Old 03-12-2009, 04:53 PM   #1
Cyclops
Member#: 95017
2000 2.2RSTI stroker
2010 SWP STI
Default Can you put an STI crossmember on a 2000 2.5rs /w the stock RS stuff?
I have a 2000 2.5rs. I'm going to be putting all of my 07 6 speed stuff, including front sway bar, lower control arms, etc. on it in the coming weeks. I am wondering if I can go ahead and put the front cross member from the STI onto the RS. Eventually the RS will be getting a full steering rack, etc. from an STI but for now I was going to keep the steering rack, exhaust, motor, etc. stock and just do the drivetrain stuff. Can I go ahead and put on the STI front crossmember and just hook all of the RS stuff up to it? That way I don't have to mess with it later. Otherwise I keep the RS cross member on then and possibly have problems hooking up my STI stuff?
Cyclops is offline   Reply With Quote
Old 03-12-2009, 07:20 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
The swaybar won't fit, the turbo ones are different. The control arms are different too but you can shim the rs ones with some washers to fit in the turbo crossmember. I'm not sure on the rack.
Old 03-12-2009, 07:42 PM   #3
DZnutz
Member#: 91837
not possible, your problem will be with the exhaust. The RS exhaust will not fit with the STi subframe or Sti sway bar and vice versa.
DZnutz is offline   Reply With Quote
Old 03-12-2009, 07:55 PM   #4
Cyclops
Member#: 95017
2010 SWP STI
Thanks. Not gonna mess with it now. I'll just swap it when I get to the steering rack swap.
Can I put an STi cat-back on my 06 WRX? LXguy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 07-27-2007 05:20 PM
Question about replacing an ACT clutch on a 2000 2.5rs AustinSTi Transmission (AT/MT) & Driveline 4 06-29-2007 01:29 AM
How can I put a more power into my 2005 2.5RS? Anthonyx Normally Aspirated Powertrain 23 11-01-2006 09:12 AM
Can you put an 06 STi Exhaust on an 06 WRX Wagon? INDY_06_STI Interior & Exterior Modification 3 06-20-2006 09:51 AM
Can you put an emblem on a Liberal grille? Jackie Interior & Exterior Modification 11 05-17-2006 12:15 AM
