Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 03-11-2009, 11:25 PM   #1
Member#: 205444
Default EJ22 Need some Info
Ok guys, im new to the whole subaru world. Im am a v8 guy (dont knock me lol) use to the small block chevy but lets face it all combustable engines have the same concept. This build is not for me but am helping my brother. He has a 95 impreza ej22, hes looking to build a stout little motor and there are way to many honda guys in the area so we both figured subaru would be the thing to do. Were looking to pull the EJ22 and run 13-15lbs of boost. Forged rods, Pistons, Steel crank, all balanced and probably run in the 8300 rpm range. It is a non turbo car, so i need some information from someone who has done this. As far as fuel what will be needed, injectors, ecu upgrade, fuel pump? Also is the stock crank in the 2.2's steel or cast? Its not going to be a race car by any means an everyday driver is more like it, but im sure you guys have some wealthy information that could be used. We both work as mechanics and have the knowledge as far as getting it done just need some help as far as what works for your guys and if that engine is worth it, as i see not much being done to the EJ22's. Some information would be very helpful
Thanks Guys, Solo
SolocamX708 is offline   Reply With Quote
Old 03-12-2009, 02:53 AM   #2
Member#: 85354
You'll very quickly find that it is likely cheaper and easier in your situation to consider swapping a complete turbo motor into the car. There are plenty of motors out there, and rewiring the car is the hardest part.
Search for some swap threads and read up.
InfiniteMotorsports is offline   Reply With Quote
Need some info on EJ22. dlo914 Normally Aspirated Powertrain 36 04-04-2009 11:01 PM
i some need some info 387hardcore Brakes, Steering & Suspension 2 04-06-2005 10:09 AM
need some info bad. SpeedRacerVer2.5rs New England Impreza Club Forum -- NESIC 1 06-04-2001 04:51 PM
need some info from those with stromung..... randolph-rs Normally Aspirated Powertrain 5 03-23-2001 06:57 AM
need some info Keiho Canada Region Forum 6 03-07-2000 03:22 PM
