Old 03-18-2009, 02:17 PM   #1
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Default Idle timing/ low load ignition timing adjustment after cam install?
I have installed bc 272 cams. I am curious how idle timing should be modified to run most or close to efficient burn. Decreasing Lop, misfires, etc.
I have tried to search but could not find any specific info on this topic from a tuning POV.
Great minds educate us.
NITROS is offline   Reply With Quote
Old 03-18-2009, 02:29 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
I fudged the coolant temp timing compensation map to add 3 degrees of timing at idle with my cosworth 278/274 cams. Seems to have helped.
jays05 is offline   Reply With Quote
Old 03-18-2009, 02:32 PM   #3
NITROS
Member#: 41561
04 GT3076 2.1
O nice, I didn't even think of modifying that map.
after bov install my car idles low ownnij Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-13-2011 12:27 AM
08 STi knocking low ignition timing and load - Help!! erikm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 04-18-2010 08:59 PM
negative ignition timing log light load Beanboy AccessPort 3 09-18-2007 01:30 PM
Low load pulling timing? Zumble Commercial ECU Reflashes 30 09-17-2007 10:11 PM
high idle after cam install wrally Built Motor Discussion 7 03-22-2007 12:55 PM
