Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 03-15-2009, 10:46 PM   #1
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
Default piknockout's STU Autocross Build - 2006 STi sponsored by Agile Auto
Sponsored by Agile Automotive Performance in Fallston, MD
For those that don't know me, my name is Josh and I'm planning on using this thread to document my STU autocross build as well as my progress throughout the season including setups and changes. To start things off, I would like to give a BIG THANKS to Hill McCarty at Agile Auto for his support and help in this build, along with all the help in the past!
Now for a little background. I've been autocrossing now going on 5 years, with all of my previous experience coming from building my 2003 Nissan Sentra SE-R Spec V that I built for STX. Although the car wasn't the prime choice for the class, I was able to win STX for Philly Region in 2006, WDCR Region in 2007/2008, and Autocrosser's Inc. in 2007/2008.
After driving the car for 5 years, I knew it was time to get into a car better suited for it's class. I sold the car in August 2008 and spent the next few months doing some co-drives to figure out what best fit my wants/needs. A special thanks to John W. (ButtDyno) for letting me co-drive the WRX to finish out the WDCR STX season! But after driving Iman's (bdi) STU prepped STi, I knew exactly what car I wanted to buy and what class I wanted to run in. I've enjoyed the ST* class and knew that it was the right fit for me.
Through research gained here and conversations with several great STU drivers (Thanks Colin, James, Iman, JR, John W, and anyone else I left out!) I decided that a 2006 STi was going to be tool of choice. I searched through the classifieds on here, IWSTI, autotrader.com, eBay, etc. for about a month before I found what seemed to be the right car. It was a 2006 Aspen White STi with only 17,300 miles, a 3.5" APS exhaust, COBB short ram intake, and Accessport with Stage 2 tune. And to make it even better, the guy only lived 25 minutes away. A couple of weeks of pricing negotiations and the car was mine on November 21st!
The car shortly after purchase
The old autocross ride
Needless to say, the next 4 months were hell. Having this beauty sitting in the garage, doing research, dealing with snow and cold...just painful. Fortunately all that ended last Sunday when I began the autocross modification process.
Through yesterday I had installed the following modifications (it's been a busy week!):
- APS 3.5" turbo back exhaust with MIL.SPEC 100 cell race cat welded into downpipe by Agile Auto
piknockout is offline   Reply With Quote
Old 03-15-2009, 10:48 PM   #2
piknockout
Member#: 192173
- Hawk HP+ brake pads
- Braille 6lbs race battery
- Re-installed stock intake to replace COBB short ram to reduce intake air temp during summer events
- Corbeau 3 pt. Harness (autocross use only)
- Rolled front part of rear fenders
- Whiteline 24mm adjustable front sway bar with Whiteline spherical endlinks
Midway through the work
Old 03-15-2009, 10:48 PM   #3
piknockout
Member#: 192173
- Whiteline 22mm adjustable rear sway bar with Whiteline spherical endlinks
- Racecomp Engineering Tarmac 2 coilovers with 600lbs front springs and 500lbs rear springs topped with Vorshlag camber plates set at Racecomp suggested Track settings (Thanks Myles for the discussion and help!)
After the installs (before alignment and fixing front ride height...at 2am)
Test fitting some borrowed 17x9 et35 RE30's (before alignment and fixing front ride height at 1:30am)
- Ported stock headers by Agile Auto (no pics...forgot the camera)
- STU Protune by Hill at Agile Auto...318whp/318wtq (I know, kind of high...dyno chart to follow) along with a street tune 325whp/350wtq
Old 03-15-2009, 10:49 PM   #4
piknockout
Member#: 192173
STU tune on top, Street tune below.
And a few other things
- Alignment set at -3.2 front camber and -1.9 rear camber with zero toe for both
- Ordered 5Zigen FN01RC's 17x9 et43 in flat black
- Deciding between 245/40/17 Bridestone RE-11's or Kumho XS's
Where the car currently sits as of 3/14/09
First test day is this coming weekend on March 22nd with the Philly Region, followed by the WDCR practice event on March 29th. I'll either be running the borrowed RE30's with Dunlops, or if I make a tire decision tomorrow I should have that setup by the weekend. We'll see what happens. I don't know how everything will work first time out, but it should be interesting. Iman (bdi) will be co-driving with me this coming weekend to help work on the setup a little bit.
My plans for the season are to run a full WDCR schedule, Fed Ex Field events with Autocrosser's Inc, Citzen's Bank Park events with the Philly Region, the DC Pro (and hopefully Toledo, but doubtful), either the Seneca Tour or NE Divisional, and Nationals in Lincoln, NE.
Old 03-15-2009, 10:50 PM   #5
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
you're slow! i figure you'll be doing scca and ainc, but what about cdc?
Old 03-15-2009, 10:53 PM   #6
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Rock and roll Josh! See you next Sunday. Whats the time frame for coilovers?
S1MPSONS is offline   Reply With Quote
Old 03-15-2009, 11:05 PM   #7
piknockout
Member#: 192173
Time frame for coilovers...they're installed! I probably hadn't updated the reserved sections when you posted.
Probably no CDC, too much of a drive. I may hit up some Susquehannah events though, we'll see how things work out.
Old 03-15-2009, 11:12 PM   #8
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
how much is that wdcr practice event? is it open to guests? i'd like to expand on my autox events. if it is, you could borrow my wheel/tire setup
Old 03-15-2009, 11:25 PM   #9
ButtDyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Don't forget the anti jersey barrier forcefield.
