Old 03-16-2009, 06:13 PM   #1
efmd3
Member#: 120985
2002 Impreza WRX
Midnight Black Pearl
Default new motor not getting fuel
Ok, so I have been building my block for 8 months and I finally get to the last few steps, priming the oil and whatnot.
This car has sat for 8 months with no battery or motor, etc. It did have gas in the tank, and all the fuel components worked great before the old motor came out.
Things that have changed since it last worked:
new motor
no tgv's or motors/etc
no ac
no rear o2 (for the moment)
no maf
new fuel filter
new fuel rails
new injectors
new FPR
now, I know what you're thinking, but I took the main line off the filter and no fuel there, so what do you think may be causing this.
One theory is the walbro has blown seals from sitting in 8 mo old gas.
Dumb things I haven't checked yet:
I haven't pulled the pump yet (its raining but this is first on the list)
Clean out gas tank and refill
pull line off pump and check for fuel.
I tried using an OBDii scanner to see if it was pulling codes, but it keeps getting errors...
Will try using the tactrix to read what map is on there, but that shouldn't keep fuel from making it into the engine bay...
efmd3 is offline   Reply With Quote
Old 03-16-2009, 06:22 PM   #2
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
When you turn the car on (not cranking it), do you hear the pump in the back go on for 4-5 sec? If not, than you're power to the gas pump is not working, start there and work your way the line....
Fongers is offline   Reply With Quote
Old 03-16-2009, 06:27 PM   #3
efmd3
Member#: 120985
2002 Impreza WRX
sorry, forgot to mention that it DOES make noise, but only when the car is in test mode
Old 03-16-2009, 07:03 PM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
My guess, you have put the fuel lines on backwards. Ie the feed is connected to the wrong side of the FPR and the return is connected to the feed side.
mick_the_ginge is offline   Reply With Quote
Old 03-16-2009, 07:55 PM   #5
69subaru360
Member#: 159682
1995 WRX
x2 I've done it myself.
Old 03-16-2009, 08:40 PM   #6
efmd3
Member#: 120985
2002 Impreza WRX
black=fuel feed
silver=fuel return
blue=tank vacuum
Old 03-16-2009, 09:29 PM   #7
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
make sure you have them going to the fuel rail the right way...i fought this problem for a few days
blkwagon is offline   Reply With Quote
Old 03-16-2009, 11:29 PM   #8
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
And connected to the FPR the right way, the FPR should be on the return rail.
Oh and connect up the MAF sensor, the subaru hates running without a MAF. I should have spotted this the first time around
Old 03-17-2009, 12:15 AM   #9
efmd3
Member#: 120985
2002 Impreza WRX
I found the problem, somehow the FP relay under the dash on the passenger side was unplugged.
Now I have a bigger problem...agency power fuel rails...
these things SUCK
they leak like a mofo.
time for some better rails, suggestions?
New Motor - Can't get oil pressure AJS Built Motor Discussion 20 06-12-2009 01:03 AM
Need help- not getting fuel jaqi006 Normally Aspirated Powertrain 6 03-22-2009 05:02 PM
S204 on 9-2006 Best Motoring, not new silentbob343 Off-Topic 15 09-29-2006 06:12 PM
New motor..not sure what tune to use. elduderino11 AccessPort 2 09-03-2006 10:10 PM
Where can i get fuel injectors for this motor. Pictures inside STEALTH-WRX Factory 2.0L Turbo Powertrain 6 09-07-2003 06:35 PM
Message Board Statistics All times are GMT -4. The time now is 05:23 PM.
