Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 03-12-2009, 03:34 PM   #1
wrxphantom
Member#: 128643
2013 STI Sedan
Default Is this Worth $1000, or even worth it
I have an 09 WRX with the following mods
Perrin TMIC
Ividia Catted Downpipe
SPT Exhaust
K&N Drop in Filter
Open Source Road Tune
Wondering if i should spend $1000 on the following or its not worth it.
Perrin equal length headers
Perrin uppipe
Turbo Inlet pipe
Perrin Crank Pully
What do you gurus think.. are all these mods worth the money for the horsepower gain????? or should i buy something else???
Please state your reasoning. thanks a lot
wrxphantom is offline   Reply With Quote
Old 03-12-2009, 03:44 PM   #2
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
PPG,Front LSD,4.44,E85
I think you need to read the sticky @ the top of the page.
Dont WAIST you money on that stuff. Theres other things you need at this point the will yield better gains. Unless you just just like to add parts that dont help fix the weak link in the chain...
Search n00b!
rexworx is offline   Reply With Quote
Old 03-12-2009, 03:50 PM   #3
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
I would do it. their small things but could add to be bigger once protuned for it. Or since you have a little power already in the car move to suspension or styling or some other section, just my opinion, but for 1k I would do it.
talvai is offline   Reply With Quote
Old 03-12-2009, 04:24 PM   #4
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
No, dont get that stuff, I know plenty of 500 whp cars still running stock headers, Put it towards a turbo kit, with of course supporting mods: bigger injectors, fuel pump, Accessport, possibly a fmic (if you dont mind a few hundred more of an rpm lag)
KB'izzle is offline   Reply With Quote
Old 03-12-2009, 04:30 PM   #5
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
it would definitely help some power in there
but you could always do fuel pump, injectors, larger turbo...intercooler...and have that be part of it
IMPORTIMAGE is online now   Reply With Quote
Old 03-12-2009, 04:32 PM   #6
xaznxeclipsex
Member#: 179310
2015 Forester XT
It would help, but you wont get the best bang for the buck.
xaznxeclipsex is offline   Reply With Quote
Old 03-12-2009, 04:52 PM   #7
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
I'd use the 1000 for some suspension and some exterior/interior/audio mods. BUt then again that's just me.
lateralus1082 is offline   Reply With Quote
Old 03-12-2009, 04:57 PM   #8
KB'izzle
Member#: 169955
30R BUILT STI /AREA
Cant deny that actually, Never regreted getting 24mm front & rear whiteline sway bars and endlinks <- thats best bang for buck mod
Old 03-12-2009, 04:58 PM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
keep adding power and neglect the most important things on the car, the things that keep your car attached to the road.
power + no grip = no fun.
Old 03-12-2009, 05:10 PM   #10
wrxphantom
Member#: 128643
2013 STI Sedan
How about instead I get springs front and rear strut bars
Old 03-12-2009, 05:15 PM   #11
MIKE DD
Member#: 106818
2003 Truck
Better route imo, go with that.
MIKE DD is offline   Reply With Quote
Old 03-12-2009, 07:06 PM   #12
nhat
Member#: 140163
03 STi
hellaflunctional
start with just sways. only springs i would try are 08/09 sti takeoffs.
Old 03-12-2009, 08:16 PM   #13
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
tick, tick, tick, tick, tick........
scby rex is offline   Reply With Quote
Old 03-12-2009, 08:36 PM   #14
KB'izzle
Member#: 169955
30R BUILT STI /AREA
yes you have it backwards man, get the sways, the struts bars are for looks at your stage. Same price & a tiny tiny bit more to put on, WAYYY better in the long run. SWAY BARS SON!
Old 03-12-2009, 09:36 PM   #15
MattPersman
Member#: 139385
what about tires? those make a huge difference on WRXs
MattPersman is offline   Reply With Quote
Old 03-12-2009, 09:39 PM   #16
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i say port your stock headers, get some good break pads and some springs, a drop in filter, a walbro fuel pump, and save the rest for injectors and turbo upgrade and tires
seanathanq83 is offline   Reply With Quote
Old 03-12-2009, 10:44 PM   #17
jondl
Member#: 148591
2007 WRX Sedan
CGM
tires - $450
front/rear sways + endlinks - done.
the best mod i've ever done was getting rid of the stock tires for some rt615s
jondl is offline   Reply With Quote
Old 03-20-2009, 07:47 PM   #18
DasWRX
Member#: 187259
2009 WRX Sedan
Your current mod list looks good (DP,CBE,TMIC,TUNE).
