Old 03-19-2009, 11:12 PM   #1
haberkorn
Member#: 97732
2004 STi
65 Nova [email protected]
Default hub centric rings needed?
Just curious if I need to run a set of hub centric rings on a 02 wrx with rotas. I wasn't paying close attention when i mounted my wheels to check how they mated up to the hubs.
If so what mm conversion size do I need?
haberkorn is offline   Reply With Quote
Old 03-19-2009, 11:22 PM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
Which Rota's? Many of them are hub centric. I think it is 56.1 or something??
tora is offline   Reply With Quote
Old 03-19-2009, 11:36 PM   #3
haberkorn
Member#: 97732
2004 STi
The SDR's are the ones on the car.
Old 03-19-2009, 11:43 PM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
I believe they are hub centric.
Old 03-20-2009, 01:00 AM   #5
subierider
Member#: 154651
when i installed a set of hubcentric rings on my volks ce28n I felt a more secure ballance some how. I say if you dont have it, get it
subierider is offline   Reply With Quote
Old 03-20-2009, 01:23 AM   #6
mr_hann
Member#: 165244
2007 2.5i
You could just measure the hub center. If it's close to 56.1, then it's probably hubcentric. Unless your last name is Wonder, you shouldn't have a problem discerning a 20mm gap.
Typically, aftermarket rims will run a larger hub center (ie 73mm) just so they can fit a variety of cars with a variety of hub bores.
mr_hann is offline   Reply With Quote
Old 03-20-2009, 07:34 AM   #7
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Placibo effect
Micky is offline   Reply With Quote
Do I need Hub centric rings? VitorBelfort041 Tire & Wheel 2 04-10-2009 12:04 PM
Hub centric Ring needed for Volks CE28N? SubyWRXSti Tire & Wheel 20 07-06-2008 04:33 PM
Hub centric ring, needed? aakrusen Tire & Wheel 2 11-18-2006 06:41 AM
Hub centric rings needed subywrx Tire & Wheel 9 09-01-2005 03:55 PM
need info on hub centric ring size NOTimprezed Tire & Wheel 8 02-10-2005 11:41 PM
