Old 03-13-2009, 04:03 PM   #1
B-Kerr
Member#: 14841
2002 Impreza WRX
WRB, VF22, Cusco, Unichip
Default Legacy 2.5GT driveline into Bugeye WRX...
Here's the deal: I have an 02 WRX with the 2.0 with about 70k on it and the tranny has started the dreaded grind again (assuming 1st is chipped). I just acquired a 05 Legacy GT turbo with light body damaged. Since my trans is out, so I am considering doing the entire driveline swap. What's everybody's thoughts? The current driveline setup on my WRX is posted below (may have forgot something here or there).
02 WRX
IHI VF22 at 17psi (waiting on sprayer)
Underdrives
Excedey lw Fly
Clutch Masters
Borla Header
GS Uppipe
Megan 3" back
Walbro w/ pinks
Turbonetics TMIC
Samcos
Unichip (oldschool)
Ra Gearset with busted first (reason for buying GT)
335ish hp
05 GT
Stock with 45k on the odom
Can I swap drive line (minus d/s, axles, etc of course) and put my harness and upgrades over on the GT engine? (basically doing it Honda-style ) I assume there will be further tuning needed and probably bigger injectors (not sure here). I want to put the sprayer on and up the boost to about 20 or 21psi while I am at it.
I definitely wanted the 4.44 final drive, but figured hey, I can sell my engine and cover what I have in the car (I own a salvage yard), so why not do the engine too!
Any input would be greatly appreciated.
Thanks,
Scott
If you want to contact me directly, email is preferred over PM: [email protected]
B-Kerr is offline   Reply With Quote
Old 03-14-2009, 05:12 PM   #2
B-Kerr
Member#: 14841
2002 Impreza WRX
Anybody able to give any 2.5 advice? I know the 2.0 pretty well, but I do not know what will and will not swap...
Old 03-14-2009, 08:24 PM   #3
00imprezars
Member#: 63155
2000 RS
Red
just swap the shortblock, everything else is different and will require wire merging
00imprezars is offline   Reply With Quote
Old 03-14-2009, 08:35 PM   #4
iluvdrt
Member#: 46248
82 Brat
Tan
I dont think 2.0 head on 2.5 engine is a good idea. The cumbustion chamber on the head is to small for the cylinder and it will raise compression or not seal right. I am not sure though but when I was doing my motor is was rec'ed
not to use the 2.0 heads.
are the intake bolt patterns the same? If they are you could swap long blocks, and reuse your 2.0 intake. This would prevent wiring delimas.
iluvdrt is offline   Reply With Quote
Old 03-15-2009, 11:03 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
post #3
yes swap the short block merging the wiring with the 05 lgt is nearly impossible due to the immobilizer
post #4
its been done a lot ... thousands and thousands of times in the last 5 years ..
Old 03-15-2009, 11:24 AM   #6
B-Kerr
Member#: 14841
2002 Impreza WRX
Jaxx... You say swap my heads over on the 2.5 block and rot assy and all accessories - correct? Any reason not to keep the 2.5 heads and just swap intake/injection. Either way I go, with a re-tune of my uni (or purchase of another e-mgt), will the pinks keep enough flow for the bigger engine and turbo?
Thanks for the input to everyone!
Old 03-15-2009, 11:41 AM   #7
darksc00by
Member#: 102140
2016 Herp Derping
Engineer For Hire, yo.
not to use the 2.0 heads. .
wrong wrong wrong.
it raises compression yes, to like 9.0:1 MAYBE.
It's been done so many times it's retarded. There is nothing wrong with putting 2.0 heads on a 2.5 block, oh wait, I have it on mine.
darksc00by is offline   Reply With Quote
Old 03-15-2009, 11:48 AM   #8
B-Kerr
Member#: 14841
2002 Impreza WRX
DK Scoob... What year is your car? What year block did you go with? what head gasket did you use when putting it together? What turob/boost are you running? Did you change injectors? (basically, do you have a link to your buildup?)
