Old 03-20-2009, 12:15 AM   #1
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Default Big 20g ~ 402hp & 397 ft/lbs.
I am pretty happy with this setup. I only have a stock EBCS though, so Scott recommended me getting a MBC to even out the boost in 5th in 6th, as right now it's erratic. Tell me whatcha guys think.
Here's my mod list:
Engine:
-FP 20g Td06h 8cm
-APS 525 FMIC
-APS 65mm Intake
-Samco Inlet
-Grimmspeed coated TGV deletes
-No coolant routed through manifold
-8mm phenolic spacers
-Invidia V3 DP, no cat
-HKS Carbon Ti catback
-Forge BPV
-Perrin radiator shroud
-Walbro FP
-PE 850cc injectors
-ACT HD clutch and streetlite flywheel
-Rerouted intercooler sprayer to FMIC
-Scott Siegel tuned to 400hp with AP v2
Dyno was at S&R in Tampa, I think it's called like a "land and sea" dyno or something?
If I do anything else power-wise I would probably upgrade to Grimmspeed manifold ends and crossover pipe, uppipe and a Grimmspeed 3 port EBCS.
slowscooby is offline   Reply With Quote
Old 03-20-2009, 12:20 AM   #2
NAZSTI
Member#: 164516
2004 STI
Nice numbers/setup. what elevation are you at?
NAZSTI is offline   Reply With Quote
Old 03-20-2009, 02:53 AM   #3
rexworx
Member#: 103232
MY05 GDA, MY04 FXTI
2.5ltr,PPG,Front LSD,4.44
Wow nice power for a 20G What kind of fuel was the tuned on?
rexworx is offline   Reply With Quote
Old 03-20-2009, 05:43 AM   #4
kyo126
Member#: 149485
ur car looks amazing...i guess is insanely fast huh?
kyo126 is offline   Reply With Quote
Old 03-20-2009, 08:41 AM   #5
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
Nice power and Nice looking car!!
WagonGGA is online now   Reply With Quote
Old 03-20-2009, 08:45 AM   #6
06njsti
Member#: 150986
06 LSB STi
AWDM.NET-LMM Powered
the 400whp 20g tune, perfect for a street car in my opinon
06njsti is offline   Reply With Quote
Old 03-20-2009, 09:18 AM   #7
C J
Member#: 132587
2006 JrTuned STi
E85 GT3582r/10.83@126mph
and to think I almost didn't want to order a 20g anymore, nice numbers!
C J is offline   Reply With Quote
Old 03-20-2009, 09:33 AM   #8
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Love the numbers and the power curve, also interested in type of fuel. Very nice man.
irascible is offline   Reply With Quote
Old 03-20-2009, 09:38 AM   #9
J. Steinbeck
Member#: 140575
2005 Legacy GT sedan
Oh good Lord... your car looks so good it hurts. Very tasteful looking (and tastefully modded) with power that is bound to shock the Hell out of more than a few people. I would love to own a car nearly identical to yours, with nearly identical mods, at some point.
Hopefully you won't mind if I ask a few questions...
Just out of curiosity, what did Scott tune for in terms of target boost on a setup like this?
I'm guessing that the 850s on a 2.5 with a 20G are well matched. Any idea what kind of IDCs your car is running?
Finally, what brand of FMIC are you running? (EDIT- Nevermind... I now see in your post that it is an APS.)
Sorry about the questions. I'm just playing around with ideas of what I might do to my own car down the road, or what I might do if I switch to another vehicle. It's nice to hear from people experienced with what I *think* will be a path worth following.
Congratulations on a stellar vehicle and setup.
J. Steinbeck is offline   Reply With Quote
Old 03-20-2009, 10:15 AM   #10
xsblack
Member#: 26530
2004 Sti
JBP
Graph looks good. Any idea what a stock Sti will put down on this land and sea dyno? Also how much boost you running? on pump?
xsblack is offline   Reply With Quote
Old 03-20-2009, 10:20 AM   #11
Dookoo
Member#: 198301
2008 STI
What fuel?
