Old 03-13-2009, 09:49 AM   #1
stikiller1234
Member#: 200480
96 impreza
Default feed tube????
i have a 96 impreza brighton, all set to be turbo'd, where do i put the oil feed line? do i have to drill into the block or something thats gonna suck?
stikiller1234 is offline   Reply With Quote
Old 03-13-2009, 10:15 AM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
You can get oil feed from the oil pressure seinding unit port.
You can get some brass T's from the parts store and some brake line and make an oil feed tree where you still retain the OE sending unit in its location.
If you decide to do this, remove the alternator first. It will make the job go easier.
PhilSine is offline   Reply With Quote
Old 03-13-2009, 06:45 PM   #3
subiidude
Member#: 141472
2008 shagg wgn STI
OG FP20g+e85 corn booze
or you could tap here next to the pcv
subiidude is offline   Reply With Quote
Old 03-13-2009, 10:08 PM   #4
master c
Member#: 168226
this is exactly what i did, works perfectly
master c is offline   Reply With Quote
Old 03-14-2009, 03:19 AM   #5
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
I like your ideas better. Had I known that at the time I did mine it's how I would have done it.
Old 03-14-2009, 04:40 AM   #6
master c
Member#: 168226
i like that pcv setup- what kind of fitting is that in teh pcv tube sticking into the block??? i would love to do something like that with mine
Old 03-14-2009, 05:28 AM   #7
subiidude
Member#: 141472
2008 shagg wgn STI
thats just my stock pcv
is yours different?
Old 03-15-2009, 03:34 AM   #8
master c
Member#: 168226
yeh mine is just the large brass tube, no small nipple fitting on it
Old 03-23-2009, 10:38 PM   #9
stikiller1234
Member#: 200480
96 impreza
thank you so much guys!!!
Twin-tube vs mono-tube shock data from Whiteline (LONG) Jim Gurieff Brakes, Steering & Suspension 34 01-09-2007 02:02 PM
My boss sez: so they're planning on removing her feeding tube... DoinkMobb Off-Topic 12 04-01-2005 12:40 PM
Terry Schiavo Feeding Tube! Great for Parties zperkins Off-Topic 11 04-01-2005 12:17 AM
Jeb Bush orders feeding tube to be reinserted beethoven Political Playground 43 11-02-2003 08:23 AM
