Old 03-17-2009, 07:14 PM   #1
robwrx19720
Scooby Scammer- Do Not Buy From User
Member#: 180582
Default Sti heads or wrx heads
I have a sti ej257 block that im going to build for my 2.0l, the sti block had came with heads. but im not sure if i should use the sti heads or my stock 2.0l heads. what set of heads should i use for the build?
robwrx19720 is offline   Reply With Quote
Old 03-17-2009, 07:19 PM   #2
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
What type of engine management are you using? If you are going stand alone then the STI heads for sure. If you want to utilize your factory ECU then perhaps the wrx heads would be the easiest since you can use all of your factory wiring. You might be able to use the STI heads and your stock intake manifold but I am not sure.
hustleshark206 is offline   Reply With Quote
Old 03-17-2009, 08:00 PM   #3
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
you can use sti heads with your stock intake mani and wiring harness but wont be able to take advantage of the avcs with out some sort of controller. Also depending on the year of the head some had a provision for the cam sensor mount in the front that needs to be drilled and tapped. If not you have use a cosworth cam angle sensor adapter to mout the cam sensor in front. The 2.5 heads will give you the correct compression number with out having to go to a thicker head gasket. Using the 2L heads with the 2.5 block will give you a higher than stock compression ratio.
blkwagon is offline   Reply With Quote
Old 03-17-2009, 09:23 PM   #4
robwrx19720
Member#: 180582
the heads came out of a 05 sti
Old 03-17-2009, 09:42 PM   #5
EGY5
Member#: 165206
2006 WRB DPSti
w/ white shoes
I personally can offer no useful advice except I was searching for this earlier and I found this advice, from Maxwell Power (Sponaugle level of knowledge)
From this thread, where the guy is literally asking the same thing (2.5L block, which heads?)
http://forums.nasioc.com/forums/show...ighlight=heads
Originally Posted by Maxwell Power View Post
my advice is to match the heads to the bore/block.
And just an FYI, taken from this thread:
http://forums.nasioc.com/forums/show....php?t=1667168
Now lets do the compression ratio calculations:
Combustion chambers:
06wrx heads (D25 casting): 50cc
04-07 STi (B25/V25 casting): 55.5cc
02-05wrx (S20 casting): 49 cc
Factory compressed HG thickness .026"
EJ257 block on B/V25 STi head: 8.24:1
EJ257 block on D25 WRX head: 8.74:1
EJ257 block on S20 WRX head: 8.84:1
EJ255 block on B/V25 STi head: 8.07:1
EJ255 block on D25 WRX head: 8.55:1
EJ255 block on S20 WRX head: 8.64:1
Remember that the EJ255 is the same as the EJ257 except for the pistons
EGY5 is offline   Reply With Quote
Old 04-13-2009, 09:41 AM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
It's not the same for the heads. Different combustion chamber.
However I want to see a set of '07 STi heads because that looks to be the same casting as the '06+ WRX heads, but still running different combustion chambers.
FuJi K is offline   Reply With Quote
wrx heads/sti block, current wrx heads ej20g 4banger4dr Built Motor Discussion 6 11-14-2009 03:55 PM
STi or WRX heads MS WRX Built Motor Discussion 3 01-30-2009 06:58 PM
LTB sti or wrx head 04+ Sc00byDrew NESIC Private Classifieds 0 10-21-2007 01:22 PM
Wtb Sti Or Wrx Heads apsrex Private 'Wanted' Classifieds 0 09-25-2007 10:32 PM
WTB: Ver.7,8 Cylinder heads, or WRX heads 17cTSi Private 'Wanted' Classifieds 1 07-14-2004 07:41 AM
