Old 03-17-2009, 11:13 PM   #1
mc2
Member#: 59992
1997 Legacy L EJ22
Default Is this my rear main seal or oil seperator plate leaking?
Hey folks, is this what i think it is?
I wiped it off and the oil is reappearing there. Getting a lot of burning and smoke from the y-pipe joint in the mornings...
Its a 2.2L on a legacy.
This is where my engine meets the transmission at the bottom there you can see the oil starting to weep out. I just wiped it clean yesterday and it's back today...
a photo from the firewall looking forward
Also, i couldn't find the oil seperator plate on the parts diagram, only item 34 which is called a rear main seal retainer? Is that the oil separator plate?
mc2 is offline   Reply With Quote
Old 03-17-2009, 11:56 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
yes, 34 is the separator plate. 33 is the rear main seal.
yarrgh is offline   Reply With Quote
Old 03-18-2009, 12:29 AM   #3
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
That seems like a weird leak. Normally a leak on the rear main or the separator plate gets all over the crossmember, and from there your header/catpipe... aka the Spy Hunter mod. Looking at those, it could be those, but seems liek something else to me... I just have no idea what.
BAN SUVS is offline   Reply With Quote
Old 03-18-2009, 12:32 AM   #4
mc2
Member#: 59992
1997 Legacy L EJ22
Well, it was all over the crossmember and exhaust, cat, etc... I went to the carwash and degreased the hell out of it to find out where the leak was coming from. it must be a VERY slow leak because it doesnt drip at all in the garage... it just burns off in the mornings. it smokes like crazy at the stop signs... out the hood, into the cabin of the car, everywhere... the guys next to me at the traffic lights must think i'm nuts.
Old 03-18-2009, 12:36 AM   #5
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Ah, yeah- that definitely sounds like rear main issues. Plan to replace both, though one might still be okay.
Old 03-18-2009, 12:53 AM   #6
mc2
Member#: 59992
1997 Legacy L EJ22
not looking forward to that.
rusty exhaust bolts, rusty crossmember bolts.. its one of those things that turn out being a can of worms... damn.
Old 03-18-2009, 03:29 PM   #7
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
If you plan on doing this yourself, I would suggest dropping the tranny instead of pulling the motor. Just so you dont have to mess with the cooling system.
If you can, get the newer style real oil seperater plate made from aluminum or the really newer ones that are steel. The plastic ones are absolute crap and leak. Make sure to clean it all off really good and use some high temp silicone gasket maker, I use permatex ultra grey for just about everything.
In your pics it looks like the pass. side rear cam plate is leaking a little bit also. Take a trip to the dealer to get the little o-ring that is inside. It might take the parts monkeys a little time to figure out what part you want, but they should be able to get it for you.
A can of PB Blaster will help break up those rusty bolts. Spray it on and do something else for 20-30 mins. or so.
If you do end up taking the tranny out, after you remove the drivshaft, there will be a leak at the tailshaft. A spray paint can lid works wonderfully to stop the leak.
~Josh~
ballitch is offline   Reply With Quote
Old 03-18-2009, 05:57 PM   #8
mc2
Member#: 59992
1997 Legacy L EJ22
Yup, I plan to do it by dropping the tranny.
I'm just going to order the part number that i get from subarugenuineparts.com, so hopefully its the metal plate.
I'm going to be doing the timing belt later as well, so I plan on changing those o-rings then. Is it going to be easier to do it while the tranny is out?
As far as the leak in the back goes, is that going to be rear diff fluid coming out? Just need to know if I'm going to need to top that off afterwards or not.
Old 03-18-2009, 06:28 PM   #9
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
that would be tranny fluid leaking out when you drop the driveshaft. the front only has splines and the carrier to keep it in place, the rear of it bolts in.
make sure you paint some alignment marks on the rear of the driveshaft, and on the pressure plate as well.
nkx is offline   Reply With Quote
Rear Main Seal Leak? Inprogress Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-23-2010 04:09 PM
Two leaking rear main seals in a year?? Leaking Head Gasket...Oil Pressure Issues??? jsavage Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-21-2010 11:06 AM
Oil leak from rear main seal area? cueball89 Normally Aspirated Powertrain 4 11-29-2009 08:28 AM
How bad is a leaky front crank seal or oil pump? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-03-2007 11:24 PM
Is this my clutch, tranny, diff, or what? Ender the Xenocide Transmission (AT/MT) & Driveline 2 01-18-2006 07:02 PM
