Old 03-19-2009, 10:20 PM   #1
needawrx13
Member#: 175051
02 Slow rs
Brp/rust
Default 2.0 vs sti oil pump
is there any differences between a 2.0 wrx oil pump and a 2.5 sti pump?
needawrx13 is offline   Reply With Quote
Old 03-20-2009, 02:16 AM   #2
cooleys04
Member#: 145027
2004 WRX FP Green
MFactory/2Tone/built 205
They are both 10mm pumps, same part #. A 12mm pump is available if you need more volume, you can shim a 10mm pump for more pressure.
cooleys04 is offline   Reply With Quote
Old 03-20-2009, 03:45 AM   #3
fastwrx25
Member#: 126441
03 bugeye
the 08+sti have a 11mm pump
fastwrx25 is offline   Reply With Quote
Old 03-20-2009, 07:41 PM   #4
needawrx13
Member#: 175051
02 Slow rs
Brp/rust
cool, thanks guys!
Old 03-20-2009, 09:19 PM   #5
SacksLax
Member#: 193949
HIGHLY suggest the 08 STi pump
I have one in my car, did it with the timing belt. The pressure holds much better, and runs a tad cooler, and more efficient. Car feels better too, someone posted a chart of pressures, somewhere search for 08 STi oil pump or something like that, and it's in one of the threads. Definitely worth the piece of mind.
SacksLax is offline   Reply With Quote
Oil pans, 2.0 vs 2.5 Vlad Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 05-28-2010 08:37 AM
FS:CT- 04-05 Sti Head Gaksets- 2.0 Wrx Engine Gasket Kit- 04-07 Sti Oil Pump 98SubbyLeg Engine/Power/Exhaust 9 05-25-2010 04:55 PM
STi oil pump vs. WRX oil pump hypoxvi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-04-2009 01:44 PM
Stock 2.0 with a 08 STI oil pump? SportyMark Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-23-2008 04:04 PM
US 2.0 plus a STi Oil Pump dingobite Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-23-2006 10:54 AM
