Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 03-13-2009, 11:57 AM   #1
ZenMotors
Vendor Sales Rating: (9)
Member#: 203926
2002 Turbo IS
GGP
Default Zen Motors -Coilover Specials! Stance & BC Racing,Tein, Rotors,SS Lines,DBA,Carbotech
Zen Coilover Specials!!!!
Stance USA
Get your Stance Coilovers today from Zen Motors!!! We can have tracking number within 24 hours of transaction!!! We are eager to earn your business!!!
Stance USA has a great product line that you should really give a try. They are made in Japan. They have a wide variety of applications that suits your needs, and Budget! I am personally running them on my Time Attack car myself.
Stance LX+Plus
The LX+Plus was designed for the enthusiast that wants greater performance than their standard dampers without sacrificing ride comfort. TheLX+Plus uses twin-tube technology to give a unique, luxurious ride quality. 15-way adjustable damping allows the driver to tune the shocks for any condition or handling characteristic.
Retail: $1395.00
Call, E-mail, or PM for Special Pricing!!!
Stance GR+
The GR+ is our flagship line. It features 15-way damping adjustable monotube shocks, which allows the driver to fine-tune the handling and ride. A separate lower bracket allows the ride height to be adjusted without sacrificing stroke. Spherical bearings are used to give the driver greater feedback. Inverted monotube shocks are utilized on strut types for greater rigidity and heat dissipation. Camber adjustable upper mounts are used on strut types.
Retail: $1429.99
Stance GR+ Pro
The GR+ Pro coilover has all the features of the GR+ but adds the benefit of a helper spring. The helper spring allows the shock piston to be placed in the optimal position within the shock body, increasing rebound stroke, and maximizing articulation on cars with minimum suspension travel.
Retail: $1529.99
Stance SS-D
The Special Setting Dampers were developed to meet the special demands of the circuit. The SS-D is valved to work in conjunction with race tires to maximize traction. The GR+ Pro SS-D were used to win national titles in both drifting and time attack; setting the highest benchmark for itself - winning.
Retail: $1529.99
Stance AL+Pro
The Stance AL+Pro has all the features of the GR+ Pro, but uses an anodized forged aluminum shock body. This increases anti-corrosion properties while reducing unsprung mass, enhancing all aspects of performance without any drawbacks.
Retail: $1895.99
Stance GR+3-Way
The Stance GR+ 3-Way is our top of the line coilover. The GR+ 3-Way features 3-way adjustability, enabling the driver to fine tune low-speed and high-speed bump separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control.
General Tech data on these coilovers for your Subaru the shock body is 53mm in diameter with a 47mm shock piston. All Stance coilovers are monotube for better damping control and anti-fatigue
characteristics. For the Subaru Impreza application, being MacPherson on all four corners, they are inverted which gives the shocks better heat dissipation for high severity conditions, like at the track. Another benefit the Impreza applications have is that all four corners come with camber plates for increased camber adjustment. This is a very simple concept, but is something that is overlooked by most other coilover manufacturers. The standard spring rates are 8K/6K on the GR+/GR+ Pro,
but for those looking for a stiffer spring rate to take advantage of R-Compound tires can get the SS-D which is valved for 11K/9K. We can also have custom valved coilovers made for custom spring rates.
Retail: $2995.00
BC Racing Coilovers!!!
BC Racing is proud to provide coilovers that strike the best balance between performance and cost. We have designed all the most popular and essential features into our coilovers while keeping the end price down for the consumer. Whether you are cruising down the street, enjoying your favorite twisty mountain road or tearing up a race track we have a coilover system for you.