Dookoo is offline   Reply With Quote
Old 03-20-2009, 10:46 AM   #12
Steve.804
Member#: 68647
07 STI
Rotated 35R Jorge Tuned
Wow perfect power band!! I'm sure this is an incredible street car! I'm also curious what a stock STI puts down on this dyno
Steve.804 is online now   Reply With Quote
Old 03-20-2009, 10:48 AM   #13
02h20
Member#: 130079
2006 STI 9.7@148
CleoTuned@PrecisionTuning
Is there any benefit in removing the coolant flow from the manifold?
02h20 is offline   Reply With Quote
Old 03-20-2009, 11:06 AM   #14
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Reduced intake heat.
Old 03-20-2009, 12:22 PM   #15
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
I am in Orlando, FL using BP 93 octane.
Not sure what a stock STi puts down on that dyno, I will email the shop and ask.
Steinbeck - I think my target boost is right at 20 pounds. Not sure what my IDC's are, I know I have plenty of room though.
Thanks for all the compliments guys
Old 03-20-2009, 01:04 PM   #16
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Thats some sick power for not going to crazy with the turbo or boost. Nice looking aswell. Good job looks like a blast to drive.
Slimsti is offline   Reply With Quote
Old 03-20-2009, 01:11 PM   #17
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
I believe stock STI's are around 230whp on that dyno.
Nice ride!
k04sti is offline   Reply With Quote
Old 03-20-2009, 01:45 PM   #18
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Cool, thanks for the info.
Old 03-20-2009, 02:06 PM   #19
klattery
Member#: 48503
2004 STi ATP3071
400 whp on 93 octane for a 20G seems pretty high, even for a higher reading dyno. Also, you're still running 65mm intake, and not maxing out the MAF.
I don't really care absolute numbers, but I think a lot of folks will be unhappy if they expect 400whp from a 20G on pump gas (even 93).
Most important thing is it's a nice powerband and nice looking car.
klattery is offline   Reply With Quote
Old 03-20-2009, 03:14 PM   #20
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
nice nice, car looks sick man. that seems like a lot of power for only 20 pounds on a 20g. you sure stock stis only put down 230 not 250-260?? must be a fun daily driver though.
godforbid67 is offline   Reply With Quote
Old 03-20-2009, 03:26 PM   #21
checque
Member#: 68562
RIP Edwin
Super high reading dyno. My 20G with cams and headwork makes that kind of power at 25psi on 110.
My DW850s are at 88% on a built 2.5 with 264 cams and lots of porting. It's amazing how some people can run 850s with a GT35R . . .
checque is offline   Reply With Quote
Old 03-20-2009, 03:41 PM   #22
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
I emailed the shop a bit ago and asked what a stock STi puts down.
It may not "actually" be 400hp, but it feels damn good
Old 03-20-2009, 04:38 PM   #23
k04sti
Member#: 171773
04 wrx sti
If they are running 850s with a gt35r then they are not using that turbo to its full capabilities at all.
Old 03-20-2009, 04:42 PM   #24
sr20dehauler
Member#: 98950
RIP - Subaru FXTi
SOLD - B13 SE-R
Aspen White '05 with a 20G... Yummy
sr20dehauler is offline   Reply With Quote
Old 03-20-2009, 05:01 PM   #25
blakkboxer
Member#: 167244
2k3 WRX MBP
black & gold is pimpin'
Beautiful car and #'s
blakkboxer is online now   Reply With Quote
Mikaust Retune - TurboXS GT30 .82 Kit & Andrewtech Motor build! 561whp & 489 ft. lbs Imprezd Proven Power Bragging 70 06-20-2008 10:17 PM
2006 WRX 20G 384 whp 387 ft/lbs Paintballguy Proven Power Bragging 75 09-07-2006 07:39 PM
Gains upto +10% more horse power & +13 ft/lbs more Torque on Gas Vehicles XLR8 out the turn Electrical & Lighting 12 08-29-2004 01:30 AM
Confirm Crank Pulley Torque; 132 ft-lbs or 90 ft-lbs? BritSti Factory 2.5L Turbo Powertrain 5 01-12-2004 09:56 PM
Convert in-lbs into ft-lbs? XBD General Community 5 11-27-2001 09:31 PM
Message Board Statistics All times are GMT -4. The time now is 08:25 AM.
