#1 |
Member#: 186033
SWIC
Vehicle:2003 gtx30r hyb wagn PSM |
would there be any way i can keep my 5 speed transmission and just swap out the engine with a 2005 sti engine, and get a new ecu or would i reflash my ecu. can any one take me through the steps or point me towards a thread that could tell me how to swap.
#2 |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
Yes. How, sorry I have no idea. I just know it's common to keep the 5mt. It's just a few wires. Surprised there is no post about this or sticky.
#3 | |
Member#: 186033
SWIC
#4 |
Member#: 152077
International
Swap the transmission and keep your engine instead...you can easily reach/exceed STi power levels with the '02-'05 2.0L block.
#5 |
Member#: 188577
TXIC
Vehicle:2003 EJ207 PSM |
I'm interested in the answer as well.
#6 |
Member#: 186033
SWIC
swap the tranny huh, would you recommend like a tranny rebuild with ppg gears or sti gearing or what?
#7 |
Member#: 163702
TXIC
Vehicle:2007 impreza 2.5 UGM |
just swap for the stock 6sp sti transmission... it can handle an obscene input. swap the trans, build the engine.
running a 5sp will hold up with turned up boost and higher input, but for how long... most likely (unless you never launch/drive hard on it) you will need trans work anyways. tranny FTW! http://forums.nasioc.com/forums/show....php?t=1717700 I assume some have seen this thread, this guy claims to be rolling with the stock trans. |
#8 |
Member#: 131067
SCIC
Vehicle:your "stance" sucks |
swapping the tranny and building the motor would be the way to go!
#9 |
Member#: 155515
SCIC
Vehicle:OBP pignose hai2u |
Yup. You were looking at it all wrong. Swap the TRANNY from the STI NOT the motor. You could easily bolt on a vf39, get an exhaust and tune, and be quicker than any stock STI for a bout a grand.
#10 |
Member#: 159334
Vehicle:02 PSM WRX UTEC,PPG,FMIC, Big turbo |
If you want to build your 5 speed box, these are the gears I got Andrewtech to build me
http://www.youtube.com/watch?v=_wZCTs4gZAI http://www.youtube.com/watch?v=Ej0MgikZA9I http://www.youtube.com/watch?v=m01ZEhBz0HU http://www.youtube.com/watch?v=Kgmkzl5QCjY http://www.youtube.com/watch?v=mCwp6bCfyyU |
#11 |
Member#: 67004
SCIC
^ videos makes me sleepy
ppg can do a lot more. I have 70k miles on my ppg. I have been known to get smoke off my tires. Yet these guys are right. Unless you built the box 6mt would be a good choice. |
#12 |
Member#: 159334
Thats when I first got them (still in breakin period) I have abused them quite a bit since then
#13 |
Member#: 67004
SCIC
thats more like it! |
#14 |
Member#: 46135
Vehicle:02 WRX Powered by Sti V9 Spec C |
I am interested in the original question. Many people know everything about transmission swaps. It's well documented. Everybody knows the advantages, etc.
But, back to the initial question: What if? What if you don't have the money to do the right thing just yet (getting the 6 speed) and you get caught with the 5 speed at high mileage, say 160 k miles and your 2.0 dies, of spun bearing, by example.. You decide to immediately do a 2.5 and postpone the transmission, although WE ALL KNOW that's what you should do (transmission first). This probably happens in real life. Each time you have some $, you go for more power. Untill, one day it's too late for your 2.0, BEFORE you had a chance to do a 6speed. And here's my question: How do you go about driving the AVCS in the 2.5? A reflash of the 2.0 ECU? I don't think so. Without the AVCS, your 2.5 is more like a 2.3 (I'm just kidding, what I mean is that you're starting with less than 100% of what the Sti offers stock) There's the throttle by wire, which requires a pedal, and probably running a wire to the engine compartment, etc. OR you may run the 2.5 on cable throttle, I wonder if anyone did that, by using your old TB. So, please, answer the original question. Last edited by Vlad; 03-19-2009 at 10:54 AM. |
#15 |
Member#: 101865
NWIC
Vehicle:88 GL-10 STi silver |
read this.
http://elementtuning.com/technical/ej25_install.htm i think this is what you are after... this is for the STI longblock not just the short block... -=Suberdave=- |
| Thread Tools | |
| Display Modes | |
| Airbags 2004-2005 STI & 2002-2003 WRX Driver's Passenger Controllers Sensors Seatbelt | Royal Motors | Interior/Dressup/Audio & Security | 87 | 09-24-2010 05:23 PM |
| will suspension from a 2005 sti fit a 2003 wrx wagon? | Dangerdave | Brakes, Steering & Suspension | 1 | 05-08-2010 08:28 PM |
| 07 Sti Engine in 02 WRX cam sensor issue | obrut | Subaru Conversions | 1 | 04-19-2009 12:06 AM |
| 2005 STI scoop fit 2003 WRX ? | FastInMass | Newbies & FAQs | 7 | 07-02-2006 05:15 PM |
| Who has put the 2.5l STi engine in their WRX? | 413rally | Subaru Conversions | 4 | 08-29-2003 05:49 PM |
