Old 03-15-2009, 11:10 AM   #1
Pita84
Member#: 193644
2002 WRX Wagon
Platinum Silver Metallic
Default Crankshaft Question
Ok, let me start by saying i have searched for about an hour now and haven't found anything. If anyone could point me in the right direction to the correct post for information without being a jack about a double post i would appreciate it.
I am wondering if the 08 STI crank will work with an 05 block. The 08 crank is supposedly nitrided where i cant find any information on if the 05 is or not.
Thanks in advance
Pita84 is offline   Reply With Quote
Old 03-15-2009, 11:25 AM   #2
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
Yes it will work
DK
WrXtaCy2003 is offline   Reply With Quote
Old 03-15-2009, 11:43 AM   #3
Pita84
Member#: 193644
2002 WRX Wagon
any difference besides treated?
Old 03-16-2009, 08:11 PM   #4
Pita84
Member#: 193644
2002 WRX Wagon
Are the earlier crankshafts treated?
Old 03-17-2009, 11:24 AM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
curious too, if the new crank is nitrited
Hyper is online now   Reply With Quote
Old 03-18-2009, 11:38 AM   #6
andya
Member#: 200134
Just checked and the crank does change part# mid 08 and about $40 cheaper than the earlier 370 part. Is it confirmed that they are indeed nitrided?
andya is offline   Reply With Quote
Old 03-25-2009, 01:08 PM   #7
andya
Member#: 200134
My order for two of the cranks arrived today! They have a flat black nitride finish and the journals are polished to perfection.
Old 03-25-2009, 01:35 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
and they're $40 cheaper?
Old 03-25-2009, 01:59 PM   #9
andya
Member#: 200134
It's hard for me to believe myself.. My cost is about $25 less than the last 2.5l crank that I bought. Retail is about $40 difference.
Old 03-25-2009, 02:06 PM   #10
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
what's the PN
pics?
so basically it's same as spec c crank, only 79mm?
Old 03-25-2009, 02:18 PM   #11
Pita84
Member#: 193644
2002 WRX Wagon
that is the new 400 number?
Old 03-25-2009, 02:20 PM   #12
andya
Member#: 200134
#12200AA400. Beside each other, the look identical outside of the finish. I won't know all the changes till I remove them from my Holy Shrine and send them to the machine shop.
Old 03-25-2009, 02:21 PM   #13
Pita84
Member#: 193644
2002 WRX Wagon
when i started the thread there were 5 in stock.. now i shook to much interest.. they are out of stock!!
same thrust?
Old 03-25-2009, 02:38 PM   #14
Homemade WRX
Member#: 33782
96 bastard child
this does make me wonder about the main journals. Andy, can you snap some pics for us?
I'd order the crank but they seem to be out of stock already...same thing happened when I first posted about the revised EJ205 cranks with the double crossdrilled/altered oil timing main journals
Old 03-25-2009, 03:29 PM   #15
andya
Member#: 200134
I'll get Ben to handle the pics and post for us.
As far as the finish on the crank, it seems darker than the usual nitride finish... almost as though some carbon dioxide was introduced as well in the process. A surface hardness test will tell for sure.
Old 03-25-2009, 05:59 PM   #16
Pita84
Member#: 193644
2002 WRX Wagon
when do you think you will have the results on the test?
Old 03-25-2009, 06:13 PM   #17
andya
Member#: 200134
Ill drop one off in the morning and depending on the work-load, hopefully by lunch I should have the results.
There were 40 in the warehouse when I made my order last week and today there was 1 in the New Hampshire depot... Strange..
Old 03-25-2009, 09:54 PM   #18
benw
Member#: 103320
1998 swapped
Forester L
Here are the pictures I took for Andy. Note the numbers on the new cranks (these pics include a used previous crank for comparison)
benw is offline   Reply With Quote
Old 03-26-2009, 09:45 AM   #19
andya
Member#: 200134
Thanks BEN... Note all the mains are A's and the rods are I's.
Seems that only the top spec cranks are processed.
Old 03-26-2009, 10:14 AM   #20
Pita84
Member#: 193644
2002 WRX Wagon
weird there were 5 when i first put the post.. then two days ago none.. they must have gotten stock just in time. Good deal.
Old 03-26-2009, 04:55 PM   #21
Pita84
Member#: 193644
2002 WRX Wagon
anything on tests? yesterday there was one.. and i guess i missed the order. someone else got it...............
Old 03-27-2009, 01:11 PM   #22
andya
Member#: 200134
The results are in....
Rockwell C scale
Stock crank 20.... New crank 32
Brinell scale
Stock 220..... New 294-301
Chemical test showed thorough nitriding, and no discoloration after 30 seconds. The stock crank showed instant reaction to chemical.
The dark finish is due to the temp and duration of processing for a deeper hardness which is even more than the Crower race cranks!
The machinist was impressed with the quality... especially for a factory supplied part.
Old 03-27-2009, 05:53 PM   #23
Pita84
Member#: 193644
2002 WRX Wagon
re the new rods the same way? i hear forged pistons also? Mine is on a plane from japan as we speak
Old 03-27-2009, 06:35 PM   #24
andya
Member#: 200134
I have not had the pleasure of going inside a late 08 yet, so I have no clue about the rods or pistons. It would probably be less expensive to go with aftermarket instead if those components were needed. Can't beat the price of the crank though!
Old 03-27-2009, 10:53 PM   #25
Pita84
Member#: 193644
2002 WRX Wagon
I agree, was just wondering.
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 02:32 PM
crankshaft questions Prevent Built Motor Discussion 14 10-14-2009 12:41 PM
Crankshaft questions Pita84 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-15-2009 11:09 AM
crankshaft questions seanathanq83 Built Motor Discussion 7 02-26-2009 05:26 PM
Crankshaft question clsmooth Normally Aspirated with bolt-on Forced Induction Powertrain 1 04-02-2008 07:24 PM
