Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 03-13-2009, 11:51 PM   #1
Van'Olinga
Member#: 147203
1996 Impreza
Question wrx brakes on 96 impreza L?
I know you can do it but will my axles work? Are the splines the same count and size as 02 WRX?
Van'Olinga is offline   Reply With Quote
Old 03-14-2009, 12:08 AM   #2
lookitsawagon
Member#: 51450
2000 GC8
You can use your same spindles/hubs, just bolt on the new caliper brackets, calipers, and rotors.
But to answer your question, if you're swapping the hubs as well, yes, your axles will work. A gear puller will help get the axles out of the hubs if they've seen any salt- don't bang too hard on the end of the stub, you'll mushroom it and won't be able to get a new nut on there.
lookitsawagon is offline   Reply With Quote
Old 03-14-2009, 01:10 AM   #3
Van'Olinga
Member#: 147203
1996 Impreza
Thanks for the info. I have had them apart before, not to bad. I can get RS rear discs or the whole WRX setup but there is a lot more aftermarket/upgrades available for wrx.
WRX Struts/springs on 96 impreza outback wagon whalewagon Brakes, Steering & Suspension 0 05-29-2008 07:53 PM
02 wrx brakes on 98 impreza L rufracer Subaru Conversions 18 03-28-2007 06:07 PM
02 wrx brakes on 98 impreza L rufracer Brakes, Steering & Suspension 8 03-22-2007 11:03 PM
2004 wrx brakes on 1995 Impreza L wagon Impretzle Brakes, Steering & Suspension 10 12-23-2004 11:48 AM
Can Kartboy Shifter Fit on 96 Impreza! scoopydo Normally Aspirated Powertrain 7 10-09-2001 01:01 AM
