Old 03-13-2009, 08:16 PM   #1
ki11switch
Member#: 176422
Default Part Time Knocking NOISE! Built engine/hydra what is it?
ok i bought 06 wrx in florida a month ago and drove it back to oregon. Since the day after i bought it, a loud knocking noise sometimes comes on for random lengths of time. What could it be? Does rod knock go away and come back? piston slap? I am thinking it might be one of the accessorie belt parts like the a/c pump, ps pump or alternator...
Its running off hydra ems 2.5 any way it could be the tune?
also the engine has 100mm cp pistons, eagle rods, bc 280/280 cams, and a gt35r set up.
I cant really take my car into a shop because the noise will most likely not be there because it is very random, but so loud!
ki11switch is offline   Reply With Quote
Old 03-13-2009, 08:33 PM   #2
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
post a video so we can hear. does it only occur under load/boost? Good luck, sounds scary but rod knock does not go away, just gets worse.
Fongers is offline   Reply With Quote
Old 03-13-2009, 08:58 PM   #3
ki11switch
Member#: 176422
occurs randomly. Slow knock and goes kinda with the rpms
Old 03-13-2009, 09:49 PM   #4
Fongers
Member#: 118239
2002 Built Wagon
might be an exhaust leak in the uppipe...
Old 03-13-2009, 10:11 PM   #5
ki11switch
Member#: 176422
would that really sound like a knock?
Old 03-13-2009, 10:54 PM   #6
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
check your intercooler piping... might be coming loose and then tapping against the inner fender...
jigga is offline   Reply With Quote
Big Hp Partout!.built Engine,hydra, Custom Gt42 Kit,awic Setup Etc... renosfasteststi Engine/Power/Exhaust 44 01-09-2009 04:16 PM
Smoke coming from engine bay...what is it? minhha2006 Service & Maintenance 26 10-17-2008 05:24 AM
Big Hp Partout!.built Engine,hydra, Custom Gt42 Kit,awic Setup Etc... renosfasteststi Engine/Power/Exhaust 0 08-13-2008 03:22 AM
Strange Noise in 2nd Gear, What is it? fliz Transmission (AT/MT) & Driveline 11 03-19-2006 12:56 AM
loose hose in engine bay, what is it for? kevinh211 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-17-2005 12:36 AM
