Welcome to the North American Subaru Impreza Owners Club Friday November 21, 2014
Old 03-12-2009, 02:16 PM   #1
Greg555
Member#: 814
Want engine mgmnt?
I sell ViPec's ECU's
Default Rally car motor build. My turn to ask questions :)
Need help with calculating this engine stuff for my next rally car.
Here is what I want:
A lot of torque.
To give you an idea Subaru Rally team USA supposedly have 500 foot pounds of torque in Dave Mirra's car but lets not discuss this here please.
KEEP IN MIND WE HAVE TO USE 34mm RESTRICTOR and I will be running ALS
Car will always run on Sunoco 104+ race gas and will be professionally tuned
Available parts that I have laying around:
ver 8 heads
US STI heads
ver 7 complete block that needs bearings
EJ22T closed deck block from US legacy T with million miles
04 STI crank
2x 2.5 NA cranks (not sure what year)
IHI twin scroll turbos from ver 8
ViPec engine management (I'm a distributor)
I was considering building up the closed deck 2.2 but after 6 hrs of reading threads I am more confused than before. I am not liking the phase1 bearing situation so I think my V7 block would be a better choice.
2.0 in that V7 block is awesome in rallying but what do you guys think about building a 2.2 stroker with the V8 heads???
I would get custom pistons, rods and head gasket and that's what I need help with. Also what kind of block/crank treatments I sould consider.
Also I should mention that I don't want to spend $5K on the build.
Thanks a lot
Greg
G-Rally.com
Greg555 is offline   Reply With Quote
Old 03-12-2009, 03:07 PM   #2
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
well luckley you have alot laying around, if your wanting torque you may wasnt to go with a 2.2 or a 2.5, i think a build 2.5 would be better for the torque you want, and with those v8 heads it will flow good, but that might be a moot point because of the restrictor. the nitride coating is nice on the cranks
seanathanq83 is offline   Reply With Quote
Old 03-12-2009, 03:18 PM   #3
Greg555
Member#: 814
Want engine mgmnt?
yeah, I got a lot of Subaru junk that accumulated over last 11 years since I bought my 98 RS
I think I will go with the 2.2 in the v7 block
For that setup do I use 2.5 NA crank or 2.5 STI?
I need to figure out rods, pistons and gaskets
I'm not afraid of running higher compression ratio since its a race car
Also with restrictor rally cars usually go face down past 5500 rpm
Greg
Old 03-12-2009, 03:30 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well a quick off the cough estimate is you'll choke flow a bit north of 600cfm (pending a lot of things) so I wouldn't run the V8 head and would opt for the smaller USDM sti ports.
If your ultimate goal is peak tq alone...then get the biggest stroker motor and shortest rod ratio you can, with as much compression and boost as it can take...now your tq curve will be more like a tq mountain peak but you'll have gobs of it. Put that with 4.44s and you'll have even more tq at the ground.
With what you have though a 2.1 short rod or 2.2L or a 2.35L short rod are your options.
Of those, I'd choose the 2.2 or the 2.35L if peak tq is truly the goal. All of them will hit choke flow very easily.
Personally with my bias I'd still vote a destroked EJ25, to give the displacement but also to aid with restrictor whoes...internal geometry, cams and manifolds will be crucial for squeezing everything through the restrictor and into the motor...
Old 03-12-2009, 04:03 PM   #5
Greg555
Member#: 814
Want engine mgmnt?
The stock STI heads are sort of sold (sold but didnt get the money yet) so I am leaning towards using V8 heads
What king of combilations I could use to acheive the 2.2 or 2.35 and what kind of CR is possible?
Can I use these pistons? http://forums.nasioc.com/forums/show...ght=2.2+stoker
Greg.
Old 03-12-2009, 04:07 PM   #6
seanathanq83
Member#: 173241
man gotta give props to a man who knows his stuff, i say try to pick up an sti block and an 04-05 wrx crank, grab some 100mm pistons, and some nice stout rods, get it put together andyou got yourself a 2.35l that can still rev if needed, but still has some displacement. get some cams that will help down low and mid rpm and get the manifold ported and get the flow as smooth as possible. this should be a killer setup for low end torque. but still be able to take the most advantage of the restrictor. and dont forget, we like pictures around here
Old 03-12-2009, 04:24 PM   #7
Greg555
Member#: 814
Want engine mgmnt?
So lets say we're going with v7 block making it 2.2 with v8 heads
What pistons, rods and gaskets do I need?
Greg
Old 03-12-2009, 07:41 PM   #8
seanathanq83
Member#: 173241
regular gasket for a 2.0, and to get a 2.2 you need a stroker kit, the sti crank only makes it a 2.123, which really isnt worth it. or you would need to sleeve it and bore it out, which comes back to doing a 2.3 liter
Old 03-12-2009, 08:50 PM   #9
Greg555
Member#: 814
Want engine mgmnt?
...so with the 2 liter block I can only get 2.123? How do i go bigger to 2.2 or 2.34?
Greg
Old 03-12-2009, 09:18 PM   #10
Homemade WRX
Member#: 33782
96 bastard child
2.34 is 79mm stroked EJ22 block or a destroked EJ25
pick your route. I'd take the latter
Old 03-12-2009, 09:18 PM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
IF you can afford it, maybe a lysholm supercharger? Then go with the high"er" compression destroked 2.5 that Homemade WRX suggested. That way you have INSTANT massive torque the moment you mash the gas....
