Old 03-14-2009, 08:55 PM   #1
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
Default 97 legacy transmission into a 96 impreza
Ive got a 96 impreza auto awd im doing 5spd conversion on. The transmission came out of a 97 legacy 2.5 gt, 4.111 gearing.
The pedals, clutch master, and shifter all bolted right up, but I dont have the transmission mounts or transmission crossmember from teh legacy. Can I use the original impreza auto crossmember? I assume the transmission is the same between impreza and legacy, and impreza 5spd transmission mounts will bolt up to it, but will they work with an impreza auto transmission crossmember? or do i need to find an impreza 5spd tranny crossmember?
gtu89rx7 is offline   Reply With Quote
Old 03-14-2009, 09:13 PM   #2
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
I'm waiting on this too.
I was thinking of doing the exact same thing.
Smoke is offline   Reply With Quote
Old 03-16-2009, 09:12 AM   #3
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
well after putting the transmission in, i discovered auto and manual transmission crossmembers are in different spots on the car.. and my auto impreza does not even have the mounting brackets for the manual crossmember installed. I will have to fab something to be able to bolt the manual crossmember to the car. not as easy as I was expecting
Old 03-16-2009, 10:10 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
There SHOULD be rubber covers in the spots where the the manual crossmember bolts onto the chassis. You should be able to pull those off. I could be wrong.. but check.
FuJi K is offline   Reply With Quote
Old 03-16-2009, 10:45 PM   #5
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
interesting.. i will look again, they may have been covered up by the underside spray
Old 03-17-2009, 04:34 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
When I did my M/T swap I thought that as well. All you need to do is pull the little grommets out of the car (right next to nearmost lower control arm bushing).
Then get yourself a M/T tranny crossmember, a wrx one will work. I suggest getting all the bolts in, then tighening them down. Make sure you use the rear diff that matches your tranny, unless you have looked it up already and know FOR SURE that it is the correct ratio. The legacy drivshaft wont work, it's too long. You need one from a M/T car. They can be found regularly at junkyards.
~Josh~
Old 03-23-2009, 05:11 PM   #7
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
youre right.. I finally got my wrx crossmember, mount, and driveshaft and it all bolted up no problems. i love subies!
FS: 97 legacy transmission AwdBoostCreep Drivetrain 6 11-11-2008 09:01 PM
97 legacy rear axles fit 96 impreza L rear diff, right? 2slofouru Subaru Conversions 11 07-17-2006 06:35 PM
WRX CD changer / cassette into a 96 Impreza shipjumper Car Audio, Video & Security 2 05-28-2005 08:39 AM
JDM 97 legacy EJ20TT into 03 USDM WRX marksWRX03 Subaru Conversions 9 09-01-2004 05:34 PM
98-01 Impreza dash into 93-96 Impreza moss Subaru Conversions 23 05-14-2004 10:46 PM
