Old 03-13-2009, 07:10 PM   #1
PDX25i
Member#: 203283
2006 Impreza 2.5i
Obsidian Black Pearl
Question Horn and cruise control help please!
So I bought my '06 2.5i back in January knowing that the horn didn't work. Later while commuting to work I found out that the CC doesn't work. I figured ok, clockspring... no big deal. Started poking around last night to make sure I had a bad clockspring before dumping $200 on a new one and got stumped.
1) I found the horn disconnected at... the horns. But when I plug them in it blows non-stop. Pressed the unlock on remote, tried key in door, key in ignition, banging on horn pad... nothing stopped it except unplugging the horns, or battery, or pulling the relay.
2) With the cruise, the "CRUISE" lights up in dash when I turn it on, but it wont "SET". Verified with a voltmeter that the brake, clutch, and neutral position sensors are working and they are properly adjusted. Made sure that the connections for the CC behind the airbag is made, and the fuse is good.
Anyone have any pointers on what else to look at? I've spent the last few hours searching the forum and can't come up with anything else to try. I'd rather not take it to the shop if I can avoid it.
PDX25i is offline   Reply With Quote
Old 03-13-2009, 08:27 PM   #2
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
It could still be the clockspring. Unplug it and see if the horn stops. If it does, plug it back in, remove the airbag, unplug the horn pad connection and see if the horn stops.
Horn stops with clockspring unplugged but not with horn pad unplugged = shorted clockspring.
At that point replace the clockspring because you know it is bad, and the cruise will probably start working too. Chances are there is only one problem with the car.
yamarocket630 is offline   Reply With Quote
Cruise Control Help Please! THE ONE South West Impreza Club Forum -- SWIC 9 05-27-2010 09:08 AM
Hazards, horn, and cruise control dead on 93 Impreza Dodge Aries K Electrical & Lighting 1 11-05-2009 02:13 PM
Help!!Check Engine Light and Cruise Control Blinking raczs_wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-18-2009 01:09 AM
Horn, E-Lights, and Cruise Control connected? rotarydelight Electrical & Lighting 6 07-18-2007 02:04 PM
Help check engine light and cruise control blink islandboy78 North West Impreza Club Forum -- NWIC 16 10-31-2005 09:34 AM
