Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 03-18-2009, 06:19 PM   #1
rexpower09
Member#: 200481
02 subaru
Default Need some advice hybrid heads
well heres the deal i just got done instating a 2.5 turbo block into my 02 wrx using 2.0 heads that where only shaved and cleaned aka hybrid.. after puting the car back together it runs good just needs a tune reallly bad. when i spoke to my tunner he had said that the 2.0 heads cumbushgin chambers need to be ported due to to much compression? well i dont plan on going nuts on the car the biggest turbo ill run is a 18g.. should i pull the motor to port the heads or well it be ok? thanks
rexpower09 is offline   Reply With Quote
Old 03-18-2009, 06:27 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Please fill out your profile and post in the correct forum
And you're running a 2.5 with the tune for your 2.0?
The heads don't NEED to be ported, but it's not a bad idea.
Audiosavvy is offline   Reply With Quote
Old 03-18-2009, 06:34 PM   #3
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
You'll be fine, porting won't really help the compression issues anyway, its boring out the cylinder tops of the heads... porting helps flow. You might want find someone who can actually tune a hybrid or learn yourself man.
Fongers is offline   Reply With Quote
Old 03-18-2009, 06:42 PM   #4
305mouse
Member#: 106792
2005 Saab 92X
Stage Pi w/ VF35
What head gaskets are you using and which block? If it's an STI block with the OEM head gaskets, your compression will be too high to run a decent amount of boost over stock. If it's a 06-07 WRX block with stock head gaskets your compression is fine. The WRX pistons are dished more than the STI ones. That's the only difference in the two blocks. If it is a STI block, you could get thicker head gaskets and be fine. Here's a chart that helped me when I started researching for my project.
305mouse is offline   Reply With Quote
Old 03-18-2009, 06:46 PM   #5
rexpower09
Member#: 200481
02 subaru
[b]the block came out a legacy turbo baja and it is a deep dish piston.. it was just a stock oem head gasket
Saw some wheels today and need some advice.... Tecate Tire & Wheel 2 02-26-2010 11:44 AM
Head gasket veterans, need some advice... surowrxa Service & Maintenance 5 12-28-2008 05:49 PM
building a car in stages and i have some questions/or need some advice jmanrex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 03-11-2006 12:20 PM
Just bought some seats, need some advice... legacyej22 Legacy Forum 5 12-04-2002 12:47 AM
heading to the rally of gb, need some advice!!! Imitryx Motorsports 10 11-05-2002 03:38 PM