BC Racing Coilover Specs
General
  • Mono-tube shock design
  • 30 levels of damping force adjustment
  • Pillowball mounts and adjustable camber plates included*
  • Adjustable rear camber plates available
  • Separate Full length height adjustable
  • Inverted and Non-Inverted setups
  • One year warranty
  • Rebuildable *Fronts, where applicable
Technical
  • Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
  • Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
  • Patented concave lower locking ring, to prevent unseating
  • Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
  • T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
  • Iron lower brackets on MacPherson struts to ensure rigidity
  • Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
  • High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
  • 2 step coating process utilizing nickel and chromium plating to prevent corrosion
  • Newly developed lubricant oil in all shock cartridges minimizes aeration and cavitation.
  • An additional bearing beneath each pillowball mount provides a smooth action and prolongs the life of the pillowball itself.
  • Each BC damper is individually dyno tested before leaving the factory, making sure each damper is matched to within 5%, ensuring an equal balance in handling. OEM standards are 13% in comparison.
BC BR Series:
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
BC Ram Series:
BC Racings Inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover setup we move the vital damper fluid away from detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The Inverted setup also handles high-g loads better and is much more durable under high stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
BC ER Series:
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than a conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune their setup using the separate, 30-way, rebound and compression tuning dials.
Tein Coilovers
Tein Flex
Description:
TEIN has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The FLEX damper Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. We have incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The FLEX damper kit includes pillow ball upper mounts, which increase steering response; 16 levels of damping force adjustment, and is compatible with the EDFC (Electronic Damping Force Controller) for added convenience and adjustability.
Retail Price $1840.00
(Call / E-mail / Or PM for Prices!!! - Too low to Post!!!)
Call Zen for a Special Price!!!!
KW Suspension Kit
KW Varient 3 Coilovers
Description:
The new KW Variant 3 Coilover System is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
Features
* Independently adjustable damping technology -rebound and compression damping
* Inox-line stainless steel technology at no extra charge
* Individual height adjustment
* German TUEV-tested adjustment parameters
* High-quality components for long life
* Comprehensive documentation for ease of use
* Infinitely adjustable rebound damping
* 14- level adjustable compression damping
* Unique, independently functioning damping power adjustment
Retail Price $2295.00
Zen Price: $1859.99
Let me know if you have any questions. I will do my best to take care of everyone right away.
These coilovers not interest you? Don't worry I carry many brands not posted above. Apexi, Buddy Club, K Sport, HKS, D2, Progress, KW, Racecomp, and much more!!!
__________________
[B]Dan Kang[/B]
[B]Zen Motors LLC[/B]
[B]Phone: 1-(888)-ZEN-MOTO[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
[B]Atlanta's Best Source for Subaru Performance, Parts, and Service![/B]
ZenMotors is offline   Reply With Quote
Old 03-13-2009, 11:58 AM   #2
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
DBA Brake Rotors!!!
DBA Standard Series Slotted Rotor
ok cancel
The Standard Series is DBA’s entry level enhanced performance rotor, offering improved braking straight out of the box. Available with slotting to improve pad bite and reduce brake fade. This also helps allow maximum cooling and provides an attractive, aggressive appearance. The Standard Series is the perfect replacement for performance conscious street motorists. DBA's Patented ‘Kangaroo Paw’ ventilation design is available on most popular DBA Street Series Rotors. * Directional slotted design (Left-hand and right-hand disc rotors) * Gun-metal grey paint provides better corrosion protection * Rapidly expels friction gases * Provides even pad wear and assists in minimising glazing of pad surfaces * Minimises brake fade * Ideal for towing and heavy loads
Zen Price: $469.99 (Front & Rear)
DBA 4000 Series
ok cancel
DBA's 4000-series is their mid-range enhanced performance rotor. It features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. The unique 6x6 Wiper Slot is designed to efficiently clear dust and debris while maintaining consistent friction and a cleaner disc surface. The 4000 series rotors also incorporate the innovative Kangaroo Paw ventilation design, which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%. Designed for the performance street and motorsport enthusiast.
