Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-16-2009, 06:23 AM   #1
subeman90
Member#: 65681
13 XV Limited
gray
Default what diff gears do we have in our baja's?
I have been in a discussion with someone about what our rear diff ratio is. Does anyone know? I am under belief that it is 4.44 b/c my baja just screams at high speed. I was also told that it is a different tranny then the turbo baja. I am talking about 5 speed trannys here not the automatics. Anyone know the answer to this?
subeman90 is offline   Reply With Quote
Old 03-16-2009, 11:07 AM   #2
weiVA
Member#: 72942
2005 Baja T
Atl Blue Pearl
I had an old thread here but that was mostly for autos. Hopefully this thread on Scoobytruck may be useful to you.
weiVA is offline   Reply With Quote
Old 03-16-2009, 04:11 PM   #3
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
Silver 340 AWHP 365 AWTQ
5 Speed Bajas are 4.44s. I am 100% sure. I had 5 teeth shear off the front ring gear (overboost / fuel cut / 5th gear/ 106 mph. it was scary) When the trans was open I counted the teeth on what was left of the ring and pinion gears and calculated the ratio. 4.44 I have the ring gear on my wall of shame in the garage along with several stripped 2nd gears, parts to the center diff plus a chunk of my old jeeps transfer case and a few u joints.
Subie_Sleeper68 is offline   Reply With Quote
Old 03-16-2009, 09:05 PM   #4
subeman90
Member#: 65681
13 XV Limited
gray
but yours is a turbo. I have a non turbo. Can you look it up since you work at the dealer. I need 100% proof here.
<---what the heck is that thing
Old 03-17-2009, 11:11 AM   #5
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
I'm at work now. The ratio is the same.
Old 03-17-2009, 12:05 PM   #6
subeman90
Member#: 65681
13 XV Limited
gray
thanks a lot!!!!!!!!!!
what choices do we have in dry panel filters? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 09-16-2008 05:00 PM
What KW Vendors do we have in Central NJ? All Star Diaries Tri-State Area Forum 0 05-03-2008 10:20 PM
What FSAE teams do we have represented in the mid-a M Mid Atlantic Impreza Club -- MAIC 25 12-25-2005 12:42 PM
What kind of coilovers do we have on our cars? Gruppe-S Suspension/Brakes/Handling 9 07-20-2005 04:31 PM
What Kind of Exhausts Or Turbobacks Do We Have In Chicago? Red Rexx Mid West Subaru Owners Club Forum -- MWSOC 8 12-11-2004 07:38 PM
