Old 03-18-2009, 12:59 PM   #1
Pita84
Member#: 193644
2002 WRX Wagon
Platinum Silver Metallic
Default USDM 05 STI Longblock into 02 bugeye
Is there any easier way to have the AVCS work on the 05 Block and heads with a modified harness and a JDM ECU or something other then a hydra?
I have been lead to believe that the JDM V7 STI ECU will not control USDM heads. I have the setup and just figured if i could use it i would. If its a pain in the arse then i would just port the WRX heads and go full hybrid instead of just bolting on my wrx intake and porting the STI heads.
Any thoughts would be appreciated.
I was thinking at the minimum would be to replace the solonoids with JDM in the USDM head.
Thanks in advance
Pita84 is offline   Reply With Quote
Old 03-18-2009, 06:52 PM   #2
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
You could bag the AVCS, plug the holes in the cams and run the bigger heads with a few sensor adaptors.
Fongers is offline   Reply With Quote
Old 03-18-2009, 10:42 PM   #3
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Whats wrong with using a Hydra?
dexterous is offline   Reply With Quote
The FIX! 05 STi clusters into 02-03s (possibly 04s) Chapel Interior & Exterior Modification 284 08-13-2013 10:26 PM
05 STi transmission into 02 WRX wagon - axle questions corey_dyck Transmission (AT/MT) & Driveline 16 07-28-2011 10:55 PM
USDM v8 STi longblock swapped into 04 wrx. Advice for engine management... srREXed Subaru Conversions 3 04-11-2010 02:51 PM
05 STi tranny into 02 WRX wrxG Subaru Conversions 2 10-03-2008 01:44 PM
what to do with DBW with 05 sti swap into 02 wrx? bustaman Subaru Conversions 7 11-16-2005 02:11 AM
