Old 03-17-2009, 02:02 PM   #1
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Default EWG oem twinscroll
not 100% sure this goes in this section, but I didnt really see anywhere better, I would have to double post to put in the 2.0 and 2.5 sections. If there is a better place please let me know I will move it
I will be putting a VF37 with a 20G wheel in it on saturday. this is an upgrade from my 16g, which I have an external wastegate on, my question is, does anyone have an EWG on the OEM twinscroll up pipe? if so do you have any pictures?
what are yall's thoughts about doing this? I know the gains since I have an ewg set up now, and I love the sound and would like to keep it, just not sure of how to do it
seanathanq83 is offline   Reply With Quote
Old 03-18-2009, 01:54 AM   #2
seanathanq83
Member#: 173241
no one???
Old 03-18-2009, 02:45 AM   #3
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I'm would like to do this also. Right now I have a vf36 but waiting to replace it with AVO's gt30r jdm twinscroll location turbo. You have to find a fabricator in your area and he'll most likely need your car to mock one up. If not hit up Kelly from CovertPerformance a vendor in this forum.
methaddict is offline   Reply With Quote
Old 03-18-2009, 03:32 AM   #4
seanathanq83
Member#: 173241
i got a guy to do it, but i dont know what under the heat sheilding, i have read that it is stainless, but i dont know for sure, i will be putting the set up on this saturday, i finaly have all my parts and, and the turbo willbe a vf37 that has been ported polished worked over, and had a 20g wheel put in it. no i bought a vf22 that is on its way, and i will be taking the CHRA and putting all my stuff from the VF37 in it, so i will basicly have a vf36 with a 20g wheel. i have been reading up on the avo turbo, knew it was modeld after the avo550, but i did know how big that was. sound like a good up grade if it all works out well, i dont see what they couldnt just manufactur a twin scroll housing and stick it on, just increase the A/R on it, and open the the turbine housing for a bigger exhaust wheel.
but back on subject, i saw somone wanted to do it, just dont remember who, or if they ever did it, i just want my EWG, to help with boost issues
Old 03-18-2009, 03:50 AM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I was toying with an idea of EWG my VF36 and rotate it, rotate intake mani and have the shortest FMIC piping as possible
results would not justify the costs
apparently lachute is working on EWG twinscroll uppipe or something...
Hyper is online now   Reply With Quote
Old 03-18-2009, 12:45 PM   #6
seanathanq83
Member#: 173241
i think an ewg would be worth it, expecialy with a 20g wheel that i had installed
Old 03-19-2009, 12:50 AM   #7
seanathanq83
Member#: 173241
anyone else
Old 03-20-2009, 12:23 AM   #8
TheWagonMod
Member#: 198405
2002 Sti Wagon
silver for now
possible but pricey you would have to run twin wastegates
TheWagonMod is offline   Reply With Quote
Old 03-20-2009, 12:33 AM   #9
seanathanq83
Member#: 173241
true but you can get them pretty cheap now the new 38mm ms-v and i have a regular 38, but im selling it to my friend
Old 03-20-2009, 12:41 AM   #10
CovertPerformance
Vendor
Member#: 196004
06 STI
if the piping is stainless tubing or any kinda of tubing it shouldnt much of a problem as long as it isnt like the stock sti uppipe. Just have to notch up some tubing the same dia as the runners on the uppipe, and then either use a notcher to put a hole on the uppipe tubing or do it the slow way and grind away with a bit.
Have you thought about just getting the gtspec jdm twinscroll piping and doing ewg setups on that?