Just wanting to have everything together before I start this project!
Old 03-15-2009, 11:52 AM   #9
darksc00by
Member#: 102140
2016 Herp Derping
I will just type it out.
I have a 2000 RS that had a 2004 WRX swap.
I decided to tear it down, and rebuild it one weekend, so I ordered a EJ257 block from my local dealership (they are all identical in shortblocks, the ej255 and ej257). I used the stock ej257 headgasket, you could go with a cometic.
I used a 16g, stock tmic, STi pink injectors, and I put down 260/290 on 14lbs of boost (thanks [email protected])
Old 03-15-2009, 11:59 AM   #10
B-Kerr
Member#: 14841
2002 Impreza WRX
What did you do for computer/mgt?
Old 03-15-2009, 12:07 PM   #11
darksc00by
Member#: 102140
2016 Herp Derping
ecutek
Old 03-15-2009, 09:32 PM   #12
iluvdrt
Member#: 46248
82 Brat
Tan
Originally Posted by darksc00by View Post
wrong wrong wrong.
I stated I wasnt sure. When I did my 2.2L build I was told to stay away from the 2.0 heads because of this reason, so I went with 2.5NA DOHC heads (which do have much bigger ports anyways).
Thanks for clearing that up!
Old 03-15-2009, 10:07 PM   #13
B-Kerr
Member#: 14841
2002 Impreza WRX
When Grossman tuned my Unichip with my VF22 at 17psi and my Turbonetics TMIC, mine was approx 330 at the flywheel. I cant remember my whp, somewhere around 250-260 I think (need to find my dyno sheets again).
Do you know if my 2.0 intake will bolt up to the 2.5 head if I decide to go that way? If not, what non drive-by-wire intake/tb would be good to replace the plastic intake on the 2.5 (and use my pink injectors)? I may swap heads, but I was figuring on selling my 2.0 to make some of my money back if possible.
Old 03-15-2009, 11:18 PM   #14
darksc00by
Member#: 102140
2016 Herp Derping
most likely yes... but... you won't be able to control the AVCS with out doing wiring.. so you might as well use the 2.0 heads.
Old 03-15-2009, 11:36 PM   #15
B-Kerr
Member#: 14841
2002 Impreza WRX
so the GTs have the AVCS like the STI... did not know this.
Old 03-16-2009, 01:39 AM   #16
darksc00by
Member#: 102140
2016 Herp Derping
EJ255
2.5 litre DOHC AVCS turbocharged, with sodium-filled valves originally designed for North American market, now sees usage in some European Imprezas and Legacies destined for Australia and South Africa. Power JIS 169 kW/230 hp
Usage in North America:
* Impreza: 2006 - present
* Forester: 2004 - present
* Legacy: 2005 - present
* Baja: 2004 - 2006
Old 03-16-2009, 11:29 PM   #17
B-Kerr
Member#: 14841
2002 Impreza WRX
Now here is my quandry... everyone is saying to use my 2.0 heads because of the ACVS kicking the timing up all the time with no control from the WRX ecu... In essence, ACVS is not much different from Honda's Vtec. Why can't we adapt a Vtec controller to control the cams? All we need is to flip the switch at approx 3-4k. Right?
05 LGT Driveline into Bugeye... who's done it B-Kerr Transmission (AT/MT) & Driveline 4 04-22-2009 02:11 PM
legacy 2.5gt vs. wrx SubiRS05 General Community 4 06-29-2007 12:36 AM
'97 Legacy 2.5GT -> WRX 2.0 Bud Brown Subaru Conversions 1 08-05-2005 05:25 PM
05 WRX, or 05 Legacy 2.5GT? xjohnx General Community 17 10-30-2004 01:19 AM
legacy 2.5gt part on a WRX spongejosh General Community 4 08-04-2004 05:42 PM
