Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 03-17-2009, 03:08 PM   #1
A Guy with a STi
Member#: 127215
01 Fozz
Default Another 'What Solo class should I be in?' thread
I've been reading through the forum and from what I've read an ALK knocks me out of any of the 'street' class and puts me in either the P or M classes. I've been reading the '09 rules and I'm still just as confused. From what I was able to understand my car should be in EM. If so, would it be safe to assume that getting a motor swap won't change what class I'd be in?
Here is a list the mods I have done to the car:
Suspenion
Whiteline ALK
Whiteline 22mm N/A Front Sway Bar
Whiteline 24mm WRX Rear Sway Bar
Whiteline Heavy Duty Rear Sway Mounts
Whiteline Front & Rear Sway Bar Endlinks
Whiteline Lateral Links
Whiteline Rear Strut Tower Bar
Whiteline Front Roll Center Adj Kit
Whiteline Rear Toe Lock Out Kit
Rota Boost 17x8 +48
Tein Front Strut Bar
ARP Extended Wheel Studs
'05 STi Brake Booster & MC
Wilwood 6/4 Pot Brake Kit
STi Group N Rear Crossmember Bushings
ATE Super Blue Brake Fluid
STi Lower Control Arm
Super Pro Lower Control Arm Bushing
Super Pro Front & Rear Trailing Arm Bushing
BC Racing Coilovers
Hankook K104's 245/40/17
MRT Master Cylinder Brace
Drivetrain
Techna-Fit SS Clutch Line
Super Pro Rear Diff Support Bushings
Super Pro Rear Diff Bushings
Kartboy Trans Crossmember Bushings
Drive Shaft Shop Alum Drive Shaft
ACT Heavy Duty Clutch Kit
Fidanza Flywheel
Cusco Motor/ Trans Mount Kit
Kartboy Short Shifter
Kartboy Front & Rear Shifter Bushings
TIC Shift Linkage Update
TIC Shifter Pivot Bushing
Ixiz Concept Race Pitch Stop
Engine
Perrin Crank Pulley
Borla Headers
AEM Intake
Stromung Cat-Back
Walbro Fuel Pump
Interior
Sparco Steering Wheel
WRX Pedals
STi Spec C Shift Knob
Exterior
Wingless Trunk off of an L
Flared/ Pulled Fenders
Tein Hood Dampers
A Guy with a STi is offline   Reply With Quote
Old 03-17-2009, 03:20 PM   #2
misterwaterfallin
Member#: 101091
you know there is a rule book right?
there doesnt need to be 5 of these threads everyday
misterwaterfallin is online now   Reply With Quote
Old 03-17-2009, 03:21 PM   #3
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
E Prepared...
Old 03-17-2009, 03:24 PM   #4
A Guy with a STi
Member#: 127215
01 Fozz
Yes. I read it. I still have questions. I was trying to be considerate and not run in the wrong class and possibly take away points from other competitors.
Old 03-17-2009, 03:27 PM   #5
A Guy with a STi
Member#: 127215
01 Fozz
Originally Posted by Scooby South View Post
E Prepared...
Thanks for the help! That solves that. Now I'll read up more on the rules for that class.
Old 03-17-2009, 03:51 PM   #6
digitalseance
Member#: 104400
169k mile race car
E Prepared...
No, not EP, FP. The aluminum drive shaft kicks you out of SM IIRC.
digitalseance is offline   Reply With Quote
Old 03-17-2009, 03:56 PM   #7
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
^^^^ actually EM....my bad...is a GC body Phil...
Old 03-17-2009, 03:58 PM   #8
digitalseance
Member#: 104400
169k mile race car
Shouldn't be EM I don't think since it's still a subaru engine. Induction is unlimited/unrestricted in prepared.
A novice really doesn't want to show up running his first event in e-mod!
Old 03-17-2009, 08:43 PM   #9
Boxologist
Member#: 21118
Novice XP then.
Boxologist is online now   Reply With Quote
Old 03-17-2009, 08:48 PM   #10
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Why not FP? The aluminum driveshaft and ALK kick it out of SM, but why into EM? I figure there is a rule I am missing.
speedyHAM is offline   Reply With Quote
Old 03-18-2009, 10:34 AM   #11
mla163
Member#: 104922
2013 BRZ
Can someone put together a thread that lists basic scooby mods that bump you into a higher class?
ALK puts you in...
Tranny swap puts you in...
Turbo swapp puts you in...
etc.
mla163 is online now   Reply With Quote
Old 03-18-2009, 11:07 AM   #12
leecea
Member#: 37359
2003 WRX
I think tha basic mods are pretty well documented and understood, it's the other stuff that's harder to figure out.
I'd also note that not everyone seems to care as much as NASIOC. I got told to "get a life" by members of another board's "motorsports" forum for telling someone they were running the wrong class
leecea is offline   Reply With Quote
Old 03-18-2009, 11:52 AM   #13
SpeedTheory
Member#: 152510
Heh. This **** happens at local events all the times. SR20DET 240sx w/a GT40R was running STX the other week.
SpeedTheory is offline   Reply With Quote
Old 03-18-2009, 01:51 PM   #14
Illini_STi
Member#: 70634
ALK puts you in...
etc.
Like perhaps this one?
http://forums.nasioc.com/forums/showthread.php?t=174189
Illini_STi is offline   Reply With Quote
Old 03-18-2009, 02:05 PM   #15
mla163
Member#: 104922
2013 BRZ
Originally Posted by 05STiDan View Post
Not bad
Old 03-18-2009, 02:21 PM   #16
delongedoug
Member#: 124113
and beyond!
Ohhh, "Read This First". Who knew?
delongedoug is online now   Reply With Quote
Old 03-18-2009, 04:16 PM   #17
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Are you going to National events? If no, run in SM until someone complains and says you need to be in XX. Then switch to XX.
If yes, read the rule book.
rjrutzky is offline   Reply With Quote
Old 03-18-2009, 04:31 PM   #18
A Guy with a STi
Member#: 127215
01 Fozz
Not just yet, but I'd like to try and compete against other cars in my class.
Old 03-18-2009, 04:42 PM   #19
Chiketkd
Member#: 71634
In hibernation...
+1 This car as it sits is eligible for either FP or XP.
Chiketkd is offline   Reply With Quote
What solo class should my car be in?? WTFJayJay Autocross 10 03-18-2009 02:01 AM
What class should I be???? kashun84 Motorsports 8 08-14-2007 11:12 AM
The 'What the hell happen to that cat?' thread WHTWRX Off-Topic 4 06-07-2004 07:55 PM
Should NY be in another forum or its own? Faraz Tri-State Area Forum 39 09-05-2001 01:43 AM
What class will i be in for auto-x? Swivel1000 Mid West Subaru Owners Club Forum -- MWSOC 2 09-25-2000 10:57 PM
