Old 03-18-2009, 09:07 PM   #1
Crazy650
Member#: 109498
05 Wrx turned STI
Default going to build a hybrid
going to take a 2.5 short block and put wrx heads on it is there anything special i well need?
thanx in the end i want to make 350whp dd
Crazy650 is offline   Reply With Quote
Old 03-18-2009, 09:21 PM   #2
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
New Head Gasket (Compression purposes)
Various Gaskets
Shims
2.5L Oil Pump
New water pump
May need new head studs
New Timing Belt, Accessory Belts
Resurface/replace clutch and/or flywheel
Turbo - 18G or bigger
Good Tune
I am sure there is more but thats off the top of my head. Also, I highly recommend some forged pistions (i.e. CP). I know a great tuner/builder in Miami (Gregg at Machines Gone Wild) if your interested.
csmithwrx'05 is offline   Reply With Quote
Old 03-19-2009, 12:11 AM   #3
Crazy650
Member#: 109498
05 Wrx turned STI
got a tuner and got a shop to do this at brand new in boynton shop (= 5mins from me
Old 03-19-2009, 12:16 AM   #4
W0R2X
Member#: 88706
i have this setup also, minus the larger turbo, the parts listed above are pretty accurate.
i would recommend replacing the head bolts as they are supposed to be one time use.
im using STi head gaskets, but a lot of people go with Cometic for different thickness.
the engine gasket kit isnt a bad idea either, since you never know what you will need.
get a new TO bearing with that clutch.
and make sure you check your valve clearances, there is a formula to figure out which shims/buckets you need. ask your local subaru dealership.
W0R2X is offline   Reply With Quote
Old 03-19-2009, 01:06 AM   #5
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
Smile
Brand new shop????
How experienced is the builder/tuner? Has he done a lot of WRX/STi builds?
B/c I would not trust a hybrid build to just anyone or just some regular performance shop. MGW (who built my hybrid) specializes in building/tuning WRXs, STis, and Evos.
Also, I would definitley have a discussion with your builder about forged pistons and if you like holding your power to 7k+ RPM some aftermarket cams (i.e. Tomei 252s or Kelford 264s).
IMHO if you want 350whp build the motor to handle 450whp, so it will last and you can drive the piss out of it.
Old 03-19-2009, 03:44 AM   #6
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
Only our 02/03's use shims + buckets. All newer use shimless buckets.
Thug Nasty is offline   Reply With Quote
Old 03-19-2009, 03:20 PM   #7
Crazy650
Member#: 109498
05 Wrx turned STI
been doing sti builds for 3 year's in his own house just got his on shop, Im going to use 05 wrx head's on a sti 08 short block, one of the other member said be a good idea to run forged if i dont he said i get alot of knock not a good thing at all. looking to do this right the frist time.
Old 03-19-2009, 10:20 PM   #8
Crazy650
Member#: 109498
05 Wrx turned STI
bump for more info
Old 03-20-2009, 08:18 AM   #9
Grammar Police
Guest
Member#:
one of the more discussed topics on this forum, hit the search key and learn.
Old 03-20-2009, 10:11 AM   #10
scprs
Member#: 172359
2005 STi
the 05 sti block has been proven to be the strongest according to jorge at IAG
scprs is offline   Reply With Quote
Old 03-20-2009, 02:26 PM   #11
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
for 350, I think any ej25x block will be fine to build on (5 or 7). Just find one in good shape with no cylinder wall damage/cracks/etc and you'll be good...
Fongers is offline   Reply With Quote
Old 03-21-2009, 06:01 AM   #12
joeschmoe714
Member#: 71374
2005 impreza wrx
aspen white
[quote=csmithwrx'05;26001867]New Head Gasket (Compression purposes)
Various Gaskets
Shims
2.5L Oil Pump
New water pump
Good Tune
this is my hybrid setup.
05 wrx heads (deshrouded, 3 angle pnp, crawford racing spec cams, oem valvetrain)
brand new ej25 block, sti crank, rods, mahle 100mm pistons
12mm oil pump
oem water pump
sti gasket kit
crawford racing wrx street clutch
custom gt30 turbo kit
ecutek
joeschmoe714 is offline   Reply With Quote
Old 03-21-2009, 11:01 AM   #13
sleeperrex
Member#: 19466
2002 wrx/hybrid
Originally Posted by csmithwrx'05 View Post
Brand new shop????
Yeah, i would be careful about who does the build. Make sure they understand how to tune for one. Don't take it to 2 different places like i did. One did the build and the other did the tune. Even if they are reputable.
Had to have my engine pulled a second time to remove aftermarket cams because the tuner had diagnosed the cams as being the problem for engine knock on my hybrid. Took it to another tuner and got it running right.
sleeperrex is offline   Reply With Quote
Old 03-21-2009, 09:43 PM   #14
Crazy650
Member#: 109498
05 Wrx turned STI
thanx for the info it alot of help thankyou
Old 03-23-2009, 10:02 PM   #15
wrxdrivr04
Member#: 156619
2004 WRX 2.5 hybrid
FP EVOIII 16g
+1 also according to Andrewtech Automotive!
justed finished up my hybrid build 05 sti s/b amd 04 wrx heads!!!!
wrxdrivr04 is offline   Reply With Quote
Old 03-23-2009, 11:20 PM   #16
Crazy650
Member#: 109498
05 Wrx turned STI
just a update on my parts are a sti short block out of a wrx 06. 05 wrx head's
If OT was going to build a custom home... (cucamelsmd15 wants a new casa) cucamelsmd15 Off-Topic 68 09-26-2010 12:34 PM
Toyota to build 3 hybrid battery plants by 2011 AVANTI R5 Non-Subaru News & Rumors 0 05-23-2008 01:20 PM
I'm going to build an airplane attitude Off-Topic 105 12-11-2006 11:34 AM
my father is going to build a new house nomadtw Off-Topic 20 06-27-2005 04:26 AM
if you were going to build... quig Normally Aspirated Powertrain 3 08-11-2004 05:30 PM
