Welcome to the North American Subaru Impreza Owners Club Friday August 1, 2014
Old 03-17-2009, 06:57 PM   #1
mellow65
Member#: 83350
Too Many
Default input from the phase 2 ej25 swappers using 1.8ecu needed
it's not a question of if it's doable, i know it's doable, i run a phase 2 ej25 in my 90 legacy using all the 2.2 stuff right now
the question is, has anyone ever ran into issues with pinging or detonation running the phase 2 ej25 with the 1.8 ecu. the 2.2s have a knock sensor but the 1.8s do not. and this is all assuming i'm running super for fuel.
i'm looking at swapping my ej25 in a 93 impreza that might be my next rally car so i'll be beating the piss out of it. but if there is concerns about possibly killing my motor due to detonation i would figure out how to run a 2.2 ecu because i have had no problems with that set up. and having that buffer of a knock sensor is nice.
mellow65 is offline   Reply With Quote
Old 03-18-2009, 07:06 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
I've only run a phase I EJ25 off the EJ18 ECU. I have run a phase II EJ22 off of it though....with no problems at 10:1 compression. I keep that ECU around for emissions testing and use(d) either an EJ22 or EJ25 ECU for other driving. I added a pin to my ECU harness and ran a wire out to the knock sensor, which solved the noticable timing drop when run without it. YMMV
Jay
Old 03-18-2009, 01:54 PM   #3
mellow65
Member#: 83350
Too Many
are you talking obd2 ecus?
because what i'm finding is that obd1 1.8 and the obd1 2.2 ecus have completely different ecu plugs. a thought i had would be to maybe depin the 1.8 plugs and repin them with to use the 2.2 ecu. but might be just as easy to lay a 2.2 harness in because i really like how my legacy runs with the 2.2 ecu running the ej25.
but good to know that 10:1 had no issues. I figured running super would cover me for most things but having a knock sensor would be nice insurance.
Old 03-18-2009, 03:24 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Yes, I was referring to OBDII ECU's.
I would keep running the EJ22 harness and add a knock sensor pin to the harness.
Jay
Old 03-18-2009, 05:27 PM   #5
mellow65
Member#: 83350
Too Many
Jay
yes but that requires hacking down an ej22 harness and putting it in the impreza. not that i haven't done it a few times before, but it's still no fun.
Old 03-18-2009, 07:26 PM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
For me, it was 1 pin to add to my ECU harness plug, and I had an extra plug that came with a spare ECU. I figured out how to remove the pins and went to town. It was a couple hours of work.
Do a search for repinning ECU plugs or something like that, I know it's been discussed before.
Jay
Old 03-18-2009, 08:34 PM   #7
mellow65
Member#: 83350
Too Many
Jay
not so easy on the obd1 stuff, the legacy has a 4 plug ecu and the impreza has a 3. so major repining would be needed. but i figure both being obd1 there would be about the same amount of pins. i know of a couple things the 1.8 has that the 2.2 doesn't like an EGR valve. so you just would leave those unhooked. but i'll do some searching. thanks
Old 04-02-2009, 05:38 PM   #8
jester409
Member#: 64376
04 WRX
Subscribing in hope of some updated info on the 18>25 swap... I've got an 05 phase II ej25 (auto trans motor) that I am preparing to install in my 95 L w/ 1.8 and manual trans using my current 1.8 computer and harness. Would really like to run the knock sensor if it is possible without major harness hacking, but from what I have seen it most likely isn't necessary. I want to make sure I have everything I need before I jump into this.
I have read everything that Hawk296 has posted regarding this particular conversion, but that info is 5 years old. He didn't run a knock sensor and seemed to have good results.
jester409 is offline   Reply With Quote
Old 04-02-2009, 07:08 PM   #9
mellow65
Member#: 83350
Too Many
i ended up finding that there really it would be easier to lay in a ej22 harness and ecu rather then trying to used the ej18 harness with a ej22 ecu. the number of wires running to each harness is way different.
ej18=64
ej22=76
and that's just counting the holes in each plug to the ecu, there may be less to each i don't know i haven't gotten that far yet.
but if you want to check it out i did a pretty good write up about swapping a ej25 into my 90 legacy. not a step by step, but it covers all the big stuff. and honestly it was pretty damn easy.
http://www.ultimatesubaru.org/forum/...ad.php?t=83839
Phase 2 ej25 with one dented piston, can I swap for a piston from phase 1? ciper Normally Aspirated Powertrain 5 05-24-2008 10:49 AM
anyone running phase 1 ej25 heads on phase 2 ej25 block ??? IllNastyImpreza Built Motor Discussion 7 05-04-2008 11:48 PM
WTB: EJ25 phase 2 Crank new to almost new, needed for rebuild (Portland) OregonRS-Dude NWIC Private Classifieds 11 04-09-2008 11:27 PM
Part Number for Phase 2 EJ25 shortblock oman Factory 2.0L Turbo Powertrain 2 01-22-2002 05:50 PM
How is the Phase 2 EJ25 holding up? dandbest Normally Aspirated Powertrain 21 05-20-2001 05:39 AM
