Old 01-29-2010, 02:09 PM   #1
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Default Stripped a Caliper Bracket Bolt -> Need help finding another.
I stripped a caliper bracket bolt on my car the other day.
Long story short, I need another one, but I can't seem to find them either at the dealership/auto store or online.
Anyone have a part number or a place I could go find one?
PS: it's not the caliper mounting bolt.
formula91 is offline   Reply With Quote
Old 01-29-2010, 02:10 PM   #2
littlewhitewagon
Member#: 103068
11 STI sedan
Go to a fastener store or the dealer. Either one will have it. For the fastener store, bring the broken bolt and dimensions you need.
littlewhitewagon is offline   Reply With Quote
Old 01-29-2010, 02:34 PM   #3
Bottom Feeder
Member#: 2808
That's a fairly good-sized bolt with coarse threads. How did you strip it?
Bottom Feeder is offline   Reply With Quote
Old 01-29-2010, 02:48 PM   #4
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
you talking about the front bracket to knuckle bolts? P/N should be 901130011
it's a M12x1.25 flanged bolt iirc
UkNuck is offline   Reply With Quote
Old 01-29-2010, 03:12 PM   #5
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I already have a bolt for the same dimensions that I am using temporarily. The problem is that those bolts are usually not graded to hold up the caliper+usage.
Well I was inspecting brake parts as part of the 60k maintenance, and 1. it was crazy rusted, and required me to use a breaker bar to get it off, and 2. the rotor was stuck to the hub, and I decided to use that bolt to try to make the rotor come off, and lo and behold the threads stripped when trying to take the hub off. Stupid me, I know. The other one worked though, oddly enough.
Much thanks are given.
BTW where'd you find that number?
torque spec for caliper bracket bolts carguy4 Brakes, Steering & Suspension 2 04-06-2007 10:02 PM
Caliper bracket bolts are impossible!! subynube Brakes, Steering & Suspension 17 06-13-2005 04:27 PM
RS caliper bracket bolt seized Fyrfytr Brakes, Steering & Suspension 6 08-17-2004 08:12 AM
01 RS Caliper Bracket Bolt Torque cotton100 Brakes, Steering & Suspension 3 12-27-2003 07:56 PM
Stripped Power Steering Bracket Bolt stimpy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-24-2003 12:34 AM
