Old 03-17-2009, 10:19 PM   #1
needawrx13
Member#: 175051
02 Slow rs
Brp/rust
Default wrx hybrid question
i just need some opinions. i just popped the motor in my 04 wrx. im planning on getting a 05 sti shortblock and swapping everything over. my question is, im going to be(for the time being) running the stock wrx ic and td04. its got catless up and 3" catless turbo back. im running a ap v1 stage 2 ots map. will i be ok with the extra displacement with the ots stage 2 map?. i barely have the cash to do the short block so a pro tune is out of the question. any info would be great. thanks!
needawrx13 is offline   Reply With Quote
Old 03-17-2009, 10:39 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Against my advice, a guy local to me here in Colorado did this last year on an engine I put together for him. He drove it for about 4 months with basically the exact same set up you are looking at doing. It survived until he was able to get a pro-tune.
That said, if my tone isn't obvious, I don't think it's a good idea. With how delicate the Ej257 pistons are when exposed to detonation or preignition it's really a crapshoot on whether or not it will hold together. A bad tank of gas or a malfunction with the BCS could crater a piston with no warning at all. You are taking your chances if you do this.
Old 03-29-2009, 11:54 AM   #3
mike914
Member#: 206818
2005 sti
wrc blue
i've seen good options as low as $2500 for the sti block
mike914 is offline   Reply With Quote
02 WRX hybrid build, PCV/Vac Line question SeanDead Newbies & FAQs 2 03-18-2010 05:32 PM
2003 2003 WRX Hybrid Questions?? (Sti block Wrx heads) khyree05 Newbies & FAQs 19 10-18-2009 08:43 PM
02 wrx Hybrid Questions? WRXTC09 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-29-2009 03:52 PM
wrx hybrid questions...my future set up...please help jimtweet Built Motor Discussion 2 09-06-2006 11:52 AM
WRX Hybrid question brex16 Subaru Conversions 3 08-13-2006 04:48 PM