Hopefully I'll be able to go to CBP on the 22nd
ButtDyno is offline   Reply With Quote
Old 03-16-2009, 12:57 AM   #10
SpeedTheory
Member#: 152510
The debate should really be between RE-11s and R1Rs....I'm surprised the XSs are considered a player anymore.
SpeedTheory is offline   Reply With Quote
Old 03-16-2009, 03:02 AM   #11
alltracin
Member#: 100265
1999 powered '90
Miata
XSs were running competitive times in Dixie this weekend. John ran times both days on them that were right with the top of the class.
I drove a car with the exact same coilover/plate setup this weekend...once we tuned out pressures etc a little bit, they were pretty fantastic. They rode REALLY well on the 9+ hour drive, too!
Beware the whiteline endlinks...that's what Karen broke on my car at the DC pro two years ago Luckily they were warrantied.
alltracin is offline   Reply With Quote
Old 03-16-2009, 08:22 AM   #12
mla163
Member#: 104922
2013 BRZ
looks good josh, see you out there
mla163 is offline   Reply With Quote
Old 03-16-2009, 08:49 AM   #13
mla163
Member#: 104922
2013 BRZ
The practice is members only. It's not too late to get a membership though.
Old 03-16-2009, 09:10 AM   #14
bdi
Member#: 66033
05 STi
Are you for real?
Looks good Josh but it needs more stickers...
bdi is offline   Reply With Quote
Old 03-16-2009, 09:56 AM   #15
piknockout
Member#: 192173
I should have some pics in full livery this weekend with stickers and all, thanks guys!
And also a on the R1R. While they may work well for light ST Civics in cool weather, not sure I want to go that route mid-summer on a heavy AWD car...although Jake is trying to prove us all wrong!
As alltracin said, they were running competitive times on the XS this past weekend.
And I'll keep an eye on those endlinks, thanks for the head's up.
I installed that permanently after the last "incident".
Old 03-16-2009, 10:03 AM   #16
wrx wagone
Member#: 97301
2005 WRX Wag-Tow Rig
95 FM - QRE Invader
+1
I'll see you out at CBP in a week.
wrx wagone is offline   Reply With Quote
Old 03-16-2009, 11:24 AM   #17
Crashmaxx
Member#: 94028
2010 Mazda Miata
Sweet setup, man. I'll keep an eye out for you this weekend at CBP.
Crashmaxx is offline   Reply With Quote
Old 03-16-2009, 11:55 AM   #18
Chiketkd
Member#: 71634
In hibernation...
'bout time you started this thread. Nice build thus far!!!
Chiketkd is offline   Reply With Quote
Old 03-16-2009, 12:03 PM   #19
piknockout
Member#: 192173
Thanks Chike...just call me lazy. Not to mention I wanted to get all the pictures taken before I posted anything up. Didn't want to post it up and have it sit for a couple of months where it's just a stock car.
I think I'm going to be on Dunlops this Sunday (thanks Iman!) and see what the car does on a known tire...as well as buy a little bit more time to figure out what I want to do. I think the RE-11 is the safe choice, but an expensive one. I'm hoping the Kumho is up to par though to save a bit of money. Then again against all the competition in DC/Philly, I'm going to need every tenth I can get.
Old 03-16-2009, 12:17 PM   #20
ButtDyno
Member#: 17301
is the "dark side"
I think I have to move my thread from Project Cars to here...
Old 03-16-2009, 12:22 PM   #21
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
^I'll be interested to see you guys' time on the Dunlops. I'm surprised they weren't mentioned earlier in the thread. Looks like a nice build - see you Sunday.
Weather is looking pretty good!
Mind is offline   Reply With Quote
Old 03-16-2009, 12:30 PM   #22
piknockout
Member#: 192173
Looks like 60 degrees and partly cloudy...another 10 degrees or so and it would be perfect! I haven't completely ruled out the Dunlop, but some preliminary testing over on sccaforums.com along with feedback from Wiggy seems to indicate that the Kumho should be a little better than the Dunlop and they're the same price.
Don't expect much on Sunday though. When you toss a whole bunch of suspension parts on the car at one time, you never know what they're going to do. But it "should" be in the ballpark at least...I hope.
Old 03-16-2009, 01:05 PM   #23
Stizmm
Member#: 202301
coilovers corner-weighted?
Stizmm is offline   Reply With Quote
Old 03-16-2009, 01:20 PM   #24
piknockout
Member#: 192173
They will be in a couple of weeks. Going to take it by Agile Auto after the next couple of events to give the setup time to settle a little bit.
Old 03-16-2009, 01:39 PM   #25
Stizmm
Member#: 202301
If the springs are going to sag, then you may as well throw them away. Get yourself a set of proper HyperCo Springs.
The Corner-weighting will throw the alignment off, and the alignment will throw the corner-weighting off a bit as well. The best route is to find a place to corner-weight and align all at the same time.
2006 STi Stage 2 Agile Auto Protune Results AlxSti Proven Power Bragging 229 01-24-2013 12:49 PM
FS: 2005 AW STI Built by Agile Auto stimania Private Vehicle 'For Sale' Classifieds 3 03-31-2010 11:24 AM
05 STi - GT52 Tuned by Agile Auto boost junkie Proven Power Bragging 28 02-26-2008 11:20 PM
Message Board Statistics All times are GMT -4. The time now is 03:32 AM.
