#1 |
Member#: 38345
Vehicle:2004 WRB WRX |
I am trying to avoid running 2 walbro's in tank feeding my swirl pot. I am thinking about running a 044 in tank has anybody done this before? Is the 044 even made for in tank placement?
#2 |
Member#: 150986
Vehicle:06 LSB STi AWDM.NET-LMM Powered |
i wanna know the same exact thing, cubuff how much hp are you looking to hit? i want a setup that will safely hold my 500ish whp q16 tune and 425pump tune. I was pretty sure it was a drop in fuel pump until i read a thread the other day that made it seem like a in line
#3 | |
Member#: 38345
Well im going to run an intank setup either dual walbro's or something else into a swirl pot and from the swirl pot im going to run an a1000 to the rails. Im thinking my setup will be 650+whp. I would really like to run the 044 intank and avoid running dual walbro's. I am also thinking a single walbro to the swril pot may be enough but I just want the added security in making sure the swirl pot is always full. What I really want is a company to make an aftermarket fuel tank that is sumped so we could run inline pumps right off the fuel tank. |
#4 |
Member#: 195677
The 044 is inline only, cant go in the tank. Im in the process of building a fuel system for someone, and I have found 2 pretty good options. A dual fuel pump hanger, and the TurboXS surge tank. Both are designed for a pair of Walbros.
I really like the idea of the surge tank, because you have the option of running dual pumps. |
#5 | |
Member#: 38345
#6 |
Member#: 195677
There might be, but I cant think of anything off the top of my head. I think the Denso (stock Supra TT) would be the closest. I always use dual in tank for simplicity.
#7 | |
Member#: 166098
Vehicle:2005 Subaru, STi Black |
http://www.jayracing.com/index.php?m...&products_id=1
http://www.dsmtalk.com/forums/showthread.php?t=167359 |
#8 | |
Member#: 96712
YOU ARE KILLING ME!!! haha.... dude, if you are only feeding a swirl pot, in other words, zero backpressure or less than 5psi of pressure, even an almost stock pump could probably feed the swirl pot.... so, in that case.... a single 044 pump used intank or 93-98supra pump used intank would certainly feed the swirlie.... |
#9 |
Member#: 84482
Vehicle:2005 STI.UR gt4088r E85 pro comp sti |
i don't know why others are saying the 044 is inline only, b/c it's both
mine is intake and it keeps up with dual walbros...it's good for a lot of hp |
#10 |
Member#: 195677
Its designed as an inline pump. It CAN fit in the tank, but its big and you it takes a bit of work to make it happen.
#11 |
Member#: 166175
I've used 044's in tank on a turbo NSX and many dsm guys use it in tank. It's basically needed when you don't want or need twin Walbro's. I'm in the process of putting one in(in tank) my dsm in order to run e85 with 1200cc injectors on a gt3561 with a 2.4l block etc.
#12 |
Member#: 163648
Vehicle:2002 Wrx,2.5L,HTA86 E85,2007 6mt,No traction |
I am trying to decie between dual walbros or trying a 044... on 1250cc injetctors on e85 lol only its a gt3076....2.5l block I would like to try intank...hhhmmm
#13 |
Member#: 166175
#14 |
Member#: 89472
I run a 040 in tank on the std bracket and wiring its runing fuel up to a custom twin feed set up with Siemens S107 injectors, its probably a little louder than a walbro but I like Bosch and you certainly will know if it ever stops
#15 |
Member#: 135588
Vehicle:2007 LGT **SOLD** |
I run the 044 intank. was a very easy install with the correct fuel sock!
http://www.pegasusautoracing.com/pro...asp?RecId=5813 http://www.pegasusautoracing.com/pro...asp?RecID=5812 |
#16 |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
Don't forget that the return fuel line feeds back into the swirl pot so it's actually feeding itself, minus what's being consumed by the engine. I just swapped in a stock in-tank fuel pump to feed my swirl pot. Seems to be working out just fine.
#17 | |
Member#: 38345
After thinking about it more I dont think there will be a need for a larger intank pump let alone dual walbros. With the return going to the pot I dont think it will ever be close to empty. I may put a level indicator in the swirl pot to make sure though. |
#18 | |
Member#: 163648
#19 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag |
Bump for more info from sean18337. I am trying to decide if I should run mine in tank or inline.
#20 |
Member#: 34519
South East
Vehicle:03 Wrx,Gt30r,AEM EMS, Air to waterWRX blue |
http://www.jayracing.com/index.php?m...products_id=62
that is what you need a intank sock for your 044 |
#21 | |
Member#: 114730
SWIC
#22 |
Member#: 34519
South East
i don't suppose it could be very hard. i am sure most people could do it with a cut off wheel and some butt connectors. knowing my brother he would do some tig welding and ss parts and solder all the connections. i know he already spoke of wanting to put twin 044 pumps in tank.
#23 |
Member#: 135588
#24 | |
Member#: 114730
SWIC
#25 |
Member#: 163648
Yea any updates here ive got -id bosch 1000's to support at 80 psi lol
| Thread Tools | |
| Display Modes | |
| wiring up walbro 255/bosch 044 to run 100% ? | Rod702 | Built Motor Discussion | 56 | 08-03-2011 09:48 AM |
| WTB: BOSCH 040 Intank Fuel Pump | bjohnson_55 | Private 'Wanted' Classifieds | 0 | 04-15-2010 06:54 PM |
| Bosch 044 pumps, Magnafuel Fuel Pressure Regulator, Tial 1 bar wastegate springs | jigga | Engine/Power/Exhaust | 14 | 06-05-2008 08:19 PM |
| FS: new Bosch 044 fuel pump | garagedefeat | Engine/Power/Exhaust | 7 | 04-08-2008 10:18 PM |
| FS: Bosch 044 pump, magnafuel external pump, 044 pump holders, weldon pump controller | jigga | Engine/Power/Exhaust | 8 | 10-19-2007 11:31 AM |