Zen Price: $589.99 (Front & Rears)
DBA 5000 Series
ok cancel
The DBA 5000 series is a direct replacement two-piece disc brake rotor, designed for drivers seeking performance braking. The DBA 5000 series disc rotors consists of two main components: the aluminum center hat and the cast iron disc rotor. These two components are bolted together with NAS (National Aerospace Standard) bolts and lock nuts, hence the term 'two-piece' rotor. The main advantage of a two-piece rotor (with aluminum hat), is the ability to allow the cast-iron disc rotor to expand and contract uniformly as the temperature rises and falls during brake application. The benefits of this is minimal distortion and warping of the cast-iron disc rotor. The Aluminum mounting center hat is made from super-light 6061-T6 Aluminium material, as used in aircraft structural design. The thermal conductivity and high strength of hat allows it to handle large temperature changes. The benfits of this is minimal distortion and warping of the cast-iron disc rotor. All DBA 5000 series rotors are slotted; slotting limits the possibility of glazing your brake pads and allows better 'pad-bite' under extreme braking conditions. Slotting constantly improved the disc pad friction face by wiping away the impurities and resins in the friction material. The DBA 5000 series rotors are manufactured with directional slotting, i.e. Left-Wheel disc slotting and Right-wheel disc slotting. Features: * Direct replacement rotors * Hats made from super-light 6061-T6 aircraft Aluminium material (reusable) * Replacement disc rotors available (without hat) * NAS (National Aerospace Standards) bolts and lock nuts * Thermal Stabillity Profiling (TSP) * Minimal bedding-in of rotors * DBA 5000 series slot design * Thermo-Graphic paint markings for temperature monitoring
Zen Price: $679.99 (Fronts!)
Zen Motors Special!!!!
Order any full set of DBA rotors receive free Brembo Brake fluid!!!
Techna-Fit SS Brake Lines
These stainless steel braided lines feature a heavy duty clear rubber coating on the outside to prevent chaffing. Stainless brake lines help reduce pedal "squish" that can be found under hard braking conditions and provide an additional degree of protection from the harsh environments of both the city streets and the racetrack. All Techna-Fit stainless brake lines are made to MVSS-1006 specifications and are fully DOT certified for road use.
Zen Price: $98.99
Carbotech Brakes!!!
We take you deeper into the corners & across the finish line first!
When you want the control and modulation to take your track-bred car deep into the turns, you need unsurpassed Carbotech brake technology. Going deep before you brake allows you to stay on the accelerator longer going into the corner and even faster coming out.
If you're a professional racer, or if you're taking your street car to the track for club events, Carbotech has the best braking solution. That's why we are becoming the #1 manufacturer of performance brake pads around the world with professional and club racers--everyone who demands the best. At Carbotech, we've been heavily involved in club and professional racing for more than 13 years. We know what you need to win.
Smarter construction.
Only Carbotech uses a proprietary Ceramic and Metallic brake construction, not the carbon and iron used in conventional brake systems. Since carbon and iron combine to form carbide, which is used in cutting tools, you can imagine what those brakes are doing to your rotors.
Carbotech Performance Brakes utilize true race compounds that are "rotor friendly," eliminating the grabbing and locking up that keep so many drivers and race cars from performing at their peak. You want to go deep to gain those precious fractions of a second before you need to brake, and only Carbotech brakes let you do just that. In every turn, all race long.
Custom solutions.
Designed by racers for racers, Carbotech brakes can be specified to meet the needs of your car and driving style. Just give us a call and we can recommend the compounds that will be perfect for your front and rear pads and shoes, assuring that they perform together with optimum effectiveness.
Give me a call for Quote on the application you are looking for! Street, Race, you name it!!!
Do these products not interest you? Don't worry I carry many brands not posted above. Hawk, Stoptech, Powerslot, Stoptech, Ferodo, Goodridge, and More!!!
Give me a call today!!!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-14-2009, 11:01 AM   #3
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Girodisc Construction:
The primary purpose of the Girodisc system is to reduce unsprung and overall vehicle weight. The secondary purpose is to increase the ventilation and cooling capacity of the brake disc while retaining it's original dimensions.
