Old 03-18-2009, 05:41 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default TD05-18G, Built Block, JUN Cams, Tomei Headers
Here's the latest tune from yesterday:
04 WRX with:
EJ257 Built Shortblock
EJ205 Heads - P&P, JUN cams
TD05-18G - 7cm 2.4" inlet
PE800cc injectors
SSAC FMIC
Tomei EL Headers
Catless Perrin DP
Custom, very quiet catback
Custom Tune using EQ Flash on 91 Octane
Chart:
This customer is planning on a 6 speed and a larger turbo in the future. Obviously the current turbo is really undersized for the setup, but the car runs great all around. Full boost around 3200-3300RPM and good pull to 7k RPM. Once we get a bigger turbo in the car, we should be able to take it to 8k RPM and have some real fun
*** Standard Dyno Chart Disclaimer ***
This software reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock WRX - 155-165whp
Stock STI - 215-225whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
380-390whp - 120-121mph traps
*** End Disclaimer ***
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 03-19-2009, 08:01 AM   #2
wrxhard
Member#: 108091
Once again, Ed FTW!!!! Good stuff. How much do you think this setup would benefit from meth or other high octane resources? Or do you think this turbo is pretty much too pooped to pop at this point?
wrxhard is offline   Reply With Quote
Old 03-19-2009, 10:56 AM   #3
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Just about any turbo would greatly benefit from meth injection or race gas as compared to our crappy cali 91. I would expect to see around 340-350whp with meth injection.
Thanks
-- Ed
Old 03-19-2009, 11:36 AM   #4
benw
Member#: 103320
1998 swapped
Forester L
what boost level?
benw is offline   Reply With Quote
Old 03-19-2009, 11:51 AM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Originally Posted by benw View Post
what boost level?
Just touching 20psi at 3200RPM, tapering to 16.5psi by redline.
-- Ed
Old 03-19-2009, 01:14 PM   #6
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Ed It looks great as always!
Any reason you tapered the boost down so much? Or is it because the 18g just cant flow that much with cams?
I love the flat powerband up top. Is this the reason you tapered the boost so, to keep it nice and smooth, instead of peaky?
Or is this just what the engine liked?
Either way it looks great. Id love to see this on meth or good fuel.
Ian,
rexworx is offline   Reply With Quote
Old 03-19-2009, 02:38 PM   #7
Bullwinkle1983
Member#: 172332
2006 WRX
The small 18g can't run much boost up top with the 2.5L engine, 16.5 PSI @ 7k is about max for pump gas.
Bullwinkle1983 is offline   Reply With Quote
Old 03-19-2009, 02:56 PM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I have almost an identical setup. With the proper boost control you can run more boost to redline but if that added boost isn't adding power the is not point. I made no more power running 20psi at redline than I did running 15psi at redline. For me the turbo was kaput after 5K rpm and just blowing hot air.
Old 03-19-2009, 05:14 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
You got it... we could hold more boost up top, but it results in no additional power. The turbo just isn't big enough to hold boost up there, so higher boost means a lot more heat. Combined with 91 Octane, this extra heat is very bad
-- Ed
Old 03-22-2009, 09:52 AM   #10
wrxhard
Member#: 108091
Thanks
-- Ed
Holy carp!!! Thanks for the reply Ed. Keep working your magic!
Old 03-22-2009, 11:06 AM   #11
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
shes beggin for a bigger turbo with a mods list like that man. I ran that size 18g on a stock wrx motor. lol
D Money is offline   Reply With Quote
Old 04-07-2009, 09:00 PM   #12
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep.... he's waiting for a 6-speed before giving the motor what she really wants
Old 04-08-2009, 01:26 PM   #13
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
Thumbs up
" *** Standard Dyno Chart Disclaimer ***
*** End Disclaimer *** "
Every tuner/shop should post this same type of info. Great job Vaus!
JoeTX is offline   Reply With Quote
Old 04-08-2009, 02:58 PM   #14
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Thanks... I realized I was posting this info in just about every thread after someone commented on the "low" numbers, so I decided to save some time and post the info preemptively
-- Ed
JUN cams and Jun cam gears FS waynoSTI Engine/Power/Exhaust 69 08-27-2010 07:14 AM
FS: Pnp FP td05 18g / XS Power EL Header/ Oem Manifold Boxer_Psi Engine/Power/Exhaust 17 03-05-2010 09:31 PM
FS: XS Power EL Header/ Oem Manifold/ Feeler: FP Pnp'd Td05 18G Boxer_Psi Engine/Power/Exhaust 1 02-14-2010 05:45 AM
which cams to go with td05 18g 8cm2 ? STi_4_life Built Motor Discussion 22 11-28-2008 03:30 PM
2.6 litre sleeved block, stage 3 heads, jun cams and springs Phatron Private 'For Sale' Classifieds 86 06-06-2005 11:48 AM
