Old 03-18-2009, 12:26 AM   #1
All_talk
Member#: 57843
2007 Spec B
Default Just Another Rod Bearing Clearance Question
How consistent should the clearance be around the diameter?
I’m measuring (with a bore gauge) 0.002” at the rod axis, but as you move to the split line it opens up to 0.003/0.0035”. The rod bores are very consistent (within a few tenths) and I can measure the slight thinning in the bearing shells out toward the ends. Normal? Or bad bearings? I’ve gotten the same results with two sets of shells.
ACL Duraglide bearings, standard size. Scat H-beam rods.
Gary
All_talk is offline   Reply With Quote
Old 03-18-2009, 05:39 AM   #2
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
I pulled the internals out of my 5.4 ford modular block and the bearings only look worn 90 degrees from the split parts. That tells me that this "oval"-ness is normal?
AKSubieDubie is offline   Reply With Quote
Old 03-18-2009, 10:49 AM   #3
All_talk
Member#: 57843
2007 Spec B
I’ve been doing a little more research this morning and apparently what I am seeing is normal. The eccentricity is intentional and the “vertical oil clearance” is measured 90 degrees from the part line. I have only found one reference to how much eccentricity there should be, but it was not specific to Subaru applications.
“Bearings oil clearance specs are listed as "vertical" due to the eccentricity in performance bearings. Measure a performance "P" rod bearing with a bore gauge and you'll see they are about .002 wider at the parting line.”
Source: https://fordmuscle.com/forums/all-fo...clearance.html
These two documents from Clevite and ACL reference eccentricity but do not give any values.
http://mahleclevite.com/techbulletins/CL77-1-205R.pdf
http://www.acl.com.au/web/acl00056.n...7?OpenDocument
Anybody have a number to shoot for in a Subaru?
Gary
Old 03-18-2009, 02:02 PM   #4
cooleys04
Member#: 145027
2004 WRX FP Green
MFactory/2Tone/built 205
The eccentricity is normal, it's to help prevent the bearing edge from "biting" the journal and spinning the bearing under high rpm.
cooleys04 is offline   Reply With Quote
Old 03-19-2009, 12:20 PM   #5
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
It's good to see people checking clearances, you should check bolt stretch/vs torque or torque angle... The rod will change shape in reference to parting line vs vertical line. It is my experence that they are a little egg shaped.
It's never the rod bearing that give me a hassle. It's the fact that the block is a mess in the mains. It always seams like a decent amount of work to get the mains where I want them. Have you guys taken apart new stock engines to see how far from "correct" they are? Have you seen how the block "grows" with heat?
Jay Meagher
RealStreet is offline   Reply With Quote
Old 03-19-2009, 12:33 PM   #6
All_talk
Member#: 57843
2007 Spec B
I haven't got to the main yet. I still have to cut mt EJ22T case for the thrust on #5 (I'm running the phase II 2.5 crank). But I'll let you know what I find.
Gary
ACL Race bearing clearance questions blkwagon Built Motor Discussion 25 12-04-2009 01:06 AM
Rod Bearing/ Shortblock Question dimpster Service & Maintenance 4 08-30-2008 08:50 PM
spun cyl 1 rod bearing - Basic questions... paintbing Built Motor Discussion 11 07-30-2008 11:37 PM
Crank bearing clearance question?? Petersubaru Built Motor Discussion 0 01-07-2007 01:14 PM
Bearing clearance question japslapr Built Motor Discussion 5 12-11-2006 09:35 AM
