Welcome to the North American Subaru Impreza Owners Club Wednesday August 27, 2014
Old 03-19-2009, 05:08 PM   #1
iRide
Member#: 190388
Default Poly Urethane Mud Flaps, Home made. Opinions Wanted!
Ok so Im working on a set of mud flaps right now and Im looking for some opinions. They will be black once they are finished but I want to no if you guys think there to wide? stick out to far from the wheel well? to wide on the inside? to low? or anything else you think might improve them, Thanks
iRide is offline   Reply With Quote
Old 03-19-2009, 05:41 PM   #2
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
I think they look pretty good. Where'd you get the material from? I probably would've bought black to start with if thats possible, since it's gonna be hard to find a paint that will hold up.
bcWRX-02 is offline   Reply With Quote
Old 03-19-2009, 06:51 PM   #3
Pohenegamook
Member#: 134262
9 조 ☼
Protective Buttress Face
now for a few more helpful points....if you plan on painting them, they will flake and look like ass, too wide on the outside but could be wider on the inside and "ENGLISH, MOTHER****ER! DO-YOU-SPEAK-IT?"
Pohenegamook is offline   Reply With Quote
Old 03-19-2009, 07:09 PM   #4
iRide
Member#: 190388
thanks for your input.
Old 03-19-2009, 07:22 PM   #5
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
i would cut it following the body line to make it look cleaner, but other that that good job.
what about using rubberized undercoating or truck bed liner to make them black? that should hold up.
bigolrig is offline   Reply With Quote
Old 03-19-2009, 08:15 PM   #6
iRide
Member#: 190388
These white ones are just templates for the black urethane ones I'm going to make. I had the urethane left over from making a snowboard box.
Old 03-19-2009, 08:31 PM   #7
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
shape looks great! what did you use as mounting hardware?
don't worry about the 'other' useless comments.
Tahoe SC is offline   Reply With Quote
Old 03-19-2009, 08:35 PM   #8
iRide
Member#: 190388
Right now there just bolted in there as you can see with the one picture, just has a nut on the other end.
Old 03-19-2009, 08:40 PM   #9
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
Unless you're planning on buying 18x9.5" wheels soon, I'd move the flap in a ways. No sense in having it 3" out into the airstream when the stock wheels are tucked back into the wheel wells.
SomeoneWhoIsntMe is offline   Reply With Quote
Old 03-19-2009, 08:44 PM   #10
iRide
Member#: 190388
Yea, I think I might move them in a lil tomorrow and see how that looks.
Old 03-19-2009, 09:00 PM   #11
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
just cut the holes pill shaped like the RA flaps so you can slide them in and out as much as you want! also make sure to use some good sized washers for the set up so the bolts don't get pulled through.
Old 03-19-2009, 11:00 PM   #12
iRide
Member#: 190388
That is a good idea.
Old 03-20-2009, 04:50 PM   #13
iRide
Member#: 190388
TAKE 2!
Those are still the white ones just with black vinyl on top, not finished yet.
Old 03-20-2009, 04:54 PM   #14
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
Those look good! flow nicely with the body
Old 03-20-2009, 04:56 PM   #15
iRide
Member#: 190388
Thanks.
Old 03-20-2009, 04:58 PM   #16
SeVn
Member#: 144811
2006 WRX Sedan
not bad man
SeVn is offline   Reply With Quote
Old 03-20-2009, 05:49 PM   #17
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
Using "to" and "no" improperly isn't bad enough to attempt and fry somebody. Way to make yourself look like a tool.
Le Saboteur is offline   Reply With Quote
Old 03-20-2009, 05:51 PM   #18
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
looks great!
can't wait to see your final product!
Just note that the RA flaps come with SS screw and everything else plastic so that there's enough strength to hold the flaps on through most things, yet if you back up to a curb or something and the flaps need to bend a different way, the screw would get pulled out from the plastic clip so as not to cause any damage. if you use bolts, you could possibly sustain some fender damage.
^ to be all technical about spelling, english, etc...actually, OP wasn't 'speaking' engrish, he was 'writing' it.
Old 03-20-2009, 06:02 PM   #19
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
my $.02 and change....
they look okay - shape is alright
they are made of a very stiff material and will shatter in the cold
Old 03-20-2009, 06:06 PM   #20
iRide
Member#: 190388
They aren't made out of very stiff material, Its Poly Urethane! This stuff lives in the cold. Its the same stuff you fine on top of snowboard boxes at ski resorts.
As for the hardware, I plan on getting some clips and screws, I just didn't have any on hand to mount them with.
Old 03-20-2009, 06:17 PM   #21
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
polyurethane or polyethylene?
mine are uhmw-polyethylene and are very flexible and have survived freezing temps.
I don't know anything about polyurethane
UP2MTNS is offline   Reply With Quote
Old 03-20-2009, 06:21 PM   #22
iRide
Member#: 190388
polyurethane, same stuff RA uses.
Old 03-20-2009, 10:38 PM   #23
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
right..... hope it works out for you.
defo not the same stuff we use on rally mud flaps but maybe it will be okay
hey you asked for opinions... just tossed in my change
I am inspired by your creativity and they do look good
Old 03-20-2009, 10:48 PM   #24
iRide
Member#: 190388
Like I said this isnt the final product, I plan on changing the density and thickness of the flap, but since I had this left over from this...
I figured I would recycle!
Old 03-20-2009, 10:57 PM   #25
Brisky
Member#: 148078
1993 Legacy L AWD
So where did you buy the polyurethane?
Lowes or a Home Depot or something?
Brisky is offline   Reply With Quote
08+ Ralley Armor Urethane Mud Flaps Black/grey MonsterWRX5 Exterior/Styling 10 05-02-2010 08:59 PM
F/S:Rally Armor Urethane Mud Flaps zzooozz Exterior/Styling 6 02-13-2009 10:27 AM
FS: Rally Armor Urethane Mud Flaps 5230EVO Exterior/Styling 6 08-17-2008 12:28 PM
Looking for pics: 2004-2005 CGM STi w/ Rally Armor Urethane Mud Flaps molehill84 Interior & Exterior Modification 5 07-01-2007 06:44 PM
Opinions wanted on mud flap colour Penphoe General Forum Archive 13 10-11-2000 12:02 AM
