Old 03-19-2009, 05:14 PM   #1
mc2
Member#: 59992
1997 Legacy L EJ22
Default Misfired, CEL, fixed misfire, reset CEL, failed smog...
I failed the section where they check your MIL. The guy wouldn’t tell me what the issue was without paying 55 dollars, even though I told him I knew what the problem was… Basically it was 55 bucks or get out.
So I just bought a OBD II reader to pull the code myself for about 60 bucks. The car hasn’t had an opportunity to complete all of the OBD tests according to the reader, so I guess that was cause I had to pull the battery to reset the CEL from the misfiring. I’ve already been driving it for a few days now and it looks like there are a few test that are not completed yet.
Is there a procedure somewhere which tells you the conditions required for each test to be completed? I tried to look in the FSM but didn’t find anything…
mc2 is offline   Reply With Quote
Old 03-19-2009, 05:59 PM   #2
mc2
Member#: 59992
1997 Legacy L EJ22
mods pls delete.. posted this in the service and maintenance section.
Misfired, CEL, fixed misfire, cleared CEL, failed smog... mc2 Service & Maintenance 3 03-20-2009 08:50 AM
Fail Smog Test after OBDII Reset truckresi Normally Aspirated Powertrain 9 07-30-2006 03:47 AM
Problematic CEL for misfire poormansporsche Normally Aspirated Powertrain 0 08-09-2005 07:25 PM
00' RS-New motor CEL Code = Misfire jelton Normally Aspirated Powertrain 3 10-09-2004 03:55 AM
CEL recurring misfire Keith99RS Outback Forum 10 10-03-2003 02:45 PM
