Old 03-16-2009, 10:57 AM   #1
zacxzx
Member#: 201281
2006 Scion tC
Default Everything you need to know about a Cutout?
hey i have a subaru sti with a stock exhaust system. i was wondering where i can buy a cut out for it.
-how much faster will i be?
-is it better than getting a (nice) new exhuast?
-how do you install it?
-any one have pictures?
Also im looking at on electric one
Thanks
-Zach
zacxzx is offline   Reply With Quote
Old 03-16-2009, 11:03 AM   #2
Uncanny
Member#: 133012
2015 STi
Lightning Red
A cut out will only alleviate any backpressure created by the catback section of the exhaust, you still have two cats in your downpipe that you are flowing through - and those create most of the backpressure in the system. The biggest thing you will notice will be noise.
Electric cutouts have also been known to leak over time as the seal wears.
Installation requires welding in a flange for the cutout, so you will want to have a shop do it, unless youre good at welding.
Personally, I am not a fan of cutouts.
Uncanny is offline   Reply With Quote
Old 03-16-2009, 11:10 AM   #3
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Everything said here, is true.
With the stock downpipe in place, you are looking at next to no power, for a lot of noise. Seriously 3-5whp at best.
Defiant Autospeed is offline   Reply With Quote
Old 03-16-2009, 11:22 AM   #4
zacxzx
Member#: 201281
2006 Scion tC
what about if i had an intake, boost controller and a tune. what would i be getting ?
Old 03-16-2009, 11:23 AM   #5
smurfwrx
Member#: 151928
09 Triumph S3
smurfwrx is offline   Reply With Quote
Old 03-16-2009, 11:27 AM   #6
Uncanny
Member#: 133012
2015 STi
Lightning Red
With still having cats in your downpipe, not much. Intake wont get you but a few horses unless its tuned for it. A tune would still be very mild, considered "Stage I" as you still have your stock downpipe. Like stated previously, a cutout won't alleviate much backpressure on a stock exhaust/downpipe.
As dave/defiant mentioned, you'll gain 5whp, maybe. If you tune, this number will be the same regardless of a cutout or not.
What you should really be looking at is replacing your downpipe. For the same money, you can do that, and then you'll open new sets of doors performance wise.
Old 03-16-2009, 11:31 AM   #7
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Next to nothing. The problem with the factory post turbo exh is that there are 2 cats, in a very restrictive pipe, before the catback section. If you are pushing things a bit harder at stage 1, you may get 1-2whp more than if you were stock+cutout. You are still looking at 6-7WHP at best. You can buy an HKS downpipe for less money, and get a LOT more as far as gains. Depending how much the cutout you are looking at will cost, plus the labor charges to install it, you may come out far ahead with any of several downpipes.
Old 03-16-2009, 11:32 AM   #8
zacxzx
Member#: 201281
2006 Scion tC
well my friend has an evo and he told me maybe i should get an intake , boost controllers , and a cutout , he said he would tune it and said i would be runing 12.5 in a 1/4 mile. since i have a sti do you think this will work??
Old 03-16-2009, 11:34 AM   #9
Uncanny
Member#: 133012
2015 STi
Lightning Red
Evos are NOTHING like STi's. NO. NO. NO. NO. NO.
Stop asking questions, and read Unabomber's Manifesto on the top of the Newbie Forum.
Old 03-16-2009, 11:35 AM   #10
zacxzx
Member#: 201281
2006 Scion tC
well then can you help me run a 12.5 for less than 600 to 700 dollars
Old 03-16-2009, 11:36 AM   #11
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Yes. Easily. Unfortunately for me, it means I cant you any of the parts, but its not hard to do.
I can tell you that the mod list your buddy suggested will get you, at best, .2 maybe .3 in the 1/4. Nowhere near >12.5
Old 03-16-2009, 11:37 AM   #12
zacxzx
Member#: 201281
2006 Scion tC
Originally Posted by Defiant Autospeed View Post
Yes. Easily.
What would i need to buy and do..
Old 03-16-2009, 11:38 AM   #13
Uncanny
Member#: 133012
2015 STi
Lightning Red
Very easily. Used Downpipe: 200-250, used Catback: 300, Opensource Stage II Map: 100+
Old 03-16-2009, 11:38 AM   #14
Uncanny
Member#: 133012
2015 STi
Lightning Red
We aren't going to hold your hand through this. You need to read through Unabomber's Manifesto, all of the FAQ's regarding exhaust, engine management, and power modifications.
Old 03-16-2009, 11:40 AM   #15
Uncanny
Member#: 133012
2015 STi
Lightning Red
Here: http://forums.nasioc.com/forums/showthread.php?t=533787
Read this. Come back when you have questions on the things you've read. It should take you a good few days to get through half of the things you should read. You need to be EDUCATED on a subject before you start modifying. For the sake of you, your wallet, and your car.
Old 03-16-2009, 11:41 AM   #16
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I can get it even cheaper.
used HKS downpipe ---$75-100
Open source stage 2 reflash --$depends. Good custom tune with OS is usually about $300
dump 2gallons of methanol into the gas tank. Give the car a little time to get used to it. This isnt for more power, and you dont need special tuning for it, as 2 gallons will only net a small octane increase, BUT, you will get maxed out ignition advance multipliers, and you wont hit a spot of det that will pull them down. Good for 5-8whp (somewhere about that) over straight pump gas, with no additional tuning.
practice. Practice a LOT. 04-05 STIs will run 12.9 BONE STOCK with a great driver. The 06-07 is only slightly slower, and with tuning and that downpipe, its going to be essentially the same as the 04-05.