$1,000 would buy you:
Walbro255 FuelPump
Swaybars F/R
17"x8" wheels
225-45-17 Tires -DunlopDirezza Sport Z1 Star Spec
After that, have a look at (JSC Speed):
Tein Super Street Coilovers With Pillowball Upper Mounts
Springrates are much stiffer than stock at: Front: 336 / Rear: 280
Adjustable Height & Dampening
Height range: Front: -1.0" to -2.4", Rear: -0.6" to -2.6"
DasWRX is offline   Reply With Quote
Old 03-20-2009, 08:04 PM   #19
garboplateNY88
Member#: 134113
05 LEGACYGT
247hp 300tq retuned STM
Perrin TMIC
SPT Exhaust
K&N Drop in Filter
Perrin uppipe
Turbo Inlet pipe
Perrin Crank Pully
dont get the perrin crank pulley get the ATI Super Damper
and get the APS inlet hose
http://www.atiracing.com/products/da...dam-subaru.htm
garboplateNY88 is offline   Reply With Quote
Old 03-20-2009, 08:27 PM   #20
wrxphantom
Member#: 128643
2013 STI Sedan
So far I got
Front and rear sway bars and end links
Looking to get
Inlet pipe
What do guys think about kito headers and uppipe for 376 shipped
Old 03-20-2009, 08:28 PM   #21
1sicWRX
Member#: 104631
99 911 Carrera
03 Land Rover Disco SE7
Best advice so far^^^^
1sicWRX is offline   Reply With Quote
Old 03-20-2009, 09:05 PM   #22
wrxphantom
Member#: 128643
2013 STI Sedan
i understand that... thats y i gt the sway bars and end links... for better handling
thanks everyone for ur input so far
Old 03-21-2009, 03:27 AM   #23
howweirdo
Member#: 186257
2015 WRX Premium
CBS
Perrin TMIC
SPT Exhaust
K&N Drop in Filter
Perrin uppipe
Turbo Inlet pipe
Perrin Crank Pully
i dont know if you'd be able to get all that for $1000. if you can, man, that'd be a great deal. but even if you did, that wouldn't include $300-500 for a protune, which would be a good idea after all those mods.
imo, the best thing to do is first off, figure out exactly what your goals are with power, suspension, and brakes. looking at your car for the long run will help you modify your car well without wasting money. then, for power, ask your tuner what he recommends for your goals, and then follow what he says.
howweirdo is offline   Reply With Quote
Old 03-21-2009, 04:26 AM   #24
fastwrx25
Member#: 126441
03 bugeye
I would spend that all on suspension..
but if I were to spend it on power I would get the headers and uppipe. gruppe-s equal length +uppipe or the tomei 3 bolt clones for about 450-500 bucks.
I also have a turbo inlet and crank pulley.
I would definetly do the turbo inlet to open things up, and a intake to further open things up.
I would skip the crank pulley, not worth the money for the limited power gains. great for revmatching...but not much difference in power.
how bout tgvs?
fastwrx25 is offline   Reply With Quote
Old 03-21-2009, 05:52 AM   #25
wRxbeater11
Member#: 12682
Id get a tune considering stock 09 WRX's have been blowing up left and right on this board. Thats just my 2 cents
Melo
wRxbeater11 is offline   Reply With Quote
So, uh. Is getting a Wii still even worth it anymore? Christoff Off-Topic 112 05-30-2008 08:17 PM
Oil Knowing Otters...Is this quote correct or even close? MidnightSti05 Off-Topic 72 05-14-2008 09:47 AM
Is it even worth it toput a 05 WRX TMIC on an '06?? saab-on-the-cobb Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-10-2008 02:43 PM
Is it even worth it for Alcohol / Water Injection for a stock turbo?? Red Rexx Water/Methanol Injection, Nitrous & Intercooler Cooling 10 09-22-2005 02:29 PM
Is Cat-Back Even Worth It? Tek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 09-23-2003 10:05 PM