Old 03-12-2009, 09:44 PM   #12
Greg555
Member#: 814
Want engine mgmnt?
no superchargers for me. I will have ALS to help with the lag issue
so with 2.0 I get 2.123456 and with 2.2 I could get 2.34
When you say 2.2 do you have in mind NA 2.2 or the legacy turbo block?
What can be done about the phase 1 bearing situation on the 2.2T and how expensive does it get?
Greg
Old 03-12-2009, 10:46 PM   #13
seanathanq83
Member#: 173241
you can have the crank ground for the thrust, or the block ground for the crank. they have differant thrust bearings. you can take the 2.2 with the 2.5 crank and get where you want.
as for price, 2.5 turbo cranks are reletivley cheap, then you just get forged rods, a set of forged pistons, you should go .20 over, because its hard to hone a block to fit a stock piston. with that you will need a gasket kit, around 300, headgaskets around 150-200. would advise cylinder head bolts 200. usdm sti heads, with a valve job, set of cams and vavlesprings if you are wanting to rev to 9, but with the restrictor, im not sure it will be worth it to rev that high. and a set of rod and main bearings. also a new oil pump and water pump, then the basics like belts, and motor mounts if you want. you should be able to do it for less than 5k, but you will also need a tune.
Old 03-13-2009, 08:02 AM   #14
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
aaah, say it ain't so...
actually I am going this route, with slighly higher CR pistons, it should work very well
Hyper is online now   Reply With Quote
Old 03-13-2009, 10:41 AM   #15
Homemade WRX
Member#: 33782
96 bastard child
I still say keep the ver 8 crank and sell the block and get an EJ257 block antilag for low end and longer rod ratio to help carry out the choke point a bit further...it'll still give you 2.34 (at 99.5mm) or 2.36 (at 100mm).
Of course this won't give a huge torque peak but a longer torque band...if you want a peak tq value you don't want to go my route but with the biggest motor with shortest rod ratio you can.
Old 03-13-2009, 11:13 AM   #16
nojokesniper
Member#: 192623
just so you know you can run a phase 2 crank in a phase 1 block, you just put the bearing in the #3 position instead of #5
nojokesniper is offline   Reply With Quote
Old 03-13-2009, 11:32 AM   #17
centeno711
Member#: 184638
2002 wrx wagon wrb
97 cummins 1ton 4x4
"just so you know you can run a phase 2 crank in a phase 1 block, you just put the bearing in the #3 position instead of #5 "
is that true? ive never heard that before
centeno711 is offline   Reply With Quote
Old 03-13-2009, 11:53 AM   #18
seanathanq83
Member#: 173241
lol no actually thats wrong, you will have to have either the crank cut to fit the block of the block cut to fit the crank, and you will have to fun both #3 and #5 thrust
Old 03-13-2009, 12:46 PM   #19
nojokesniper
Member#: 192623
looky here
http://www.rs25.com/forums/showthrea...=39629&page=28
"brydon, we used the same ACL main bearings in that EJ25D block as we did my EJ251 block. You just have to put the thrust bearing on journal 3 instead of 5. I guess if you wanted to run dual thrust bearings... you could machine the block, but what is the ****ing point?
YOU CAN RUN PHASE 2 BEARINGS IN A PHASE 1 BLOCK."
"So I can put the phase 2 crank in with no clearance issues, using the #3 thrust bearing in proper locatioin, correct? I'm going to start looking around for parts for building it up when I take it out and swap the k in."
"yes.. as long as you put the main bearings in the proper location. your fine. The older phase1 blocks dont have quite as much room for aftermarket rods. So, if you use stock STI rods, which i recommend because there is nothing wrong with them, you will have no issues at all."
Old 03-13-2009, 02:49 PM   #20
seanathanq83
Member#: 173241
phase 1 main bearings are 48mm not 52mm
Old 03-13-2009, 04:13 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
phase 1 rod bearings are 48mm not 52mm
fixed it for you...the phase two cranks can drop in but some guys are saying they are having issues with the thrust clearances.
I'd still machine the #5 main and go rear thrust.
Old 03-13-2009, 05:46 PM   #22
nojokesniper
Member#: 192623
thank you for your support, seams like sean just missed out on subaru 101
Old 03-13-2009, 05:52 PM   #23
Greg555
Member#: 814
Want engine mgmnt?
how how expensive is this?
Old 03-13-2009, 06:51 PM   #24
nojokesniper
Member#: 192623
how expensive is what?
Old 03-13-2009, 06:55 PM   #25
Greg555
Member#: 814
Want engine mgmnt?
we were talking about phase 2 crank in phase 1 block and work related to fitting the thrust bearing
Rally Car motor help! manick777 Built Motor Discussion 12 06-27-2010 11:37 PM
My turn to ask you... Comp. Surge JSarv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 03-31-2009 06:43 PM
Motor build time - what to do? Mikedabike Built Motor Discussion 2 11-14-2008 04:25 PM
My mom is asking questions about Foresters and Legacys.... Homemade WRX Mid Atlantic Impreza Club -- MAIC 12 03-23-2005 01:56 PM
My turn to part out my car VeganWRX Rocky Mountains Impreza Club Forum -- RMIC 0 11-27-2003 12:20 PM
