South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 03-20-2009, 07:41 PM   #1
superblkwrx
Member#: 129395
2006 OBPWRX VF39 E85
333WHP 385WTQ 21PSI SD
Default Help picking rotors
Hey what do you guys think about the cross drilled and slotted Rotora rotors? Any one purchased these before? And where is a good place to buy after market brake parts local. Caliente Auto seems to have gone out of business .
superblkwrx is offline   Reply With Quote
Old 03-20-2009, 07:47 PM   #2
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
PM Evil Performance. He has brakes in stock now for your car
v8eaterWRX is offline   Reply With Quote
Old 03-20-2009, 07:49 PM   #3
superblkwrx
Member#: 129395
Thanks I just PMed him now.
Old 03-20-2009, 07:57 PM   #4
sedanman10
Member#: 112948
I would recommend staying with a flat face rotor.
sedanman10 is offline   Reply With Quote
Old 03-20-2009, 09:57 PM   #5
superblkwrx
Member#: 129395
Why do you recommend flat faced? I can't see any down sides to those types of rotors. They only dissipate the heat better
Old 03-20-2009, 10:07 PM   #6
What's A GC?
Member#: 189719
1997 Impreza L Wagon
2 tone - Black/gray
Because flat faced have more surface area for the pad to grab onto and a well designed flat faced rotor can cool just as well as a slotted/cross drilled one. Also, it's rumored that drilled/slotted rotors are more prone to cracking.
What's A GC? is offline   Reply With Quote
Old 03-20-2009, 10:11 PM   #7
Heider
Member#: 172173
2005 Impreza WRX
actually i was informed that flat faced rotors dissipate heat better because they have more surface area. i guess it depends on what you are using the rotors for. if it's everyday driving plus spirited driving, then i'd stick to flat faced. if you are going to be racing then maybe the slotted/drilled rotors would be useful. just remember your pads will get eaten up alot quicker. of course this is all my opinion and don't take it as fact
Heider is offline   Reply With Quote
Old 03-20-2009, 10:18 PM   #8
superblkwrx
Member#: 129395
I agree with the cracking rumor but I don't know about the dissipating faster with flat faced. But lets say I go with a flat faced rotor, what brand have you guys had luck with? The OEM ones were horrible(mostly because of the pads) Gruppe-S was on back order for the Hawks so for no extra cost they sent me the hawk +'s. I had no choice cuz my pads were completly gone. So the pads were too much and heat checked the h3ll out of the oem rotors.
Old 03-21-2009, 01:12 AM   #9
Heider
Member#: 172173
2005 Impreza WRX
replaced my fronts with brembo rotors and PBR/Axxis Deluxe pads (http://www.importrp.com).
Old 03-21-2009, 11:48 AM   #10
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
DBA 5000 FTW....
All brakes will crack if not taken care of correctly.. But you are driving on street only. Brembo blanks are you best bet. Get a organic pad. These pads dont last as long but its cheaper to replace your pads then rotors.
Slotted help clean and keep the brake pad flat. Nice step up from the blanks. Would be good around here as the desert dirt and sand can tear things up.
Drilled: Need to be cooled off after hard use. They can cause cracks. Each time you drill a hole it can be a stress riser. Cheaper drilled rotors have bigger chance as they dont clean the drilling up as much.
Also you can get them get them cryo treated. But I think you are more street use?
I'd stay with brembo blanks... Axis pads... Or upgrade to slotted.. I love my DBA's best upgrade I have bolted on.
Make sure to upgrade your brakelines if you have a older car. Old hose after a while tend to get even more spongy then new. Which effect brake pedal feel.
And brake fluid dont go cheap..... That can cause all sorts of problems..
06STi is offline   Reply With Quote
Old 03-21-2009, 02:04 PM   #11
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
just get a brembo flat face replacement. slotted works great on track because they will pull some more gasses out and reduce overheating and warpage. they also work well in wet weather, keeping the pads clean. drilled will also reduce debri on the surface in dusty conditions, but you loose surface area. both will cause more wear on pads.
On the street, flat works best because you have a constant surface for the pad to grip and they wont cause as much wear. a pad like the hawk hp+ will definitely wear out a rotor, especially when cold.
WgnWheel is offline   Reply With Quote
Need help picking front rotors slaytalera Brakes, Steering & Suspension 4 04-25-2009 11:56 AM
Help! Uneven Rotor Wear with new rotors (H6 in rear) and pads Saucy7 Brakes, Steering & Suspension 6 10-07-2008 03:23 PM
Need help picking a WRX!!! please help! boost4life1 Newbies & FAQs 19 02-14-2007 03:04 PM
need help picking rotors willyb Brakes, Steering & Suspension 12 08-06-2005 09:51 PM
Help picking an amp. SilverSuby Car Audio, Video & Security 12 06-12-2001 09:09 AM
