Old 03-15-2009, 09:38 PM   #1
Ltobesti
Member#: 93737
Chapter/Region: PRSIC
1993 L
Exclamation Cable operated clutch question
I recently swapped all of the drivetrain and engine from a 98 RS to a fwd 93 L, In order to continue using the cable operated clutch i need to know what awd clutch release fork(CABLE TYPE) I have to use because the one that came from the RS is for hydraulic. I used for some time the fwd fork but because of its design it doesn't push the clutch enough and the feeling is very heavy. I just want to know which was the last year that cable clutches were used. I believe it was 97 2.2L equipped cars but I want to make sure.
Thanks in advance
Ltobesti is offline   Reply With Quote
Old 03-15-2009, 10:22 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
You can keep the fork, I suspect you didn't move the pivot ball to the other hole. Try that first.
98 EJ22 (OBS) still had a cable clutch.
Jay
Old 03-16-2009, 12:48 PM   #3
Ltobesti
Member#: 93737
1993 L
Yes, I did move the pivot ball. It seems that the fwd fork is being stopped by the tranny housing because it is curved
Old 03-16-2009, 04:52 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Oh yeah....I just looked at a couple forks I have in the garage. Hmmmm....that is odd that they changed the shape like that. I have a 98 fork that is curved, but I have substantial welding boogers to clean out of the pivot pocket......
Jay
Old 03-18-2009, 12:13 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
why didnt you swap the hydraulic set up and pedal set from the RS?
Old 03-18-2009, 03:25 PM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
It isn't much benefit over the cable setup (opinion mode off). If it were me in this situation, I'd open the window on the trans to allow the fork full range of motion, and be done with it.
Jay
Old 03-19-2009, 08:16 AM   #7
parkes
Member#: 166898
1994 T leg SS
ABM
You have to drill a hole in the hyrdraulic fork so you can get the cable through, then your good to go however it has the cable has to stretch quite a bit so the you have to use eight million ton of force to move the pedal, but it works!!!
parkes is offline   Reply With Quote
Old 03-19-2009, 08:46 PM   #8
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
It's still going to be a heavy clutch no matter what you do. The 2.5l uses a stronger spring in the pressure plate and therefore uses hydraulic actuation to make the pedal feel lighter.
yamarocket630 is offline   Reply With Quote
Old 03-20-2009, 08:05 AM   #9
Slack
Member#: 17548
If you think that's stiff, you should try an ACT pressure plate. I have literally bruised my foot driving my car in heavy traffic.
Slack is offline   Reply With Quote
Old 03-25-2009, 07:48 PM   #10
Ltobesti
Member#: 93737
1993 L
FIXED!!!
I found out that the fwd fork was all cracked when I pulled the tranny out. I drilled the fork that came with it and it is working fine. I'm using a clutchmasters stage 1 kit, its a little heavy but fine.
Now I'm looking for the A/C compressor clutch.
Sorry for not introducing myself properly.
Here is a picture of my car:
Here are the mods so far:
Converted to AWD from a 2000 RS
2.5 DOHC from a 1998 RS
1998 RS Gold Wheels
Pink Sti Struts & Springs
Front 4 pot calipers with Ferodo pads
Rear Legacy vented discs
Braided Brake lines
JDM Sti Gauge cluster
WRX 2002 Seats
Old 07-28-2009, 12:00 AM   #11
greddy18
Member#: 112680
2000 Impreza L
Acadia Green
I think I am going to be doing this tomorrow..
greddy18 is offline   Reply With Quote
Old 07-28-2009, 08:07 PM   #12
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Originally Posted by Ltobesti View Post
FIXED!!!
Glad you got the shift fork issue resolved. I was going to suggest a '98L fork, but you got it fixed. As for the A/C clutch, I don't think they sell the clutch separate from the compressor. I noticed my '98L A/C clutch going out and all I could find in the part system was the entire compressor...no separate part number for the clutch.
beaviscih is offline   Reply With Quote
Old 07-29-2009, 01:11 PM   #13
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
was your RS clutch pivot point longer than your L pivot point ?
I'm doing an 05 LGT tranny right now into an 00 Impreza L with a cable clutch. And I can't figure out which pivot point to use. The L pivot point is longer, and would move the fork away from the tranny a little bit.
whata u guys think ?
I plan to drill the LGT fork and go with that.... now just to decide on the pivot point.
IllNastyImpreza is offline   Reply With Quote
Old 07-29-2009, 01:41 PM   #14
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Jay
+2 on the groove...just cut back the housing a little bit and be done with it.
I actually preffer the cable feel but am hydro because of the 6-spd...though a conversion back to clutch would be nice; shave some weight, open up room in the engine bay and simplify the system. With the twin plate however, my left leg would become ginormous
Old 07-29-2009, 02:43 PM   #15
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
what do you mean cut back the housing ? what are you achieving with this ?
Old 07-29-2009, 10:03 PM   #16
Storm
Member#: 5218
96L Most Over-
Developed Beater
"porting" the window that the fork sticks out of.....as in, making it bigger, like, so the fork will move all the way.
Jay
Old 07-30-2009, 10:44 AM   #17
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
ah ok cool. anyone done this ? how does this effect your pedal ?
Old 07-01-2014, 04:28 PM   #18
Ltobesti
Member#: 93737
1993 L
Laaaate update.... Swapped the cable setup to hydraulic, snapped 2 clutch cables in less than a year!!!
Old 07-01-2014, 04:33 PM   #19
bobblehead230
Member#: 321543
2012 wrx
pasmabluepearl
oh well thatll happen!
at least youre still driving the car after 6yrs (at least since this thread was last updated)
edit: 5yrs, i shouldnt be this drunk at work
bobblehead230 is offline   Reply With Quote
WTB WRX cable operated Throttle body ljaviation Private 'Wanted' Classifieds 4 05-11-2008 11:24 PM
Heaviest duty clutch for a cable operated 5spd? wrxsubaru Transmission (AT/MT) & Driveline 4 03-11-2008 03:08 AM
Operating system question Clarkson.is.God Off-Topic 2 06-20-2007 09:54 PM
Cable vs hydro clutch questions kingbobdole Transmission (AT/MT) & Driveline 1 12-19-2006 07:42 AM
Cable Clutch Question yebokmj Transmission (AT/MT) & Driveline 1 08-28-2004 08:43 AM
