Old 03-15-2009, 03:42 PM   #1
Flat4Fixation
Member#: 196898
1990 Legacy
Sandstone metallic/Black
Post 2.5 swap
Looking to swap in 2.5 into my 1990 legacy. Just want to swap the block nd use my 2.2 heads.intake manifold and sensors for ease of swap. alread calculated compression ratio to 10.1-1 to 10.5-1 depending on gasket thickness. Any known complications waith this? Have all parts. Any idea on how this will run? Or do i need a piggyback for sure? Dont see why this shouldn't work
Flat4Fixation is offline   Reply With Quote
Old 03-15-2009, 06:32 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
There is a very informative thread describing this very swap. It's titled "Hi compression frankenstein"..... I thought it was a sticky....but I guess since it doesn't involve turbos....it isn't worthy. Yay nasioc.....
Jay
Old 03-15-2009, 11:54 PM   #3
Flat4Fixation
Member#: 196898
1990 Legacy
I have all these parts so its free, just want to know how it would run
Old 03-17-2009, 05:23 PM   #4
mellow65
Member#: 83350
Too Many
if i remember right the CR was higher then that. but regardless you will be needing to run super to keep the ping fairys away.
i thought of going this route and decided to keep the whole phase 2 ej25 in my 90 legacy.
i'm running stock everything for a 2.2. runs great, is pretty dang quick. i highly recommend the swap to anyone. only down side, not having a working IAC.
but if you got a 1.8 TB you could have one because the IAC is mounted on the TB and not on the intake like the 2.2.
my write up. not a step by step, but it shows some of the things i had to do.
http://www.ultimatesubaru.org/forum/...ad.php?t=83839
mellow65 is offline   Reply With Quote
Non-STI 2.5 swap vs. 2.0 swap? anon_az Subaru Conversions 6 03-20-2010 12:33 PM
bit confused on 2.2 to 2.5 swap Mk3Design Subaru Conversions 7 03-04-2007 11:51 AM
2.2 or 2.5 swap cindergarden Normally Aspirated Powertrain 3 09-25-2002 04:12 PM
2.2 - 2.5 swap 97 impreza wagon MC Racing Normally Aspirated Powertrain 7 04-24-2002 06:55 PM
97 impreza l wagon 2.2- 2.5 swap clutch questions MC Racing Transmission (AT/MT) & Driveline 1 04-24-2002 01:47 PM
