Old 03-14-2009, 07:18 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ Tuning Stage 1 Shortblock + Blouch DOM 3.0R + 91 Octane + Meth = 384whp!
Last night we finalized the tune on our first EQ Built block
This is an 05 STI with the following:
Stock STI heads/cams with 5 angle valve job
Blouch DOM 3.0R Turbo
HKS FMIC with EQ Tuning Custom Blow-Through MAF
EQ Tuning Custom Intake
Deatschwerks 850cc Injectors
Grimmspeed EWG UP with Tial 38mm EWG
Invidia Catless DP
Greddy Evo 2 Catback
Walbro
Hallman MBC
SMC Meth Injection running 50/50 mix
Custom Tune on 91 Octane
This tune was done at about 23psi peak. Here is the chart:
This thing was a lot of fun! It spools up hard an pulls very hard all the way to redline. The EQ Shortblock has about 2000 miles on it now and hasn't burned a drop of oil.
We have another couple blocks being broken in right now, so look for results soon
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 03-14-2009, 07:51 PM   #2
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
should any block with only 2000 miles burn oil?
06-wrx-tr is offline   Reply With Quote
Old 03-14-2009, 09:32 PM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
built blocks tend to burn oil because getting the tolerances right with forged pistons is difficult.
If you want a ISO9000 certified company to build you a shortblock its very costly....IE Cosworth.
They have to meet certain tolerance standards for their machining processes and final tolerances....whereas a "normal" machine shop does not.
A regular machine shop may give you pistons and bores that are 100mm +-0.1 where as from cosworth you're gonna get +-0.0001
Old 03-15-2009, 01:35 PM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Built blocks often burn oil because of improperly set tolerances. We set and blueprint all tolerances and oil clearances to our strict specs in house.
Thanks
-- Ed
Old 03-15-2009, 02:34 PM   #5
carnz-pj-410
Member#: 110994
2004 Impreza WRX STi
95 Coupe lightweight proj
nice numbers looks like the car will be a lot of fun to drive.
thats good that you guys have stricter standards for setting tolerances, quality FTW
carnz-pj-410 is offline   Reply With Quote
Old 03-15-2009, 03:54 PM   #6
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
great numbers
achavez is offline   Reply With Quote
Old 03-15-2009, 05:25 PM   #7
GTWRX
Member#: 17282
2002 wrx
blue wr
Photos Please
GTWRX is offline   Reply With Quote
Old 03-15-2009, 07:01 PM   #8
bigboyzben
Member#: 91583
2005 STI
EQ Tuning strikes again! Looking good, Ed! Those numbers are almost exactly what I did on my GT35! Except my meth refused to spray ... I'm real interested to see what those built motors with GT35s do on some 100 octane
bigboyzben is offline   Reply With Quote
Old 03-16-2009, 10:58 AM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yea... this isn't bad at all for pump gas on a DOM3.0R. Without meth these turbos never break ~325whp on my dyno. We could probably push the turbo a bit harder, but the car was already very quick. Remember these numbers on my dyno software equate to 120-121mph trap speeds... not bad at all
-- Ed
Old 03-16-2009, 11:07 AM   #10
Tgui
Member#: 44771
What is EQ Flash?
Tgui is offline   Reply With Quote
Old 03-16-2009, 12:36 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Originally Posted by Tgui View Post
What is EQ Flash?
Its a tuning service we provide. Its similar to "OpenEcu" tuning, but we use a set of different tools/applications to tune and reflash the ECU.
Thanks
-- Ed
Old 03-16-2009, 12:37 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
-- Ed
Ed, if i send you a log will you make a power plot in your software??
What is EQ Flash?
Since ed wrote his road dyno software, I'll assume that EQ Flash is something just like ECUflash that Ed made.
Old 03-16-2009, 06:43 PM   #13
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Yes, I also think there may be a *bit* of suspicion in the Subaru community what exactly it is when a tuner goes and develops their own "custom tuning tools" as has happened some times.
I wanted to raise the point to some that Ed has substantial professional software development experience and a computer science degree from a top tier university, as well as extensive professional background in microcontroller implementations and mechatronics. I don't mean to put this background information as a contrast to other entities or anything like that, but merely want to point out that standalone ECUs, ECUtek/Cobb reflashes in the first place, professional dyno software (Mustang, DD, Dynojet) and other tuning implements were developed by people possessing Ed's type of practicing engineering background .
