Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 03-18-2009, 06:17 PM   #1
Hard Body
Member#: 191436
08 Acura TL
Default leak from behind timing belt cover...help
i was changing my oil yesterday and noticed a leak coming from behind the timing belt cover. i asked my mechanic and he said its most likely the cam shaft seals...anyone have any ideas of what else it might be?
Hard Body is offline   Reply With Quote
Old 03-18-2009, 06:32 PM   #2
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Oil pump.....
I had it go on my old Outback, they replaced the seal 3 x before they replaced the whole pump assy. (Under warranty).
skimobile is offline   Reply With Quote
Old 03-18-2009, 06:53 PM   #3
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
It could be one of many things. A cam shaft seal, oil pump seal, valve cover seal, blah blah
Thug Nasty is offline   Reply With Quote
Old 03-18-2009, 07:04 PM   #4
Hard Body
Member#: 191436
08 Acura TL
and all that would be under warrenty?
Old 03-18-2009, 07:11 PM   #5
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
if your car is still under warrenty... duh
ownnij is offline   Reply With Quote
Old 03-18-2009, 07:43 PM   #6
Hard Body
Member#: 191436
08 Acura TL
very nice yeah i got the powertrain left
Old 03-19-2009, 10:22 AM   #7
Haelan
Member#: 151045
2013 Subaru STI
CBP
If it's your cam or crank seals you might want to check your PCV valve. I blew my crank seal from a pinched PCV hose.
Haelan is offline   Reply With Quote
Old 03-19-2009, 07:20 PM   #8
Hard Body
Member#: 191436
08 Acura TL
i took the car in today. they replaced both cam and crank seals, timing belt, and a tensioner. im gonna give it another week before i look at it to make sure it isnt leaking still
Old 03-19-2009, 08:16 PM   #9
skimobile
Member#: 92114
03 WRX (NAVY Camo)
Nice!
Shattered Timing Belt Cover, Help! nfm Newbies & FAQs 5 08-10-2009 02:50 PM
Replacing timing belt cover. HELP! adxvance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-05-2009 10:41 AM
Help Please! Timing belt cutting into timing belt cover behind A/C idler pulley Kansai Subaru Service & Maintenance 14 10-23-2008 04:05 AM
leak from timing belt cover area grizz3000 Service & Maintenance 17 12-27-2006 09:53 AM
Oil Leak from timing belt cover abosworth Normally Aspirated Powertrain 26 09-15-2005 08:29 PM
