Old 03-19-2009, 04:23 AM   #1
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Default Built RS-T injector sizing and general questions.
Hello.
I've been searching around for injectors for my car. I know a fair amount about injector sizing for rotary engines, but am at a loss for my Subaru.
Here is my build. -Its been on the road reliably for the last year, and its time to up the boost slightly while keeping drive-ability great.
ENGINE:
Ej253 block
Je forged pistons
Pauter Rods
O-ringed
Knife edged and micro polished crank
ACL bearings
ARP head bolts
SOHC
Delta Ground Cams
5 angle valve job
Ported and Polished and port matched
Cobb retainers and valve springs
OEM STI head gasket
OEM timing belt, waterpump, oil pump and all other belts
All OEM seals
Motor Assembeled and Machined by Greg at Millennium Motor Sports late Spring 2007
Compression: 9.2:1
TURBO:
TurboNetics T3/T4 .74 trim
Greddy front mount inter cooler
Synapse engineering BOV
HKS wastegate 7lb spring
Unequal length custom turbo manifold
Custom 3” inch exhaust -no cats
FUEL & ECU:
RC Engineering 310 saturated injector’s 91% duty cycle (running very rich)
RC fuel rail setup with parallel fuel rail conversion
Aero-Motive Rising rate FPR
Earls high flow fuel filter
Walbro 255lph fuel pump
Hydra Nemesis 2.5 ECU
-I plan to get a GM boost control solenoid, or perhaps something else to control boost. Suggestions would be welcome.
-This car is a daily driver and I have a high importance on a smooth idle and reliability. I'd like to get around 300 WHP and increase my fuel economy above ~15mpg. With how rich the car is running now I figure I can get the fuel economy up w/o much issues.
1: What injector size would meet my power goal while keeping a decent AFR at idle? I'm thinking of 550CC injectors from RC Engineering.
2: I need a method to increase boost above 6psi, and am leaning towards a GM boost control solenoid. The Hydra ECU can control boost functions if need be. Any other recommendations/comments/ suggestions?
3: Does the turbo need an oil restricter in the oil feed line, or should I not worry about it?
Thank you for any advice!
ZeroDrift is offline   Reply With Quote
Old 03-19-2009, 04:37 AM   #2
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I would go with some RC 750's so you have some head room if you want to up the boost some more.
Are you running an internal or ewg? Either way you can use the hydra to control boost. You could also go with any one of the aftermarket units to control boost that way.
It depends on the turbo. Some like the garrett's need it and some like my Innovative have them built in. I would call turbonetics and find out for sure.
speed_freak27 is offline   Reply With Quote
Old 03-19-2009, 04:45 AM   #3
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Can the Hydra use both High and Low impedance injectors? Which one would be better suited to my goal? The waste gate is external, and I believe the size is 44mm, but I cannot say for certain. The waste gate does merge back in the exhaust later in the downpipe.
Old 03-19-2009, 09:46 AM   #4
JSarv
Member#: 163445
l33t *******
[email protected]
RC=Lucas and Lucas injectors suck balls...
I'd explore other options! trust me you will regret having a horrible idle.
-Jerod
JSarv is offline   Reply With Quote
Old 03-19-2009, 12:44 PM   #5
cpturbo
Member#: 49175
2004 STI
Yes, the hydra can control both low and high impedence injectors.
What is the hp potential of your turbo?
Do NOT get 750cc injectors! Get those Bosch 1000 cc injectors if you can or use RC 1000s.
The reason is, your motor is built and you may decide to upgrade to a better turbocharger for your goals. You will ultimately lose money by selling and re-buying injectors. The idle on the hydra is good, even with 1600cc injectors.
Nice build. Luv for the GC8.
cpturbo is offline   Reply With Quote
Old 03-20-2009, 02:33 AM   #6
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Ok. Thanks for the advice so far!
I've made some calls and after talking to Tim at Surgeline, he highly recommends Deatsch Werks 860cc injectors. For the time being I plan to have the Hydra control the boost as well.
I've come the conclusion that I need a better catch can as well. Any thoughts about a Mr. Gasket Crankcase evacuation system? It vents crankcase fumes into the exhaust as opposed to the turbo inlet. Any other options that won't break the bank? I'm looking for more of a temp solution for the time being. I plan to get a proper air/oil separator in the next few months.
I need best injector size and opinions... NORAB Built Motor Discussion 3 04-07-2009 11:08 PM
e85 injector size, and boost control questions Turbovan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-25-2009 01:49 PM
EJ22 SOHC Injector Size and Compresion ratio Mechkiller31st Normally Aspirated Powertrain 18 10-15-2007 02:11 AM
installing a basslink and general questions ludecrous Car Audio, Video & Security 7 12-14-2006 09:04 PM
uppipe installation help and general questions... dj_booduh Newbies & FAQs 3 08-31-2005 09:50 PM
