Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 03-19-2009, 08:40 PM   #1
binx159
Member#: 175695
2005 STI
CGM
Default Remove heat shield?
So i put a 3" exhaust on my 04 wrx sedan and the heat shield above my midpipe hits the new pipe and creates a periodic rattle. What have some of you done to solve this problem? remover heat shield? chop it down? ... let me know... thanks.
binx159 is offline   Reply With Quote
Old 03-19-2009, 08:48 PM   #2
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
Take tin snips or a dremel to the shield and remove the bit of metal where it rubs. You shouldn't remove the heatshield if you have a TMIC, and even if you have a FMIC it still helps with underhood temperatures.
SomeoneWhoIsntMe is offline   Reply With Quote
Old 03-19-2009, 08:50 PM   #3
binx159
Member#: 175695
2005 STI
CGM
Im talking about the heat shield under the car where the midpipe is. just in front of the rear wheels...
Old 03-19-2009, 09:00 PM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
same deal, get some tin snips and trim the heatshield.
rougeben83 is offline   Reply With Quote
Old 03-20-2009, 07:09 PM   #5
thejo
Member#: 206210
02 WRX Wagon
Wagon
Tin snip. Make sure you don't have a shot ram uncovered because the heat from the turbo doesn't match with intake.
thejo is offline   Reply With Quote
Old 03-21-2009, 11:54 AM   #6
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
what??
i used a rubber mallet and tapped the shield up a little bit on the edges and that solved it for me. though ive also seen people snip it.
elevenpoint7five is offline   Reply With Quote
Old 03-21-2009, 12:11 PM   #7
Tut4u2
Member#: 40424
05 STi
Longer exhaust hangers or just put some insulation between the two.
Tut4u2 is offline   Reply With Quote
Old 03-21-2009, 02:39 PM   #8
djoye
Member#: 50072
2003 WRX
12.3@112 20psi
My exhaust was rattling on that under-body heat shield somewhere towards the rear of the car, I remember just bending it and that resolved the rattle. Don't remove it.
djoye is offline   Reply With Quote
Old 03-22-2009, 10:50 AM   #9
GreenLantern
Member#: 159372
2007 WRX (stage ++)
UGM
WOW REALLY EVERYONE????
hes talking about the heat-shield on the MIDPIPE!!!!! For those of you that didnt realize, there are more heat-shields than that over the turbo.....
man you can remove the heat-shield or just bang it up until it doesn't it anymore.
Goodluck
-GreenLantern
GreenLantern is offline   Reply With Quote
Old 03-22-2009, 03:18 PM   #10
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
if your aftermarket mid pipe came with bracket for tranny
cross member, adjust the alignment to eliminate rattle.
factory heat shield are there for a reason.
Old 03-22-2009, 11:25 PM   #11
bluesube2
Member#: 204783
'03 wrb wrx stg2
'11 dgm wrx
take it off
bluesube2 is offline   Reply With Quote
Old 03-23-2009, 05:37 PM   #12
RealiTnh
Member#: 191452
2004 ej20 18g 303whp
@ 20psi Synaptic tuned
Take It Off!
RealiTnh is offline   Reply With Quote
How hard to remove heat shield on cilinder #4 for EGT??? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-26-2005 03:25 PM
Removing heat shields...is this ok? 2sour4u Normally Aspirated Powertrain 17 12-25-2003 01:19 AM
Removing Heat Shields? Ryan24 North West Impreza Club Forum -- NWIC 2 08-25-2002 06:00 PM
Installed exhaust- can I remove heat shield? SoLiDbReAkZ Service & Maintenance 8 04-18-2002 11:10 PM
Removing heat shield? SGOSWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-20-2001 12:22 PM
