03-15-2009, 08:58 PM | #1 |
Member#: 186893
South East
Vehicle:2004 WRX SILVER |
Dip stick issue
Got my new 2.0 running and installed the APS header, they said to switch to a STI oil pan so the header would fit, now when I check the oil it does not read on the dipstick! I got the new pan, pick up and dip stick from Subaru and had them check my order and said it is correct, anyone installed the APS header and have the same problem? Thanks
03-15-2009, 09:01 PM | #2 |
Member#: 186893
South East
Ignore post
found post on here, sorry!
03-15-2009, 09:09 PM | #3 |
Member#: 186893
South East
Well post did not help
Still need answers if anyones knows, thanks
03-15-2009, 11:24 PM | #4 |
Member#: 173241
TXIC
Vehicle:2002 s256 twinscroll now with one more gear |
if you got the sti dip stick it should read fine, if you have a wrx, it will read like its at the lowest level, if you dont get anything, then you dont have anything in the pan, all it is is a stick that goes into the oil, unless you mixed somthing up somewhere
03-16-2009, 08:37 AM | #5 | |
Member#: 186893
South East
Hey pal
03-16-2009, 04:59 PM | #6 |
Member#: 118239
SCIC
Vehicle:2002 Built Wagon Wife- 2004 Outback SE |
Sounds like the wrong stick man
03-16-2009, 07:36 PM | #7 |
Member#: 182227
NWIC
Vehicle:2000 MPS Built RS 1991 Leggy Turbo EJ22t |
Wrong stick. STI oil pan is a necessary mod for EL headers.
03-17-2009, 03:56 PM | #8 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Does your dip stick have a hole that you can loop your finger through to pull it out? If so, it is the 2.5L dip stick. If not, you have the 2.0L stick.
03-17-2009, 04:27 PM | #9 | |
Member#: 186893
South East
Bro
That right there is the info I need, they (Subaru) sold me a dipstick that does not have the hole to pull it out!!!! Thanks again, I am going up there this week to get them to get me the right one! |
MT - 3.7Qts dip stick reads overfill | DucatiBoy | Transmission (AT/MT) & Driveline | 3 | 03-23-2003 10:56 PM |
MT dip stick | Mammoth | Transmission (AT/MT) & Driveline | 4 | 09-29-2002 08:36 PM |
Noise from the dip stick, please check. | milkman | Normally Aspirated Powertrain | 6 | 06-02-2002 01:16 PM |
Manual Transmission Dip Stick Location? | STORER | Transmission (AT/MT) & Driveline | 3 | 10-29-2001 12:19 AM |
Dip Stick Accuracy???? | PunksRS | Technical Forum Archive | 2 | 09-25-2000 12:11 AM |
