Old 04-12-2002, 06:41 AM   #1
redoktober_99
Member#: 17430
Sedona Red Pearl
Default 1st Gear and Reverse Problems
Has anyone experienced the following?
With the clutch down to the floor.
Shifting from N to first or reverse, there are times when the transmission will not shift into gear or will require a great deal of force to get it into gear.
Also I experienced this once.
Also with the clutch to the floor, shifting into reverse, I got that "grinding" sound and had to press the clutch again to get it to shift.
redoktober_99 is offline   Reply With Quote
Old 04-12-2002, 06:58 AM   #2
z&cobb
Member#: 12344
2002 2JC
blue
Default Re: 1st Gear and Reverse Problems
Does it happen when the car is cold? Anyway, don't force it. Push the clutch in again and try again. If that doesn't work put it in the opposite gear, say first, then push the clutch again and put it in the gear you want, say reverse. If you have do this a lot then something is wrong with the synchros. I get this sometimes on my 300ZX with 280,000 miles and on my new WRX, but I never force a noisy shift.
z&cobb is offline   Reply With Quote
Old 04-12-2002, 07:53 PM   #3
stikboy
Member#: 6697
2011 WRX 5-door
Look-At-Me Red
Default no worries
this is typical of our cars. just don't force it and try it again. if it happens 50 percent of the time, get your car looked at.
stikboy
stikboy is offline   Reply With Quote
Old 04-14-2002, 11:11 AM   #4
MAGMORE
Member#: 16146
SILVER
Default what i have learned
I have heard that the first production run of the WRX had a few issues with the first gear thing and that soa has taken care of them .
I have a newer silver wagon and although i sometimes have to double clutch to get it to go into reverse i hae not had any problems with first.
I think there is a rather long thread about this in the warrranty thread.
MAGMORE is offline   Reply With Quote
Old 04-15-2002, 05:25 AM   #5
secretaznboy
Member#: 16666
2002 WRX!
MidNiGhT bLaCk
Default common problem...sad..but true
THis is a common problem amoung wrx.
i just got my wrx less than a month ago...
i have had the reverse grinding noise...and sometimes...the car won't go into first even after the car is warmed up.
it is a problem with the synchros...SOA should take care of it.
it doesn't happen too often with me...ill get it checked with my next oil change.
secretaznboy is offline   Reply With Quote
Old 04-17-2002, 06:38 AM   #6
redoktober_99
Member#: 17430
Sedona Red Pearl
Thanks to all for your updates, here is what the service guy at my Subaru dealer told me.
He knows about the problem and each time you bring in the car for service mentoin it to the service manager. That way he knows it is a continued problem and if there is a service bulletin he can tell you.
He also showed me on his own WRX, it has the same problem.
Also you can go onto my.subaru.com and log the problem and keep updates on your car.
WTB: Tranny parts, 1st gear and 1st gear synchro or straight cut 1st, 2nd. boycelaforest Private 'Wanted' Classifieds 0 03-01-2010 04:14 PM
Flat 1st gear and best gear oil questions. vatorn10 Transmission (AT/MT) & Driveline 5 09-26-2006 09:08 PM
Grinding in 2nd gear, 4th gear, and reverse Blizwinter Transmission (AT/MT) & Driveline 5 06-08-2004 04:12 PM
1st gear holding back....problem? avalanche165 Factory 2.0L Turbo Powertrain 13 12-26-2001 03:34 PM
1st gear down shift problem? hayscoob Normally Aspirated Powertrain 13 03-06-2001 01:32 PM
Message Board Statistics All times are GMT -4. The time now is 11:36 PM.
