Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 03-16-2009, 11:09 PM   #1
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Default will the a/c compressor & power steering from an 06sti fit in my 02
I swapping in a 06sti LB with wrx intake manifold and tb into my 02wrx.
Question is will the 06sti power steering and ac compressor fit into the wrx as well. I thought I read somewhere that they had different fittings. I'm hoping I can use them since thats just more stuff to switch over.
breathinez is offline   Reply With Quote
Old 03-16-2009, 11:21 PM   #2
MasterKwan
Member#: 98961
2003 WRX
Steering will swap over. I hope the AC does, I'm planning on sticking an 05 compressor in my 03. By my eyeballs they look the same.
Old 03-17-2009, 10:54 AM   #3
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Yeah they look the same to me as well.
Old 03-17-2009, 11:07 AM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Fittings are the same, but the plug changed from a 3 wire to a single pin connector in 04.
jamesfacts is offline   Reply With Quote
Old 03-17-2009, 11:30 AM   #5
MasterKwan
Member#: 98961
2003 WRX
Thanks. I have the 05 harness in my car so I should be good.
Old 03-17-2009, 10:54 PM   #6
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Can I just switch the plugs? I mean that would take 2 min. , it looks like the 02 is basically one wire with a jumper.
Old 03-20-2009, 09:03 PM   #7
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
I'm gonna bump this for an answer.
Old 03-20-2009, 11:22 PM   #8
MasterKwan
Member#: 98961
2003 WRX
Maybe you should look at the wiring diagram? That's how I'd figure it out if it was me.
What transmissions will fit in my 02 WRX? Juks Transmission (AT/MT) & Driveline 3 11-06-2009 02:13 PM
WTB: 93-01 2.2L Impreza A/C Compressor & Power Steering Pump compressro Private 'Wanted' Classifieds 7 08-04-2009 10:57 PM
Is it my Wheel Bearing? & Will a hub from an 06 fit an 02? nayr924 Brakes, Steering & Suspension 0 06-01-2009 08:47 PM
Will an STi fit in my garage? (Need measurement of rear wing) vision.dynamix General Community 64 06-06-2007 08:20 AM
will a VF22 from an RS fit my 02 wrx? breathinez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-16-2005 04:20 PM
