Old 03-18-2009, 03:19 PM   #1
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Default Draining pump gas? For Race gas....
hey,
I was wondering how all you high hp people drain your fuel when wanting to run Race fuel.
I have been told to drop the fuel tank and get a bung and plug welded on the lowest part of the tank so I can simply open the plug and have all the fuel drain out so that i can refill the tank with VP109 race fuel.
Using a siphon is not an option because there is no way of getting every drop of the fuel out. I need to be able to run untained race fuel in my tank.
How do you guys do it?
Ben
mtcs is offline   Reply With Quote
Old 03-18-2009, 03:29 PM   #2
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
When I switch from pump to race, I just run it super low and idle the rest out. I then put a full tank of race gas in to make sure any pump gas gets gobbled up by my super race gas molecules
rjrutzky is offline   Reply With Quote
Old 03-18-2009, 03:37 PM   #3
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Do you run it so the tank is completely empty?
Wouldnt the fuel pump eventually take a sht cause it was running with no fuel going through it...
or how does it work....
Old 03-18-2009, 03:41 PM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Disconnect the fuel return line in the engine bay and connect it to a hose which drains into a can. Then just idle the engine until the return starts to splutter.. hey presto, tank empty, or at least low enough
mick_the_ginge is offline   Reply With Quote
Old 03-18-2009, 03:46 PM   #5
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Pretty good...i might try that insteead of droping the tank and going through all that aggrivation.
just dont want to kill the Walbro fuel pump...
Old 03-18-2009, 04:07 PM   #6
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
my take has a drain plug, yalls dont????
seanathanq83 is offline   Reply With Quote
Old 03-18-2009, 04:21 PM   #7
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
not on the 00 RS
Old 03-18-2009, 04:43 PM   #8
seanathanq83
Member#: 173241
o ok didnt know what
Old 03-19-2009, 01:22 AM   #9
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
think I got it...
going to drill a small hole into my fuel pump bracket having it go into my fuel tank. Next, i'll install a line that will have a weighted tip so that it remains on the bottom of the tank at all times. From that line to a drill pump and finally into a container. Should work perfectly (I hope)...
what you guys think? got the idea from youtube. lol
Old 03-19-2009, 02:13 AM   #10
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
sounds sketchy, drills and fuel fumes are a recipe for you dying. Return line idea is best.
turboL is offline   Reply With Quote
Old 03-19-2009, 02:42 AM   #11
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
was just an idea...really not sure what im going to do yet. got two weeks before I need it.
Disconnecting the fuel return line would def do it but what kind of damage might I do to my walbro? Dont want to end it's life way prematurely...
any thoughts?
Old 03-19-2009, 02:56 AM   #12
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Put a fuel cell in the trunk.
alcoolaid is offline   Reply With Quote
Old 03-19-2009, 09:01 AM   #13
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
when draining my tanks in the past, I'd had just jumped 12v's to the fuel pump and pulled the feedline and drained it fast...
I like mick's idea...as its easier but slower
I use a tuthill fuel transfer pump now.
Old 03-19-2009, 10:46 AM   #14
jays05
Member#: 78165
05 STI 35r + e85
I either pull the return line or run it low and add a LOT of racegas (more fun )
jays05 is offline   Reply With Quote
Old 03-19-2009, 12:02 PM   #15
TopSpeed
Member#: 78884
Go faster
at TopSpeed
This is how we always do it.
Doug
TopSpeed is offline   Reply With Quote
Secondary tank/fuel cell for race gas? Red Rocket Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 07-14-2004 01:23 PM
How do I modify my stage 3 UTEC map for Race gas? Davenow Engine Management & Tuning 1 03-31-2003 05:39 PM
Local guy for race gas/delivered or pick up/ 5 gal Tex-WReX Texas Impreza Club Forum -- TXIC 8 06-26-2002 04:42 PM
>93 octane gas for racing Minnesota WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-19-2001 01:11 AM
Any place in OC for Racing gas? flipguy80 Southern California Impreza Club Forum -- SCIC 4 05-25-2001 12:28 AM
