Old 03-18-2009, 08:34 PM   #1
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
Default Smoking Like A Chimney!
Alright so last week I did a turbo swap on my built motor.. I went from an element tuning gt52 to a vf48 in hopes to run e85 and go fast, with instant boost.. The vf48 had maybe 5k miles on it and is 3 months old. No shaft play and was not smoking on the previous car..
I am now smoking like a chimney and its been going on for a week. I swapped turbos last Thursday the 12th. I have white smoke pouring out my exhaust pipe.. I have ordered a ICV gasket and its on its way. I think this is the culprit but I have no clue since I have never touched it before..
My question is can I run fuji/honda bond whatever you want to call the silicone gasket maker until the proper gasket comes in. This is my daily driver and the white smoke is killing me!
Or is there anything else that I should look for as the culprit?
autvincereautmori is offline   Reply With Quote
Old 03-18-2009, 08:38 PM   #2
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
Oh and my built motor has just over 3k miles on it.. Changed oil at 100, 500, 1000 and at 3000 miles..
Old 03-18-2009, 08:58 PM   #3
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
Can i just do the throttle body coolant bypass mod and that way there is no more coolant going through the throttle body?
Old 03-19-2009, 12:03 PM   #4
benw
Member#: 103320
1998 swapped
Forester L
so your TB gasket is hosed, and you suspect coolant getting in to the TB? Have you looked in the TB to see if that's what is happening, or could the smoke be from something else?
benw is offline   Reply With Quote
Old 03-19-2009, 02:30 PM   #5
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
No i believe that it is coming through the idle control valve.. I have looked into the manifold and there was liquid sitting in the plenum..
That is what I am asking if it is coming from something else. I am about to do the coolant throttle body bypass mod and see if that eliminates my problem..
Old 03-19-2009, 03:10 PM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Make sure the turbo oil return like is not restricted. That will cause you to smoke too. I focus on the things you touched last if the problem started soon after.
Old 03-19-2009, 03:27 PM   #7
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
Good call I will look into that as well.. I am letting my car cool off now from the ride to autozone.. If the oil return like was kinked ever so slightly wouldnt it smell like oil being burned? The white smoke doesnt smell like oil and is pure white not blue.. Or am I just wrong?
Old 03-19-2009, 03:48 PM   #8
centeno711
Member#: 184638
2002 wrx wagon wrb
97 cummins 1ton 4x4
how long did the turbo sit before you installed it? white smoke is coolant black is fuel or oil depending on color but both could be due to bad seals in this new turbo.......just a shot in the dark but you didnt have the problem and now you do so i would start with the most obvious change.
centeno711 is offline   Reply With Quote
Old 03-19-2009, 05:21 PM   #9
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
Well i fixed it.. I did the coolant bypass mod and I found that I had a huge kink in my oil return line.. The kink cut off about half of the flow.. So I replaced that as well.. Now there is no more smoke!
Old 03-20-2009, 02:28 PM   #10
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Cool, was gonna suggest the bypass if you thought that was leaking...
Fongers is offline   Reply With Quote
My turbo blanket is smoking like crazy, is this normal dexterous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 06-10-2009 12:17 PM
Two Year Old Smokes Like an Adult Wile Off-Topic 47 02-12-2009 03:21 PM
b12 chemtool doesn't smoke like seafoam :( vica153 Service & Maintenance 5 10-02-2006 01:16 PM
04-05 wrx SE Austin smoking like Cheech and Chong Legend STI Texas Impreza Club Forum -- TXIC 11 06-20-2006 12:30 PM
My car smokes like a chimney Rated reX Service & Maintenance 14 02-26-2002 11:23 AM