This is accomplished by using two-piece disc construction. The central “hat” section of the disc is made from 6061-T6 aircraft specification aluminum.
The disc is made from cast iron, constructed in the USA and is made to the same specification and material as used by professional racing organizations. It is a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 8 or 10 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade 12 cap screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Sent me a PM, E-mail, or Call me for the absolute best prices!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-16-2009, 09:48 AM   #4
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Have questions? Give me a call today!!!!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-18-2009, 01:57 AM   #5
STiRA-435
Member Sales Rating: (1)
Member#: 191564
1999 WRX STi RA V-L
Could you pm a quote for Stance GR+ and GR+ Pro in a GC8 application? Thanks
STiRA-435 is offline   Reply With Quote
Old 03-18-2009, 12:19 PM   #6
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Sending it to you now!!!
Take care!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-19-2009, 11:14 AM   #7
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Bump for Specials!!!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-20-2009, 11:12 AM   #8
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Bump for Specials!!!!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-20-2009, 11:21 PM   #9
karlknaupp
Member Sales Rating: (5)
Member#: 60871
2004 WRB WRX
wow insane pricing on stance coilovers! waiting for my tax return on monday and then calling up to order the GR+pros.
karlknaupp is offline   Reply With Quote
Old 03-21-2009, 12:35 AM   #10
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Sounds Great! Have a great weekend!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-23-2009, 01:36 PM   #11
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Shave seconds off your lap times! - Buy suspension today!!!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-24-2009, 10:29 AM   #12
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-25-2009, 10:48 AM   #13
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Wheel gap looks goofy! Lower your car today!!!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-25-2009, 01:58 PM   #14
AltronX
Member Sales Rating: (18)
Member#: 86241
2006 Bolony Mobile
REAL MAN KREW #5
can you pm me a price on tein basics and bc racing coilovers shipped to 91326? Thanks.
AltronX is offline   Reply With Quote
Old 03-25-2009, 03:51 PM   #15
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
What year, and model car do you have. I will send out quote asap.
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-25-2009, 04:02 PM   #16
karlknaupp
Member#: 60871
2004 WRB WRX
coilovers got here today! thanks for the wonderful service!
Old 03-26-2009, 11:07 AM   #17
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
You are welcome! Where is your buddies order?
Take care!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-26-2009, 06:33 PM   #18
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Bump for Specials!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-27-2009, 11:44 AM   #19
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-28-2009, 11:37 AM   #20
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Weekend Bump!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-30-2009, 10:23 AM   #21
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 03-31-2009, 11:12 AM   #22
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 04-01-2009, 11:31 AM   #23
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
I will Price Match Advertised Prices!!!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 04-01-2009, 03:28 PM   #24
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Bump!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Old 04-02-2009, 12:07 PM   #25
ZenMotors
Member#: 203926
2002 Turbo IS
GGP
Bump!!!
__________________
[B]Dan Kang[/B]
[B]E-Mail:
[/B]
[B]Website:
[/B]
Bc Racing, Tein, Megan, stoptech, whiteline, hawk, DBA...UNBEATABLE Pricing+Service! IMPORTIMAGE Suspension/Brakes/Handling 551 06-26-2010 04:59 PM
Fantastic deals on Group N, BC Racing, Tein, Hawk, DBA, Stoptech subaruwrxparts.com Suspension/Brakes/Handling 23 03-10-2010 01:11 PM
04 STi Front Brembos, DBA slotted rotors, SS Lines, and new OEM Pads crikreef SCIC Private Classifieds 24 01-14-2008 09:01 PM
SoCal: STi Front brembos, DBA slotted rotors, SS Lines, new OEM Pads crikreef Suspension/Brakes/Handling 30 01-14-2008 09:01 PM