I have a buddy that knows how to tune, and knows how to drive, he is running faster than 12.5 for under $150 total.
used HKS Downpipe --$50
home depot home made MBC about$5
open source tune $free. Did it himself
Used TurboXS short ram intake $50
Home made heatsheild for intake $10 in sheet metal from home depot
Old 03-16-2009, 11:51 AM   #17
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You could outfit your car with two Veyron engines, you could still run a 14.5. Quarter mile times are terribly variable as it depends more on YOU than your car. And we have no idea what year your car is. Fill out your profile as a 2006 Scion tC doesn't really help us on the Subaru forums. Years make a difference as to recommendations. I suggest you PM Defiant Autospeed and handle this all offline as he will do you right.
Old 03-16-2009, 12:05 PM   #18
smurfwrx
Member#: 151928
09 Triumph S3
+1 for Defiant. WORST salesman EVAR! He tells you how he'd go about it and save money rather than try to get you to buy the most expensive stuff.
Old 03-16-2009, 12:13 PM   #19
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I know
What really annoys me is how much I push Blouch (because other than a few $$$ brands like ATP and such) and yet I cant get a good wholesale source so I can sell them Same with Samco and Kartboy (although Tom said I should email him about it, I just havent gotten around to it yet.)
Old 03-16-2009, 12:16 PM   #20
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
+1 for driver.
Put me in an STI
Then put a GOOD driver in the same STI
The other guy will run .4 (at LEAST) faster than my time
And sadly, for some reason the average Subbie driver is even worse than me.
Oh, and thank you Ron
Old 03-16-2009, 12:45 PM   #21
drdabbles
Member#: 110229
2004 WRX STi
Java Black
To sum up the sentiment here, and even the FAQs / Manifesto... research before you ask questions. There is a TON of information here, but you need to look for it. And yes, we all start out by asking questions, getting spanked, feeling butthurt, and then reading all the info out there. Then, we start giving sage advice like "Search, n00b!".
Tuning Subarus is not like tuning an evo, or a honda, or whatever the cool kids drive these days. Upgrading your intake before upgrading your exhaust is a waste of time and money.
Start with things that relieve back-pressure on the turbo (like a full turbo-back exhaust). This will require a tune. Then you get to say "I'm runnin' t3h stage thr33zor!"
At this point, take some driving lessons. I'm not talking about your local defensive driving course, either (though, that won't hurt). Go to some track days and get someone to show you the ropes. You're not Sebastian Loeb and you're not Lewis Hamilton. Learning how to better handle your car will make you a faster and technically better driver all around.
Next, work on things that restrict flow from the exhaust ports to the hot side of the turbo- up-pipe, porting and polishing, etc. Now would be a great time for a custom tune!
Suspension- These mods WILL enhance your car's performance. A well crafted suspension package will help your car corner better, which will allow you to apply power in more aggressive ways. You should take more driving lessons now. A lot more. You're officially driving a fast car that will eat up the miles on your local track. Learn to drive it properly, and you'll get to enjoy everything the car has to offer you.
Now, look into things restricting flow on the cold side of the turbo. You're still probably not taxing the flow of the stock intake, but this may be a good time to upgrade it anyway...since you're an addict now. Either way, these upgrades won't show a ton of HP increase, but they will clear the way for your next round of (crazy expensive) mods. An upgraded TMIC might be nice, some heat wrapping and blankets, cold-air intake, etc. Tune or not is up to you here...probably not going to make much difference.
Fuel system - Like the intake, upgrading the fuel delivery system here is going to cost money and won't deliver much more than a smoother tune. Higher rated fuel pump, injectors, rails, etc. These clear the way for the next mod, which will kick you in the ass.
Turbo- Now is a good time to choose a good turbo and search your soul. The second you go for a larger-than-stock turbo, you're officially sunk into the car. A good turbo from a reputable vendor plus all of the needed supporting mods is going to cost you a chunk of change. You've officially spent a year of payments at this point, and you'd better be enjoying yourself.
Divorce- Your wife and kids have left you, no doubt. Your family has sent the police to check on you, and you've been fired from your past three jobs. You should probably get a sponsor or 17, because you're driving a race car.
New car- You've probably outgrown the STI, wrecked it, or blown it up several times. You clearly also have enough spare cash kicking around to buy a car that is better stock. Look into a Farrari or an Audi R8.
drdabbles is offline   Reply With Quote
Old 03-16-2009, 12:47 PM   #22
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I just spit iced tea out my nose
Old 05-15-2009, 01:52 PM   #23
BretskieSubie
Member#: 200793
06 ...stock WRX/B
ive read your other posts zacxzx, i think you should read the stickys please
BretskieSubie is offline   Reply With Quote
Old 05-15-2009, 02:04 PM   #24
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
Listen to the n00b, OP
YourMother'sLover is offline   Reply With Quote
Old 05-15-2009, 04:21 PM   #25
dsolis
Member#: 121775
2008 STi Hatch
Aspen White | Gold BBS!
Can you close the valve while your driving? or do you have to be at a stop? or the car needs to be off?
I read and read and couldn't find anyone mentioning anything about that....
dsolis is offline   Reply With Quote
Everything you need to know about boost creep wgknestrick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 503 04-15-2016 06:39 AM
everything you need to know about turbos dankEe Tri-State Area Forum 1 11-08-2007 06:59 PM
Everything I Need to Know about Raleigh Durham But Was afraid to Ask Cdiff South East Region Forum 5 12-13-2005 03:13 PM
Everything you want to know about cheap boost control desiwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 86 03-09-2005 09:21 AM
Everything you wanted to know about the WRC but were afraid to ask rsquire_downunder Motorsports 7 02-12-2003 12:28 PM