CovertPerformance is offline   Reply With Quote
Old 03-20-2009, 01:11 AM   #11
seanathanq83
Member#: 173241
actually i dint know they had anything, that and i have the full twinscoll set up, its going on saturday
Old 03-20-2009, 01:12 AM   #12
CovertPerformance
Vendor
Member#: 196004
06 STI
is it off the car? Why dont you just look behind the shielding and see if its tubing or not, should answer your questions
Old 03-20-2009, 01:16 AM   #13
seanathanq83
Member#: 173241
because its welded and i dont really want to drill out or cut out the welds, but i know it is stainless
Old 03-20-2009, 01:29 AM   #14
seanathanq83
Member#: 173241
also, i am still trying to decide if i want 1 or 2 ewg, or just port the heck of out the stock IWG, and upgrade the wastegate actuator
Old 03-20-2009, 01:17 PM   #15
methaddict
Member#: 159738
2004 WRB STi
The jdm header and uppipe is stainless steel behind the heat shields.
Old 03-24-2010, 02:53 AM   #16
arco
Member#: 57156
2007 V.8 207 STi
Mercedes White
Hey what's up Meth.
If i have some twinscroll uppipe flanges, how much do you think it would be to have a single EWG fabricated?
I too am going off the OEM setup. Ballpark estimations are fine. Also I'm wondering how long it will all take to be complete. Thanks in advance
arco is offline   Reply With Quote
Old 03-24-2010, 10:42 AM   #17
arghx7
Member#: 232940
I don't understand the problem... bleed off the outside radius of each runner, collect to EWG. done. you need to have the capability to create the holes necessary and the capability to weld them. It's like the reverse of a custom EWG recirculation.
arghx7 is offline   Reply With Quote
Old 03-24-2010, 03:29 PM   #18
arco
Member#: 57156
2007 V.8 207 STi
Mercedes White
I wanted to keep my stock uppipe and create another one solely for EWG. This way I have an option to switch back if I wanted. I know that comment may not be directed at me but I think it's fairly easy. I just wonder about cost and I want to know who is capable of creating it in the SCIC area.
Old 03-24-2010, 07:36 PM   #19
seanathanq83
Member#: 173241
well i am in texas, and still want to do this, but i may be able to find someone to do it, but i was really thinking about doing dual ewg's
Old 03-25-2010, 02:31 AM   #20
arco
Member#: 57156
2007 V.8 207 STi
Mercedes White
Ideally two is better. I think we have come to a consensus about that. Speaking for myself, my car is still my daily driver and I don't have anything on the line in terms of competitive racing where I need every edge possible. I would to make this as best as possible but there is a point where I am foolish to spend all of the money I make to complete my mods leaving me eating ramen, not affording future rent, gas, etc. etc.
That all being said, I will probably go with a single v-band EWG. I want the runner to be separate as far the WG flange. It should be suitable for my situation and it should still be better than me not using a EWG period.
Anyone know where I can go in SCIC Long Beach, Cerritos, LA, Costa Mesa area to get this done?
Or would Covert Performance be able to do this without my car?
Old 03-25-2010, 08:37 AM   #21
seanathanq83
Member#: 173241
If they can do it off the car for a reasonable price let me know I got friends in Cali I could send it that way
Old 03-30-2010, 02:58 PM   #22
arco
Member#: 57156
2007 V.8 207 STi
Mercedes White
bump for local fabricator
Old 04-20-2010, 03:03 AM   #23
seanathanq83
Member#: 173241
anyone ever get this done??? talking to a guy about getting my turbo built, and that 49lb compressor wheel could really use the assistance of twin 38mm vbands
oem twinscroll header seanathanq83 Factory 2.0L Turbo Powertrain 60 06-20-2009 03:42 PM
FP Evo3 16G EWG, OEM TMIC, SSQV Bracket, much more Vlad Engine/Power/Exhaust 21 05-27-2009 06:22 PM
SoCal: Garrett GT35R, turboxs ewg uppipe, rear O2 sensor, twinscroll dp and more BlueFish Engine/Power/Exhaust 27 05-27-2009 06:08 PM
Twinscroll EWG Question BigRigger Factory 2.5L Turbo Powertrain 36 05-11-2009 05:16 PM
OEM Twinscroll copper Gasket Kit Lachute Performance Engine/Power/Exhaust 0 03-02-2009 03:20 PM
Message Board Statistics All times are GMT -4. The time now is 04:54 PM.