I think that as most of us on this forum are working professionals with areas of expertise ourselves, we can appreciate the subtle but significant difference that this kind of background makes in aftermarket automotive engineering.
verc is offline   Reply With Quote
Old 03-16-2009, 07:01 PM   #14
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
Looks great ED. If you want a real tune get it from this guy. I've spend some good time with him driving cars to be tuned and cannot believe the technical knowledge Ed knows about the computers and software.
nosmo is offline   Reply With Quote
Old 03-16-2009, 07:06 PM   #15
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
+12345
Old 03-16-2009, 08:32 PM   #16
Tgui
Member#: 44771
Thanks
-- Ed
You use an application other than Ecuflash to flash the ROM? What other tools do you use? Software/Mechanical engineer here, I gots questions!
Old 03-16-2009, 08:36 PM   #17
Tgui
Member#: 44771
Dyno and flashing software are very different. I'd be surprised if he developed something thats already supported by a totally free flashing application. It would be a lot of work with little functional gain to recreate Ecuflash. I'm betting he has some data analysis tools, which is still damned cool
Old 03-17-2009, 01:28 AM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
ECUflash is not just a flashing tool....its a tuning tool too and actually has more tuning functionality than romraider with the interpolation functions. You can literally extend the loads and make a whole new timing/fuel map in about 10 seconds.....
I use ecuflash to make changes to my ROMS more than i use romraider. I just use romraider to log mostly.
EQ Flash is probably an all in one tuner, flasher, logger and viewer. Of course im probably wrong....i guess i should just wait for ed to answer.
Old 03-17-2009, 02:05 AM   #19
PikkaGTR
Member#: 179940
2007 Sti
super clean power band!
Looks like you've been keeping busy Ed-
Seems like every other day there's a nice suby that's been massaged--
keep up the good work
PikkaGTR is offline   Reply With Quote
Old 03-17-2009, 02:39 AM   #20
jakeswildsti
Member#: 201676
Ha i was just thinking about making a thread about this.(My Car)^^^^....anyways cant say enough good things about ed and his crew. ed really put in the extra time and made sure to work all the bugs out. The end result is a very well built motor that really screams. It really hasnt burned a drop of oil, but i go through the meth quite quickly
I would highly reccommend EQ tuning to anyone looking for a built motor or awsome tune!
jakeswildsti is offline   Reply With Quote
Old 03-17-2009, 08:02 AM   #21
Tgui
Member#: 44771
I'm probably the last person you need to inform when ROM software feature sets In fact, from what I can tell, Ecuflash has even less interpolation capabilities than my hobby ROM editing program. Romraider has/had interpolation code in place ready to go. I gave up on trying to budge people there to help with the rats nest GUI code (at least it was that way when I tinkered over there).
Given OPs a known good tuner, hes probably too busy to code editors, flashers, loggers. I bet he's written a set of programs to ingest csv files to do magic for him. Lots to do with analysis. He probably won't divulge the nitty gritty details, I just think its cool other engineers are turning their skills to support their true passions.
I bet $1 I'm right You pay shipping on the pennies if I'm wrong.
Old 03-17-2009, 09:55 PM   #22
kloo413
Member#: 156840
2006 STi
Congratulations on the first EQ built block! I hope the EQ team is doing well.
-Kevin
kloo413 is offline   Reply With Quote
Old 03-18-2009, 02:05 AM   #23
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Subscribing just for the tool talk.
<== Been pondering writing the 4th (5th?) Subaru ROM editor.
Old 03-18-2009, 07:27 AM   #24
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
^^ Just join TGUI and work on his. It has the potential to be great, just needs at least all the same features of ECUFlash and RomRaider added - a lot more work :P
It'd be great if TGUI could reverse engineer the read/write capability of ECUFlash and add it to his editor (or maybe pinch the older code from the google projects page for ecuexplorer ) - then add logging capability and there will be nothing else that comes close
Great results btw :P
wrxsti.l is offline   Reply With Quote
Old 03-18-2009, 08:10 AM   #25
Tgui
Member#: 44771
Well, my logger is running in command line mode As far as flashing code, I'm more interested in real time maps If the guy two (^^) up really wants to help the community, he should hop over to RomRaider and help pickup the realtime map functionality.
Tuning: 05 STi EQ tuning stage 1 built motor, stock turbo, 91 octane OBrex05 Proven Power Bragging 5 03-18-2010 01:45 AM
FS (Missouri): Blouch DOM 3.0R Turbo w/2.4in (8cm) inlet cshepherd Engine/Power/Exhaust 2 04-18-2009 04:23 PM
BLOUCH DOM 3.0R- 4700 Miles Stiguy34685 Engine/Power/Exhaust 11 02-09-2009 11:47 PM
blouch dom 3.0r = gt3071r or gt3076r??? mannyOlicious Newbies & FAQs 17 11-24-2008 01:13 PM
FS: Brand New Blouch DOM 3.0R darkantz Engine/Power/Exhaust 1 06-18-2008 03:22 PM
