Old 03-14-2009, 03:31 AM   #1
mufflerman69
Member#: 166835
2004 WRX STI
white
Subaru Stars Built motor and all the goodies but lack of power...
let me just start by saying that i have built 5 wrx motors and they all tuned just fine. the case here is a 06 wrx with forged internals bored 20 over , a dom3, and PE 800cc inj. now after breakin we took it to the tuner and they tried there hardest to get it to break 300 but it just wouldn't we ran a leakdown test,comp test, and boostleak test. they all past, so i then pulled the timing covers off and checked the marks and they too were good... if you can think of anything feel free to let me know i would like to make at least 350... thanks
mufflerman69 is offline   Reply With Quote
Old 03-14-2009, 08:50 AM   #2
centeno711
Member#: 184638
2002 wrx wagon wrb
97 cummins 1ton 4x4
how much boost?
fuel and air ...spark....tune
there aro only so many factors to check. im sure if you stay with it youll get it. but if it were me i would have the tuner help you as hes the one looking at the numbers that matter
ie injector duty and what not you could be dropping boost due to insufficient fueling
it could be a million things
youve checked most of the easy ones now just find the one component thats missing
i would start at the easiest points first fuel and air
maf...do sensors and what not also as they could be working but not well enough
the good part is you know somethings wrong.....thats usually half the problem in itself
centeno711 is offline   Reply With Quote
Old 03-14-2009, 07:16 PM   #3
mufflerman69
Member#: 166835
2004 WRX STI
white
well he has me tuned for 18.8 psi... and the timing is uknown to me yet the tuner aid the timing wasnt the issue... he said the car started to fuel up on top and fall on its face.
Old 03-14-2009, 09:58 PM   #4
DemiSlayer
Member#: 120339
02 WRX
Alliance Motor Sports
This sounds like a tuning issue though could be turbo related. 300 on a domIII should be easy.
I would take it to another tuner or have one of us look at the timing map etc.
DemiSlayer is offline   Reply With Quote
Old 03-14-2009, 10:55 PM   #5
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Could you please post your fuel octane, ambient temperature, altitude and the type of dyno that was used. Thanks.
dexterous is offline   Reply With Quote
Old 03-15-2009, 11:43 AM   #6
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
did you do cams? OEM wrx heads can't flow up top well enough to take advantage of 20g+ sized turbos after 6k...
Fongers is offline   Reply With Quote
Old 03-15-2009, 04:38 PM   #7
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
02-05 wrx heads maybe, but not on 06+ heads. sounds like a tuning issue to me.
trbowrx is offline   Reply With Quote
Old 03-15-2009, 05:22 PM   #8
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
Is it hitting target AFR's at higher RPM?
bucket7788 is offline   Reply With Quote
Old 03-18-2009, 04:03 AM   #9
mufflerman69
Member#: 166835
2004 WRX STI
white
well i know the tuner isnt the issue, for one thing he has tuned every car that i have set up and the target hp has always worked out. let me just say that GST does all my tuning.
just dropped in new motor and all the coolant in the oil pan JT's06sti Built Motor Discussion 39 03-01-2009 03:37 PM
Missing at idle all the time, EGT code, and lack of power occasionally STI-NKR Texas Impreza Club Forum -- TXIC 7 05-04-2008 09:19 PM
FEELER: AZ sr55 and all the goodies.. FATgc8 Engine/Power/Exhaust 8 07-08-2007 06:02 PM
