Old 03-16-2009, 08:42 PM   #1
tscott915
Member#: 130225
01 BRP Ej205 vf39
270whp 265wtq
Default swapped GC atmospheric pressure sensor
RS ecu B136-29.... no location found for the newly updated wrx ecu. sooo do i need this sensor for the new motor. if so what must i connect the wires too?
all my connections have been made. i have 2 wires left from the rs end. they both go to the engine bay. R/W is b136-29 (stock ecu now removed)and there is a blue wire that runs next to it.
tscott915 is offline   Reply With Quote
Old 03-16-2009, 11:19 PM   #2
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
not sure what engine you are running but with my swap i didnt' have that sensor. it is not needed for it to run (was told that by few vendors on here)
slava from goshen is offline   Reply With Quote
Old 03-16-2009, 11:36 PM   #3
silentt
Member#: 119995
2004 Outback XT
Peachy
Check Brydon's thread here or on RS25. It's a sticky in the conversions forum over there.
silentt is offline   Reply With Quote
Old 03-17-2009, 01:56 AM   #4
tscott915
Member#: 130225
01 BRP Ej205 vf39
270whp 265wtq
im running an 02 wrx motor. my rs is an 01
Old 03-20-2009, 12:12 AM   #5
tscott915
Member#: 130225
01 BRP Ej205 vf39
270whp 265wtq
does an 02 usdm wrx motor need an atmospheric pressure sensor??
Atmospheric Pressure Sensor ElizRN Transmission (AT/MT) & Driveline 12 03-07-2016 07:47 PM
atmospheric pressure sensor??? Pierrot Subaru Conversions 25 01-10-2016 08:31 PM
Atmospheric Pressure Sensor cthor Private 'Wanted' Classifieds 2 09-25-2009 12:35 AM
Where is atmospheric pressure sensor located? IndyRacer Engine Management & Tuning 7 02-24-2006 12:38 PM
MAP & Atmospheric Pressure Sensor Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 4 02-01-2002 12:45 PM
